Bed Extender question for 1st Gen 2001 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by meanieme, Apr 12, 2020.
  1. Apr 12, 2020 at 8:05 AM
    meanieme
    meanieme [OP] New Member
    I want to install a Bed Extender and read through all the online posts and still a little confused which ones works with my 1st Gen 2001 Tundra.
    1) AMP Research brand says 74811 Bed Extender with 74605 Mounting Brackets.
    2) I've also seen OEM Toyota different kinds PT392-34000 (with PT329-34070-BR bracket) or PT392-34100 (with PT329-34101 mount).
    Which kind is the U (not V) shape bed extender?
    Which kind is the drill-less mounts? I think the AMP I have to drill but not Toyota OEM.
    Also, are the bed extenders and mounting brackets interchangeable? For example, can I buy Toyota drill-less mounts to use with AMP bed extender?
    Can I buy any brand bed extender?
    Again, I am asking for 1st Gen Tundra, I've seen a lot of posts for future Gen Tundras.
    Thanks!
  2. Apr 12, 2020 at 12:01 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I have the oem Toyota one in my Tacoma. It’s a u shape. It’s adjustable to fit the tundra too. I believe the mounts for the tundra are just like the Tacoma and go between the bed and rope hooks
  3. Apr 12, 2020 at 12:17 PM
    meanieme
    Do you mind sharing the Part Number for both mounts and bed extender if you have? And also photos would really appreciate it!
  4. Apr 12, 2020 at 12:18 PM
    empty_lord
    05 rollover special
    I’ll hunt it down. The trucks not here and the extender is with it. I’ll try and run tomorrow
  5. Apr 13, 2020 at 10:26 PM
    3.4Tundra
    3.4Tundra New Member
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    So are you saying the 1st Gen Tacoma extender will adjust wider to fit the 1st Gen Tundra?
  6. Apr 13, 2020 at 10:27 PM
    empty_lord
    05 rollover special
    Supposedly it does. I have yet to try it
  7. Apr 20, 2020 at 9:35 PM
    meanieme
    What do people use bed extenders for? Contemplating if I should get one.
  8. Apr 20, 2020 at 9:44 PM
    empty_lord
    05 rollover special
    Anything longer than the bed. More useful on my taco vs my tundra. But you can also use it to seperate things at the back of the bed from the rear
  9. Apr 21, 2020 at 9:28 AM
    3.4Tundra
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    Very useful If you buy any building materials for projects around the house, lumber, doors, etc.
    Also, useful for any camping trip I've ever done.
  10. Apr 22, 2020 at 11:42 AM
    3.4Tundra
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    I just scored this one for $140, not a scratch on it.
    This one is expandable, the vertical supports in the center unscrew (clamshell style) and you can widen the bars, then reclamp the supports.
    These newer AMP research ones look and feel like high quality parts.
    This one is part# 74811-01A
  11. Apr 22, 2020 at 12:09 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I actually gave mine away last September. I will say that had I not added my topper I would have kept it. It was handy as a tie down mechanism. I kept things from moving around because I could run a bungee cord from the existing tie down location to anywhere on this extender. Mine must have been OEM as it had brackets that didn't require any additional drilling.
    3.4Tundra likes this.
  12. Apr 22, 2020 at 12:38 PM
    3.4Tundra
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    I saw your post while researching...I totally missed out!!
    I had an extender on my 02 and have been annoyed not having it on my 06. That's too bad that it interfered with your topper, no way to have modified it?
  13. Apr 22, 2020 at 1:49 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The issue is that when moving the extender back and forth it would wack the window strut for my back glass. I could force it, but it wasn't great for it. The other issue is that I couldn't load my dogs back there with it in place. I do miss it sometimes.
  14. Apr 23, 2020 at 1:31 PM
    meanieme
    but doesn't the gaps cause things to slip through them and fall off the back of the truck like lumber and doors? that's why i've wondered why they aren't fully enclosed
  15. Apr 23, 2020 at 1:33 PM
    meanieme
    so the one for the newer tacomas fit the 1st gen tundras?
  16. Apr 24, 2020 at 9:31 AM
    3.4Tundra
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    Never have had that happen. Lumber mostly stays put from what I've experienced. If it's lighter weight wood like fence boards, I use a cam strap to cinch the boards together as well.
