Bed liners: Spray-on vs insert
Discussion in '2.5 Gen Tundras (2014-2021)' started by PA452, Aug 8, 2018.
  1. Aug 8, 2018 at 8:14 PM
    PA452
    PA452 [OP] New Member
    2021 Tundra SR5 CM TRD O/R
    Got my new Tundra last Tuesday. Worked into the deal a bed liner insert, which I'm still waiting for. Couple people I've since talked to think it's a bad idea, but even the salesman said for my use the insert is probably the way to go.
    It would be pretty rare that I'd haul something like sand, if ever. But I will be hauling firewood, tools (shovels, picks, digging bars, axes, etc..), occasionally things like brick or stone. None of this would be regularly, just thinking of things that I definitely find myself moving now and then.
    My thought is the insert will likely stand up to this type of use better than a spray-on, but I don't have any experience with a spray-on so can't say for sure. Only downside to the insert is the potential for holding moisture between the liner and the metal, but hopefully that's not a huge problem.
  2. Aug 8, 2018 at 8:20 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Spray in will outlast the liner. The liner will also scratch the crap out of the bed and rub the paint off so once installed never take out. Liners also cause static electricity which can be an issue if you ever place gas cans back there. The spray should outlast the truck and the liner will probably need replaced at some point and is susceptible to warping in the heat. My 2cents
  3. Aug 8, 2018 at 8:28 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    I second @Tracker
    Spray in is they way to go if it’s an option.
  4. Aug 8, 2018 at 8:28 PM
    PA452
    Will a spray-on flex well with dents and not crack? Not that I plan on putting dents in it, but I just can't imagine not getting some dents over the years with any hard use and a spray-on liner.
    My parents have an insert type liner in their F150. It doesn't fit tight at all anymore; still effective though admittedly I have no idea what the bed underneath looks like. I wish I could remember what it was like when it was new.
  5. Aug 8, 2018 at 8:31 PM
    Rider0120
    Rider0120 New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    I have a liner in my 1990 F350. I’ve always had a liner in my trucks. When loading firewood, refrigerators, boxes, whatever is always easier to slide from the bed to the tailgate. The bed could hold a static charge but I always fill my gas cans on the ground like the pump tells you to and I ground myself out on the pump itself.
    Let’s say you load a big piece of wood in the bed you flip/roll it over and it hits the bed hard, I’ve seen spray Berliner’s dent in where the plastic liner has a little more give. Plus the plastic liner has slots in it for a 2x6 to divide the bed into 3 sections which is great, I always leave the one in closeted to the tailgate for my cooler and other items I don’t don’t rolling/sliding to the front.
  6. Aug 8, 2018 at 8:32 PM
    CCLJ03
    Craig
    I’ve honestly never seen a spray in liner crack in person, but most come with a lifetime warranty anyways. The one I’m having the dealership install tomorrow does!
    Tracker likes this.
  7. Aug 8, 2018 at 8:43 PM
    17inferno
    17inferno New Member
    I like the insert. I toss things in the back of my truck without thought, and never have to worry about it. It is much better dent protection in my opinion, which is something that I look for. The spray in looks pretty, though.
  8. Aug 8, 2018 at 8:44 PM
    15whtrd
    15whtrd Mr. Blonde
    Just do both and it will last forever. :stirthepot:
    Fiestee23 and CCLJ03 like this.
  9. Aug 8, 2018 at 8:46 PM
    15whtrd
    15whtrd Mr. Blonde
    Seriously I would go spray in liner. If it really bothers you the drop ins are easy to come by. Sometimes even the Liner place can give you one that somebody is throwing away.
  10. Aug 8, 2018 at 8:47 PM
    PA452
    Haha
    :spending:
    15whtrd[QUOTED] likes this.
  11. Aug 8, 2018 at 8:49 PM
    PA452
    My thought as well on dent protection. Like I said, I don't have experience with the spray-ons but I just can't imagine if you stacked a bunch of cement block in the bed and something fell it wouldn't crack that liner?
    Boerseun likes this.
  12. Aug 8, 2018 at 8:52 PM
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    I despise the liner in my truck. Had it not come with it, I would have done a spray for sure.
    NewImprovedRon and zeke7681 like this.
  13. Aug 8, 2018 at 8:53 PM
    PA452
    What do you not like about it?
  14. Aug 8, 2018 at 8:55 PM
    KB Voodoo
    Chad
    It’s a cheap, poorly fitting piece of crap. And I can’t even imagine all the dirt and crap that is trapped under it. And let’s not even get into all the salt that must be under there in the winter, eating away at the bed.
    NewImprovedRon likes this.
  15. Aug 8, 2018 at 8:56 PM
    I think my BedRug is the best of both worlds. You can abuse the crap out of it. Pretty much load anything on it. It's washable, breathable, and padded in case you have an impromptu overnighter.
    hogpiolet, NewImprovedRon and 15whtrd like this.
  16. Aug 8, 2018 at 8:58 PM
    KB Voodoo
    Chad
    Even a rubber mat would be better than what I have.
