Bed mounted Vertical dual tire carrier, options?
Discussion in 'Recovery & Gear' started by 14burrito, Dec 2, 2019.
  1. Dec 2, 2019 at 5:30 PM
    14burrito
    14burrito [OP] IG @14burrito
    2014 SR5 CM 4x4 5.7
    What options do we have out there for a tire carrier as such? (Aside from SDHQ)
    Thanks
    TundraXPLover, Flyinryank and cmack like this.
  2. Dec 4, 2019 at 11:56 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Just a little bump bump
    Talking with someone locally about ideas, pricing.
    Still curious if there are any cookie cutter carriers options out there!
    Thanks
  3. Dec 4, 2019 at 12:28 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Nfab had one but it’s not on their site anymore
    TundraXPLover and 14burrito[OP] like this.
  4. Dec 4, 2019 at 12:41 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I guess I can also be open to alternate solutions,
    A vertical setup seems to take the least about if bedspace.
  5. Dec 4, 2019 at 1:00 PM
    Vizsla
    Vizsla pretend2send
    Most of us just double stack them in the bed with Mac’s tie down systems or similar. Like this but 2 tires. Keeps center of gravity a little lower, maybe.298ADCDD-7956-49B0-8E39-A5BF6C6D7F29.jpg
  6. Dec 4, 2019 at 1:04 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Thought about that, easy and simple, clean - but I feel that takes up more space than a vertical setup as pictured above would. I guess I'll have to do something math to see if that is actually the case lol
    It at least gives me more bed real estate ground wise, may not once you take spacial awareness into account.
  7. Dec 4, 2019 at 1:19 PM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    Flyinryank and 14burrito[OP] like this.
  8. Dec 4, 2019 at 1:22 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I have come across that, my only concern on it is the strength. By no mean am like a lot members, but I do do enjoy my truck offroad and not sure this will hold up as I hope. I get a little roudy.
    Another issue I see with that is I would need to either mount front of the bed, single spare then, or near the tailgate on either end which places alot for weight rear axle - which is what I'm trying to avoid.
    5.7TRDProm likes this.
  9. Dec 4, 2019 at 3:37 PM
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Yeah I feel like those screws that hold th rails in couldn’t take it when doing anything bigger than a bumpy fire road
    14burrito[QUOTED][OP] likes this.
  10. Dec 5, 2019 at 4:52 AM
    gears_call
    gears_call New Member
    Orange County, CA
    2014 SR5
    King 2.5's l Method double standards l 35" BFG KO2 l SS Built front bumper/skid/valence l more to come....
    Most local fab shops can also make you one too don’t forget
  11. Dec 5, 2019 at 5:01 AM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    I'll be selling my Wilco Pre-Runner tiregate soon here
  12. Dec 5, 2019 at 6:16 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Post 2 ;) already chatting with a couple for ideas on pricing, still wanted to see if there were any cookie cutter options. Doesn't look like there are for us, craptor has plentiful.
  13. Dec 5, 2019 at 6:20 AM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
  14. Dec 5, 2019 at 6:45 AM
    14burrito
    2014 SR5 CM 4x4 5.7
  15. Dec 5, 2019 at 6:47 AM
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
  16. Dec 5, 2019 at 6:55 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    I actually came across these, local company as well. Only downside, I'm trying not to drill into the bed.
    Trying to utilize the bed bolts as tie down points. Also, if I get one made by a local fab guy, maybe extend into the bed rails for some added bedside stability.
    Have you found them for less than $500/ea? Little pricey option as well IMO.
    Local shops are quoting me about 600 to 800 for similar designs as post 1.
    Bakelite[QUOTED] likes this.
  17. Dec 5, 2019 at 7:06 AM
    GravityGear
    Aurora, CO
    Nah.
  18. Dec 5, 2019 at 7:10 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Figured
  19. Dec 5, 2019 at 7:20 AM
    Bakelite
    Bakelite New Member
    Sam
    I haven't scoured their site or for deals a ton regarding it, since I'm still working on new tires and wheels and some new UCAs. I'll get to it when I get to it lol. Think I may go this route for my full size spare.
  20. Dec 5, 2019 at 7:24 AM
    GravityGear
    Aurora, CO
  21. Dec 5, 2019 at 7:52 AM
    gears_call
    Orange County, CA
    2014 SR5
    Ahhh. Reading often does help... haha
  22. Dec 5, 2019 at 7:55 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Can't be that hard to adapt a raptor one over if you like the looks of one of those
  23. Dec 7, 2019 at 3:31 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Sounds like you want something very particular. I think you're on the right track talking to a local shop.
    14burrito[OP] likes this.
  24. Dec 18, 2019 at 9:24 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    So, Dave, as I continue to search....I may have come up with an idea, similar but different to yours. Might have gotten some inspiration from you and something I found online. This idea will incorporate, easy to remove, bedside supports/stiffeners as well...hmmm
  25. Dec 30, 2019 at 10:02 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Well back to the drawing board for a vertical lol
    Don't like the tires forward, moves too much added weight rear of the axle and I don't want to have to walk over the tires to get into the storage bin.
  26. Jan 6, 2020 at 2:57 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Well....lol
    Vizsla, TRDFerguson, TheBeast and 2 others like this.
  27. Jan 6, 2020 at 2:58 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    SDHQ?
  28. Jan 6, 2020 at 3:15 PM
    TheBeast The Beach
    there you go ! custom work for your bin :)
    I don't think you need the oem bottle jack either..lol
  29. Jan 6, 2020 at 3:39 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Yes Sir,
    Buddy selling his used one locally, snagged it up from him. Actually really happy with it. The rubbermade box fitting was a concern, fits beautifully! Has all my wheeling gear.
  30. Jan 6, 2020 at 3:44 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Bottle jack will stay, going to make extensions for it for the time being. Similar to what's pictured below.
    TheBeast[QUOTED] likes this.
