Bed Rail 2019 Tundra Double Cab
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2point5seconds, Jan 11, 2021.
  1. Jan 11, 2021 at 4:13 PM
    2point5seconds
    2point5seconds [OP] Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    I finally decided to get a bed rail system for my 2019 DC.
    I read some directions on this site and watched a video on how they did it.
    Problem I had was the truck was bought new from dealer with a spray on bed liner. So the holes to hold down the rails were covered.
    Someone said to use a needle and hammer and tap around to find the hallow points. It was dark and I just got off work so I didn't have the patience. (Pics were taken next day with better lighting)
    So I stuck the rails up using the plastic clips and made sure it was level. Then I took a tap punch to find the holes. I found them every time by hitting in the center of each hole. Plus it made a hole through the liner where I used a box cutter to open the hole slightly. I used a hex from GorillaGrip. It was nice because I could flip it over and have it at a 90 degree angle to really tighten the bolts. I thought i would break it but it held up.
    https://www.amazon.com/dp/B000E7VG4S/ref=cm_sw_r_cp_apa_i_VKo.FbYJQXNDW?_encoding=UTF8&psc=1
    There's five bolts on each side and four in the front rail. There's one hole on each end that I do not think has a hole for a bolt. I tried to use the tap punch to find one but never did. I did end up using five bolts on the side rails and four on the front one.
    Got done in about an hour.
    jnjonesx2, Terndrerrr and Black Wolf like this.
  2. Feb 9, 2021 at 4:20 AM
    Whittle
    Whittle New Member
    2021 Magnetic Gray Tundra TRD Pro
    Did the bolts you installed look like the left or the right below?
  3. Feb 9, 2021 at 4:48 AM
    The left is the OEM bolt. I found this In another thread.
  4. Feb 9, 2021 at 7:42 PM
    Whittle
    Whittle New Member
    I saw that as well, the issue that I'm having is that after my Line-Xing I'm 3 bolts short on the bed rail system. I figured easy fix, called the dealership had them order them in for me and got the ones on the left. Went to install them and couldn't get them to work. So I pulled out the two remaining screws on the rail that needed them and both of them looked like the ones on the right not the left, i.e. longer, no tapering etc. Just wondering if anyone has ever seen that or knows what's going on. Thanks!
  5. Feb 10, 2021 at 2:36 PM
    2point5seconds
    Sensei
    Nor Cal
    I can pull the screws out and see which one I have. I have to say, when I used the punch to make a hole through the bed liner, I think it left bits of the liner in the hole. So I really had to turn the screws hard to get them in. Eventually as they went in, it got easier.
    Is that issue you're having?
  6. Feb 11, 2021 at 6:18 AM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    For what it's worth, I just did this install a few weeks ago on my '21 DC, also with the Toyota spray in bed liner... After having to cut the bedliner off of the front tie downs/bolts to install my DECKED drawers, I was fearing the worst trying to find the holes.
    As @2point5seconds stated above, just using the plastic clips to hold the rails in place and finding the center of each opening was the ticket. I used a straight pick tool that, coincidentally, was just a bit smaller than the size of the threads on a T30 bolt, so a few "reams" in and out cleared enough bed liner for the bolts to catch the threads.
    I'm not 100% on which bolt style I had, but I want to say it was the A0006 as I don't remember the taper, and I remember them being somewhat longer than I thought they needed to be. That being said, my rail set was purchased through the parts department of my local dealership, so I'm not sure if there may be a discrepancy between what is provided on the new trucks vs purchasing the kit later (unless the bed rail install is simply a tech installing the kit prior to sale, I'm not sure if it counts as a dealer installed accessory).
