Bed plug
Discussion in '2.5 Gen Tundras (2014-2021)' started by BlueBottle, Feb 20, 2019.
  1. Feb 20, 2019 at 9:13 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Anyone know the part # for this?
    I need to replace mine.
    If anybody has two of these laying around that would even be better!
    @Roman maybe?
  2. Feb 21, 2019 at 8:37 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  3. Feb 21, 2019 at 8:56 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  4. Feb 21, 2019 at 9:29 AM
    TheBeast The Beach
    need some Line-X on that bed :)
    Sunnier, BlueBottle[OP] and 15whtrd like this.
  5. Feb 21, 2019 at 9:34 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Just out of curiosity, what are those plugs used for?
  6. Feb 21, 2019 at 10:40 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Not my truck! was lazy so just did a screen capture of a youtube video lol
    Yup, if you want to make your truck into a pool, unplug those to let the water out lol... haha I drilled mine for a drain for my old tonneau cover that I don't have anymore so I want to cover up the hole.
    Sas[QUOTED] likes this.
  7. Feb 21, 2019 at 1:35 PM
    Sas
    OKC, OK
    Interesting. I don't think I've ever had so much water in the bed of any truck I've owned that I would've even contemplated the need for a drain plug. I guess if you live in an extremely rainy area or something?
  8. Feb 21, 2019 at 1:40 PM
    15whtrd
    15whtrd Mr. Blonde
    It would most likely flow out of the back of the tailgate or the small gaps in between the front bed panel and the floor.
  9. Feb 21, 2019 at 1:41 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Good post as I'm in need of one as well, noticed it was missing last week.
  10. Feb 21, 2019 at 2:32 PM
    Sas
    OKC, OK
    Apparently the plug thieves are about again. Crazy little Tide Pod eaters.
    Tundra2 and NewImprovedRon like this.
  11. Oct 29, 2021 at 5:40 AM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    Since nobody else really got it, they allow you to run electrical wires, drain hoses, vent lines, coax cable, and similar through the bed wall. Fewer holes drilled into the metal wall, and easy to replace as you change things around as your needs change.
    By the way, nothing to do with draining water. There are small openings under the front bed wall to allow water to drain away.
    Sas[QUOTED] and coldcanuk like this.
  12. Oct 29, 2021 at 6:17 AM
    Willard
    Willard New Member
    2024 F250
    There is a slight gap between the bed and front wall, as they’re two separate pieces. Even with a spray on bed liner mine drains out the front near the corners.
    I would think an excessive amount of liner sprayed in that gap would close it up. It may be possible to punch through it with a thin blade, at the risk of hitting your bed underneath.
