Bed Mat question
Discussion in '2.5 Gen Tundras (2014-2021)' started by eagleguy, Mar 25, 2022.
  1. Mar 25, 2022 at 3:45 PM
    eagleguy
    eagleguy [OP] New Member
    For my 21 Tundra I have a plastic drop in bed liner but I also added a Rough Country bed mat. Problem is that I need to trim the mat to fit it inside the drop in plastic bed liner. NOT so easy! The mat is almost impossible to cut to fit. Any ideas?
  2. Mar 25, 2022 at 3:51 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Get rid of the plastic drop in, nothing but trouble down the road
  3. Mar 25, 2022 at 3:58 PM
    Lemoyne40
    Lemoyne40 New Member
    Central PA
    :thumbsup::thumbsup::thumbsup::thumbsup:
    Toyotoholic likes this.
  4. Mar 25, 2022 at 4:01 PM
    This^^^^.
    831Tun, Toyotoholic and panicman like this.
  5. Mar 25, 2022 at 4:03 PM
    Jig saw with a fine tooth blade.
    HulkSmurf14 and Black Wolf like this.
  6. Mar 25, 2022 at 4:03 PM
    Lose the drop in, sell the RC mat and get a Bedrug!
    Omohundro and Toyotoholic like this.
  7. Mar 25, 2022 at 4:04 PM
    Are you a bot? Heh...heh.. I am...
    panicman likes this.
  8. Mar 25, 2022 at 4:05 PM
    Ro
    BOT :D
  9. Mar 25, 2022 at 4:33 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Agree ditch the drop in plastic liner, only use the mat if you've had spray in bed liner applied, or have bed cover or shell. I have one with zipper sides and front, and removed them, I only use the bed section, works great.
  10. Mar 25, 2022 at 6:04 PM
    eagleguy
    Bed liner fine for me. Had issues with spray in bed liners before. Just asking best what to cut bed mat with, thanks!
  11. Mar 25, 2022 at 6:59 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Option 1: pack of brand new razor blades in a good razor knife.
    Option 2: jigsaw with a fine blade, maybe using silicone spray to lube the cut and blade.
    You’ll have to make a jig or a straight edge.
    (BTW, I advise just getting rid of the liner and using the mat)
  12. Mar 26, 2022 at 6:53 AM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Either way if you don't have your bed sprayed , you're going to get alot of rust fast, unless it's covered. Probably one of the best investments is spray in liner, professionally done.
    Mike59 likes this.
  13. Mar 26, 2022 at 7:17 AM
    eagleguy
    I have had numerous drop bed liners in other trucks over the years. Always heard about the rust issue but never experienced it myself. Hope this time around there is no exception!
    Weather Tech also has an underliner to protect from any scratches for those concerned.
  14. Mar 26, 2022 at 3:06 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    I also vote get rid of the drop-in liner, get a spray liner and use the mat on that.
    Mike59 likes this.
  15. Mar 27, 2022 at 8:02 AM
    2mchfun
    Sell the mat and go get 4×6 stall mat from a farm supply. Less headache, more useful. Easy to pull out and throw down for camp mat, mechanic work mat, over downed power lines for safe passage, etc. Hell you can even throw it in a horse trailer and haul a horse or two!
    akmerle likes this.
