Bed lights
Discussion in 'Lighting' started by Xtaco16, Jun 13, 2019.
  1. Jun 13, 2019 at 3:35 PM
    Xtaco16
    Xtaco16 [OP] New Member
    2018 Tundra TRD sport
    Getting line x on my truck bed next week but I have yet to install the bed lights. Should they be installed before or after?
  2. Jun 13, 2019 at 3:44 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    After
    KnuckleHD likes this.
  3. Jun 13, 2019 at 3:49 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Yep, what he said. I’m guessing you are referring to the SE Toyota ones. I had my bed sprayed first, then drilled the holes and painted them to prevent rust prior to installing the lights.
  4. Jun 13, 2019 at 3:50 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Definitely after
  5. Jun 13, 2019 at 3:59 PM
    Xtaco16
    Thanks yes they are the ones from Toyota xmas gift that still isn't installed. I havent read the directions I knew someone could give me a suggestion. I will install after the line x.
  6. Jun 13, 2019 at 4:26 PM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    After but I drilled out the holes and told my installer what they were for and he plugged them. Figured it was easier to locate and drill out first.
  7. Jun 13, 2019 at 4:28 PM
  8. Oct 6, 2019 at 4:59 PM
    Burdturger
    Burdturger New Member
    I'm looking into adding oem bed lights as well. Already have the bed lined. So someone in here mentioned rust prevention after drilling. Can someone elaborate on how to prevent rust during the install?
    NewImprovedRon likes this.
  9. Oct 10, 2019 at 8:22 AM
    KnuckleHD
    I used some flat black rustoleum to paint the raw edges after drilling the holes. Once dried, I ran the wires through the holes and added silicone around it to keep moisture out.
    panicman likes this.
  10. Oct 10, 2019 at 8:49 AM
    How bright are the OEM bed lights? I haven't seen any of them.
  11. Oct 11, 2019 at 8:21 AM
    KnuckleHD
    To be honest, they aren’t the brightest. They work fine for my needs but they can’t compare to a full strip of LEDs. I have a tonneau cover and the lights allow me to see what I need. One downside is that if you have anything in the corner (near tailgate) of your bed, it basically blocks the light output all together from that light. I got mine for cheap and did the install myself so I’m still happy overall. If I had to do it again I might spend a little bit more and go with a full LED strip.
  12. Oct 12, 2019 at 4:16 AM
    Burdturger
    The full strip just doesn't look clean imo. There is a popular choice on the forums here but that toggle on off switch looks so cheesy. I'm not electrical savvy enough to figure out a better solution but if there was a kit that had a soft button to mount in the jam of the tailgate so it would trigger itself, that would be more ideal and more oem looking
  13. Oct 12, 2019 at 4:54 AM
    biebs96
    PA
    BravoDeltaRomeo likes this.
  14. Oct 13, 2019 at 4:52 AM
    Burdturger
    Anyone have the auer bed light kit? Seems to check all the boxes for me: no drilling, uses factory switch, durable wiring, mostly hidden. Would love to see installed pics
  15. Oct 13, 2019 at 6:24 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Got these from Headlight Revolution. Had to drill and run wires to cargo light circuit, but easy to do and I like the results. They turn on when I open the door:
    Have the same lights on my rock rail steps:
    paradizecityz likes this.
  16. Oct 13, 2019 at 7:10 AM
    Burdturger
    Is that the auer kit that they sell? I guess I missed the drilling part in the instructions
  17. Oct 13, 2019 at 9:27 AM
    biebs96
    PA
    Any details on which wire you pulled power from. I’d like to be able to control them with the cargo switch as well.
  18. Oct 13, 2019 at 5:04 PM
    Kerch71
    Mechanicsville VA
    No, these are just 6" LEDs that you can mount, but you have to run your own wire. I had puddle lights already wired to the cargo light circuit. I replaced these, then spliced and ran wiring to the bed for the bed lights.
  19. Oct 13, 2019 at 5:07 PM
    biebs96
    PA
    Can you provide information on what wire please
  20. Oct 13, 2019 at 5:17 PM
    Kerch71
    Mechanicsville VA
    I'm not sure which color wire it would be on a 2017, I think it's light grey but don't quote me. @NewImprovedRon knows the wiring really well. Might want to PM him, or maybe someone else will chime in. Pretty sure the wire is in the bundle under the passenger side vinyl door sill cover.
  21. Oct 13, 2019 at 5:22 PM
    biebs96
    PA
    Sounds good, I started poking around. I believe the cargo light wire is on the driver side from previous reading.
    But maybe @NewImprovedRon will clarify for us.
  22. Oct 13, 2019 at 5:32 PM
    Kerch71
    Mechanicsville VA
  23. Oct 13, 2019 at 5:36 PM
    biebs96
    PA
    Oh that’s good. Thank you.
    Getting lights and wire for my birthday from the wife. So can’t wait to finalize the install
  24. Oct 13, 2019 at 5:47 PM
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