    When it comes to the AMP model that I posted above, it does fit Tacoma and 1st Gen Tundra
  17. Apr 24, 2020 at 9:35 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Not if you tie it down. I would never rely solely on the bed extender.
    bokch0y and 3.4Tundra like this.
  18. May 4, 2020 at 11:48 PM
    Limu
    Limu New Member
    Alan
    2001 Tundra white
    Donahue coilovers front, Fox rears. Deaver 10 leaf pack
    I used to have the Toyota one. I used to pack too much stuff so would fold the extender down. Lost it on a trail near Big Bear. It doesn’t do well off-road with a lot of bouncing and jarring. With the cloud if dust and the noise of all the gea4 banging around I never noticed till I stopped. Went back and never found it
  19. May 7, 2020 at 9:26 PM
    meanieme
    I finally bought a used bed extender, now looking for the no drill brackets that screw into the tie down anchors. Are PT329-34070-BR the right no drill brackets that I need? Do they work with 1st gen Tundras? I'm confused because same P/N looks different at Sparks vs Amazon. Also I can't tell from the Sparks photo if it wraps around so that it can bolt to the tie down anchors.
    Sparks PT329-34070-BR
    https://www.sparksparts.com/oem-parts/toyota-tundra-bracket-kit-pt32934070br?origin=pla
    Amazon PT329-34070-BR
    https://www.amazon.com/Toyota-Genuine-Accessories-PT329-34070-BR-Retainer/dp/B00DWVNDG2
  20. May 7, 2020 at 9:39 PM
    empty_lord
    05 rollover special
    Shit I’m so sorry I forgot to post on here with my bed extender.
    oem Toyota
    this is the bracket kit
    Paladin, bokch0y and FrenchToasty like this.
  21. May 7, 2020 at 9:40 PM
    empty_lord
    05 rollover special
    the Extender is for a first gen Tacoma and the hardware kit sandwiches between the rope hook and the bed. No drill and all fits great.
    Even works with my cap
  22. May 8, 2020 at 5:04 AM
    meanieme
    empty_lord likes this.
  23. May 8, 2020 at 8:43 AM
    empty_lord
    05 rollover special
    This is for the reg/access cab.
    double cab is different if that’s what you have
  24. May 8, 2020 at 8:56 AM
    meanieme
    Interesting! I have the access cab. Placed an order for the bracket already based on your P/N. Thanks again have a great weekend.
  25. May 10, 2020 at 9:19 PM
    meanieme
    Thanks to empty_lord, I bought the right no drill brackets for the 1st gen Tundra.
    On the other hand, seems I bought the wrong bed extender, this one is actually for 2nd/3rd gen Tundra I believe.
    For small objects, this leaves me a gap that things can fall out from.
    On the plus side, for larger objects, it gains an additional 3-4 inches.
  26. May 10, 2020 at 11:49 PM
    empty_lord
    05 rollover special
    Seems like it fits pretty good other then the length. You could fabricate a filler plate or something.
  27. May 21, 2020 at 5:49 PM
    Twisted99
    Twisted99 New Member
    2018 Crewmax Platinum 4x4
    None, yet
    If anyone has a factory extender, or just the factory brackets for the double cab can you post a pic please?
    I want an extender in my 06 DC
    I have the extender and OE brackets from my 01 Tacoma, and I can modify the brackets to fit if I have to.
    The extender itself seems like it's not tall enough.
    I'll post some pics over the weekend
  28. May 21, 2020 at 5:56 PM
    Twisted99
    None, yet
    I had the same problem on my 01 tacoma when I put a cap/camper/topper on it.
    I modified the extender "pegs" that go in the brackets. Worked great. I used it for 3 or 4 years before I sold the truck. I have the extender still. I'll post a pic of the modified peg. In case you want to give it a try.
  29. May 23, 2020 at 5:17 PM
    Twisted99
    None, yet
    This is the extender from my 2001 Taco. Don't know if the its OE
    Brackets are OE for the 01 Taco, but I think they are same as 1st gen Tundra reg cab and access cab
  30. May 23, 2020 at 5:21 PM
    Twisted99
    None, yet
    OE brackets.
    Height of Taco extender not as high as the bed
