bed rail holes
Discussion in 'Tonneau Covers, Caps and Shells' started by holokuk, Mar 2, 2022.
  1. Mar 2, 2022 at 3:09 PM
    holokuk
    holokuk [OP] New Member
    '21 Tundra DC
    flux capacitor, curb feelers, fuzzy dice, bumper sticker
    maybe an odd question, but has anybody ever utilized any of the "holes" along the bedrail (underneath the cap, excluding the stake pocket hole) as an attachment point? i'm talking about the holes that the little plastic tabs (on the underside of the plastic rail cap) fit into, the rectangular/square openings. i've got a situation wherein i'm trying to avoid drilling holes, and cannot use the stake pocket hole on account of things not lining up. i was considering using some kind of toggle bolt or something similar. but all i've ever seen are the typical cheap-looking toggles; i'm a little wary on those guys.
  2. Mar 14, 2022 at 8:18 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I have not seen that but you probably could.
    holokuk[OP] likes this.
  3. Mar 14, 2022 at 8:59 AM
    holokuk
    '21 Tundra DC
    thanks for the reply. i have 2 aluminum feet, one on each bedrail. each extends about 30" from the cab side of the bed (up tight near the window) along the rail down towards the tailgate. i've figured out how to make it work w/ the bed pockets (contrary to my original post) and would just need to secure the end opposite the bed pocket. so i plan to drill a hole through the foot, through the plastic cap, and down into the square hole (red circle), and drop a toggle bolt w/ large washer into the hole. it wouldn't act as a load bearing anchor as much as it just needs to hold the end of the foot in place. hopefully it works, but am open to other suggestions. bedrail1.jpg
  4. Mar 14, 2022 at 9:06 AM
    2mchfun
    Why not? A fender washer or even a flat bar on bottom would distribute the forces, but you might need to trim off any tabs on the rail cap that would interfere. Use a fender washer on top to help prevent cracking the cap and give an air gap for any condesation to dry.
  5. Mar 14, 2022 at 10:00 AM
    Willard
    Willard New Member
    2024 F250
    You’re going to want a spacer under the cap. Otherwise when you tighten that bolt it will squash the cap which is only supported by a few ridges of plastic running lengthwise and crosswise.
    2mchfun and holokuk[QUOTED][OP] like this.
  6. Mar 14, 2022 at 10:13 AM
    holokuk
    '21 Tundra DC
    great advice, thank you.
    2mchfun likes this.
