Bed rail and cargo hooks?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Vintner, Oct 8, 2021.
  1. Oct 8, 2021 at 7:27 AM
    Vintner
    Vintner [OP] New Member
    Robert
    2021 Tundra
    step rails
    New '21 and the truck bed is has a series of what look like .25 or 6.. threaded holes along the inside of the bed. The Toyota rail system i have seen is pretty wide and reduces the width of the bed. Has anyone a recommendation for a simple cargo hook or better rail? The rail system is attractive as it allows positioning, but I own a wrench and often transport the same configuration cargo - standard fermenter bins for grapes. No way the the only low cleats work. Some low profile Stainless unistrut? Ideas if you can. Thanks!
  2. Oct 8, 2021 at 7:36 AM
    2mchfun
    D rings could be mounted in the holes or stake pocket anchors which would probably be stronger and better suit your needs.
  3. Oct 8, 2021 at 7:48 AM
    ezdog
    ezdog New Member
    Gateway To The West
    There are threads on here about options and of course you can use strut as one of them. You will still lose 3/4” for strut plus whatever fastener you decide is right but sure are welcome to find what works for you. I have also used rivnuts in the bigger holes lower in the bed and ss eyes in them. No idea about what you are mounting so tough to make better suggestions there really?
  4. Oct 8, 2021 at 12:39 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