  17. Aug 8, 2018 at 9:00 PM
    Depends where you live. I had one that I replaced with my BedRug. Plastic liner was 8 years old. Zero rust, dirt, crap ...only a couple spots with very minor scuffing.
  18. Aug 8, 2018 at 9:02 PM
    DeeZee makes a real decent rubber mat
  19. Aug 8, 2018 at 9:07 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    My spray-in liner flexes with the steel when the bed is dented and has no cracks. I have a bed mat atop my liner that does well at blunting impacts and also keeps items from sliding around.
    15whtrd likes this.
  20. Aug 8, 2018 at 9:10 PM
    15whtrd
    15whtrd Mr. Blonde
    That’s my setup. Wouldn’t mind a bedrug as well though.
    Black Wolf likes this.
  21. Aug 8, 2018 at 9:11 PM
    15whtrd
    15whtrd Mr. Blonde
    I don’t like that my tailgate sheet metal flexes with my bod weight.
  22. Aug 8, 2018 at 9:20 PM
    PA452
    Interesting, never heard of BedRug. I see Husky makes something very similar too.
    Sounds like your experience with the plastic liner wasn't bad though. Do you like the BedRug much more?
    I see WeatherTech also makes a "TechLiner" that looks decent, and I've liked the WeatherTech products I've owned. Only thing is it offers nearly no protection to the sides and I'm questioning how much dent protection it would really offer.
  23. Aug 8, 2018 at 9:27 PM
    Honestly I'd stay away from the plastic liner. Love my BedRug. Not even comparable to a plastic liner. There were some on my local Craigslist going for $75 and they won't sell. Sold mine for $60. I'm not aware of anything similar to BedRug quality. BedRug has been around for quite some time.
  24. Aug 8, 2018 at 9:34 PM
    Aron9000
    Aron9000 New Member
    Aaron
    Yes, I had one in my old Tacoma and my current Tundra. Great product, keeps stuff from sliding around in the bed, keeps the bottom of your bed from being scratched up. Doesn't trap water or crud under your bed either, doesn't scratch the paint finish on your bed floor like a plastic liner.
  25. Aug 8, 2018 at 9:50 PM
    Aron9000
    Aron9000 New Member
    Aaron
    Also any plastic bed-liner is a real piece of shit. I've had that POS plastic liner in two trucks I've owned.
    First one was my 1993 Toyota pickup, a "basket case" I bought for $600. It had been hit in the front, nothing on the grill, headlights, fenders, hood lined up, hood was held on with a bungee cord. Whole truck had been black from the factory, I honestly think it might have been some sort of fancy factory black out package, no chrome trim, bumpers were black, yet delux interior with carpet, full door panels, it was trimmed out nice inside.
    I don't know the whole story but my friend's mentally ill wife had painted the truck with flat black house paint in certain parts, after she had drove it in the ditch and wrecked the front end. Anyways this truck had a drop in plastic bed liner that scuffed the paint off the bed floor to the point that it turned to surface rust. Not rust through, but just surface rust. Not that I cared, I drove that damn truck for 4 years and put 20k miles on it, it was a great beater. Sold it for $1000.
    My 2nd truck, a 2011 Tundra had a plastic bedliner from day one, didn't know if it was a factory or dealer option, I took it out last month only to reveal a bunch of scuff marks where it took the paint down to the bare metal. I've "touched up" those parts of the bed where it looks like it rubbed thru to metal. I guarantee that bed would look nicer if it just had a $90 rubber mat on the floor in there vs that stupid plastic bed liner.
    Plastic bed liners suck ass and are total bullshit IMO.
    Pells18 and Black Wolf like this.
  26. Aug 8, 2018 at 11:29 PM
    Scottd818
    Scottd818 New Member
    2018 Quicksand Tundra Limited TRD 4x4
    Go with the spray on either rhino or linex. Both have lifetime warranties. They will last forever. And make ur bed stronger.
  27. Aug 8, 2018 at 11:45 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Spray in liners increase value.
  28. Aug 9, 2018 at 5:45 AM
    nodak67
    nodak67 New Member
    JR
    look at the price differential between a liner and a basic spray in.
    my line-x basic cost $498 after taxes out the door.
    drop in liner usually cost between 300-400 and a basic mat is around 160-200.
  29. Aug 9, 2018 at 5:54 AM
    hogpiolet
    hogpiolet New Member
    Jimmie
    2018 tundra Platnium
    none
    I have always had spray in liners and loved them I also have a bed mat which keeps things from sliding and you can remove it and wash it off that will keep dents from the bed
    RoscoePico and NewImprovedRon like this.
  30. Aug 9, 2018 at 7:04 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    I would recommend a spray in liner. I had a insert for about 3 years and didnt like it after about a year. I used to live in the desert and mine would warp when really hot outside and it would go back to normal when it cooled down and the smell of hot plastic got annoying. I eneded up moving back to New York and the scratches it left behind the salt got to some and starting the corrosion process. I had mine sprayed a few days ago and looks amazing and would never get a drop in liner again. I paid about 586 w/tax for the premium.
