Bed Electrical Power
Discussion in 'General Tundra Discussion' started by Alex261, Nov 4, 2023.
  1. Nov 4, 2023 at 8:34 AM
    Alex261
    Alex261 [OP] New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Trying to figure out how the power works in the bed. I know it doesn’t pump out a lot of power but I was trying to charge a leaf blower battery pack on my way to work. When I looked down at the switch it wasn’t lit up when I was driving. I’d press it, it would light up, and then go out. When I was parked with truck running, I’d press it and it would stay on. Does that plug only work in park or am I possibly drawing too much juice from that charger pack? Also I didn’t know if the plug inside the truck worked the same way. Does the plug work inside the truck while the truck is in motion.
  2. Nov 4, 2023 at 10:07 AM
    Alex261
    Alex
    Boston, Ma
    Ok so I just learned that none of the electrical plugs work when the truck is in drive. That doesn’t make sense. Maybe the bed one can be justified but what’s the point of the one in the cab. You can’t charge a laptop or something for the kids while your driving? That’s BS
  3. Nov 4, 2023 at 12:13 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Sorry, I got nuthin'...
  4. Nov 4, 2023 at 1:09 PM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    With engine running in park you can draw 400 watts and in drive it’s limited to 100 watts.
  5. Nov 4, 2023 at 6:03 PM
    Alex261
    Alex
    Boston, Ma
    Ok well that’s good to know. So I assume a laptop or something like that is under 100 watts?
