Bed mat with factory spray-in liner
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mustang67ford, Jul 30, 2023.
  1. Jul 30, 2023 at 5:09 AM
    Mustang67ford
    Mustang67ford [OP] New Member
    My truck came with the factory spray-in bedliner. I am still looking to get a rubber mat to keep things from sliding around. Would there be any issues putting a mat on the liner like causing wear on the liner? Also, is the OEM tundra mat good or is there something better out there? I see husky makes one also.
  2. Jul 30, 2023 at 5:36 AM
    NCSkeeter
    NCSkeeter New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    I don’t see any issues with my OEM mat and after market spray-in liner after ~4.5 years.
  3. Jul 30, 2023 at 5:44 AM
    BruinsFan
    BruinsFan New Member
    No issues here either. I purchased a Dee Zee mat from Amazon for about $100 shortly after purchasing my truck in 2021.
    djflaco23 and rdiddy5 like this.
  4. Jul 30, 2023 at 5:57 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    My 2020 came new with the factory spray in liner. I added the OEM Tundra mat almost imediately, the only minor issue was the mat having been rolled up caused the ends to want to stay somewhat upward. I did lay a board on the front edge to hold it down, the back edge wasn't as prominent. Over time this has diminished and I don't see it as a real problem.
    Over all I really like the mat and would buy it again, it protects the spray in liner from potential damage from loading things like cement blocks and helps things in place while driving. Also adds a cushion for your knees if needed.
    I can't give any comparisons with other like prodects, can only say "works for me".
    TXBrit likes this.
  5. Jul 30, 2023 at 7:43 AM
    rodbucks
    rodbucks New Member
    jeff
    Campbell
    2019 Tundra Limited Cement
    Fox 2.5, Rago Front Skid, BD Pro Ditch Lights, Diamondback HD, TRD Exhaust, TRD Rear Sway
    No issues on my 2019, have Line-x and the Tundra rubber mat, no issues or uneven wear under the mat.
    Ely010606 and TXBrit like this.
  6. Jul 30, 2023 at 8:14 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I have the factory liner as well and I threw in a factory bed mat as well with no issues at all. It might even work too well. Sometimes I get pissed trying to push or pull something on it lol
    Guess I should mention I have a diamondback
    Neo258, excelw and TXBrit like this.
  7. Jul 30, 2023 at 8:20 AM
    Marc4x4
    Marc4x4 New Member
    No issues on my old truck, I washed underneath it every once in awhile.
  8. Jul 30, 2023 at 12:12 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Same here. The only thing I have noticed is the area under the mat is like new (Line-X Premium) and the interior side walls of the bed are a bit faded due to exposure to sunlight. No functional issues, simply cosmetic.
  9. Jul 30, 2023 at 5:03 PM
    Mustang67ford
    Thanks for all the info. Good to know. Anybody try something other than the oem mat?
    NewImprovedRon likes this.
  10. Aug 1, 2023 at 1:46 PM
    Mustang67ford
    Decided to order an OEM mat but easier said than done. There are or were 3 different part numbers
    pt58034070sb
    pt58034070
    pt58034070lb
    Supposedly the SB is a short bed 5.5' (discontinued), the no letters at end was the standard bed (also discontinued), and the LB was a long bed. The story I got was the long bed was the 6.5' bed and replaces the no letters part numbers. Supposedly the 3 mats were only about 2" difference between them and the LB was 67". I have a 6.5' bed which is therefore supposedly the long bed the long bed is the standard bed. Very confusing, but ordered the LB as it was the only one not disco tuned ND is supposed to be for a 6.5' bed. will know shortly if correct. I have my doubts.
  11. Aug 1, 2023 at 2:40 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Yep, BedRug!! Love mine!
  12. Aug 1, 2023 at 4:35 PM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    This guy
    I rolled on Herculiner for my mini truck and it's outstanding so far. It's got a rough texture.
    Elroy_unlimited and Jaypown like this.
  13. Aug 2, 2023 at 4:35 PM
    Mustang67ford
    Picked up the LB version of the bed mat. Ended up being 18" longer than needed. Cut off the 18" and fits great.
    ATV25 likes this.
  14. Aug 2, 2023 at 4:47 PM
    GeoJoe
    LB version - as in 8' bed? Where'd you get that?
  15. Aug 3, 2023 at 2:48 AM
    Mustang67ford
    Yes. Overall it was roughly 8'. Got it from the dealer after being told the LB version was now the standard bed or something like that. Apparently they are all discontinued but the LB version is the only one that still has stock. I cut the extra 18" off up against the front of the bed and it works great. From the start of the wheelwells back and the tundra wording, it all looks factory and needed no trimming.
    GeoJoe[QUOTED] likes this.
  16. Aug 4, 2023 at 7:08 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    I have a spray-in bed liner with a Dee Zee bed mat. I think it's an awesome combo. The spray-in liner keeps the bed from rusting, and the bed mat protects the bed liner from being wrecked when hauling things like blocks or similar items, and also keeps things from sliding around. I love it.
    The Dee Zee mat is perfect for me. Good coverage, nice balance of toughness but soft enough to provide cushion and keep things from sliding.
    https://www.deezee.com/product/truck-bed-mats/
    Only pic of mine I could find:
  17. Aug 5, 2023 at 2:45 AM
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    Here's the bed Rug on my 2020. It's been great. You can't damage it. I've tried.
    ss_803 and NewImprovedRon like this.
  18. Aug 5, 2023 at 9:03 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  19. Aug 7, 2023 at 7:47 PM
    dundunDUN
    dundunDUN New Member
    2016 Tundra SR5 CrewMax
    I went with the exact same for my 2016 and like how they have the tough webbing that covers the tailgate gap. It’s been on for over a month now and no issues. Perfect fit. Only complaint was having to keep folding it back during install to keep it from lifting, ended up with creases in it but it performs flawlessly. The extra cushion on the knees is appreciated as well.
    1lowlife[QUOTED] likes this.
  20. Aug 10, 2023 at 8:53 AM
    MadTrapper
    MadTrapper New Member
    2018 Crewmax TRD
    I was given a BedRug by a friend just after I had my 2018 Crewmax done with Line-X Rhino-liner. Bulletproof and great on the knees.
    sonofdad likes this.
  21. Aug 12, 2023 at 4:32 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    I have the factory spray in liner which is horrible in my opinion,and i bought a rubber bed mat to out over it to stop everything from sliding around
  22. Aug 25, 2023 at 8:03 PM
    PA452
    PA452 New Member
    What's horrible about it?
  23. Aug 26, 2023 at 4:12 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Good question, I have the factory spray in bed liner and seems just fine to me.
  24. Aug 26, 2023 at 2:03 PM
    Rob's Inferno
    it's like 80 grit sand paper and nothing stays put. And its super thin.
