Bed Drain?
Discussion in '3rd Gen Tundras (2022+)' started by WasAChevy, Jan 2, 2022.
  1. Jan 2, 2022 at 3:22 PM
    WasAChevy
    WasAChevy [OP] New Member
    Does the composite bed have a drain hole(s)?
  2. Jan 2, 2022 at 6:57 PM
    BlacknWhite23
    BlacknWhite23 New Member
    2021 Black TRD Off Road
    The Tacoma did. FWIW
    WasAChevy[OP] and Mattedfred like this.
  3. Jan 2, 2022 at 7:35 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    If it doesn’t it’s easily remedied with no risk of corrosion. All you need is a handy-dandy drill and nice sharp drill bit! Drain hole(s) achieved!
    WasAChevy[QUOTED][OP] likes this.
  4. Jan 3, 2022 at 6:05 AM
    OppoMojo
    OppoMojo New Member
    Yes Sir! No need to sharpen drill bits on a Toyota. Just sit back and enjoy the ride.
  5. Jan 3, 2022 at 10:05 AM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Can confirm, just like the composite bed in the Taco, that the Tundra has drain holes up front near the cab.
  6. Mar 9, 2022 at 3:21 PM
    WasAChevy
    Has holes, smalll holes. Nothing a 1/2" bit can't fix.
  7. Mar 9, 2022 at 7:03 PM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    There are 4 of them at the forward end (towards the cab).
    Small but drillable if you need them bigger.
    If you install the OEM Tonneau cover it does utilize 2 of those holes for its drain tubes but the holes are there.
  8. Mar 9, 2023 at 7:56 AM
    smkmsqt_23
    smkmsqt_23 New Member
    I bought a synetic USA cover and it has 4 big drain hoses. I am not sure where to drill...anyone has a picture of where they drilled. Ultimately, I am trying to just drill the liner and not the metal of the bed...is that even possible? if not, I may look for drain tube reducer to make it fit the tiny factory holes.
  9. Mar 9, 2023 at 10:36 AM
    urmomspad
    urmomspad New Member
    SoCali
    23 Tundra TRD OR
    I installed a Retrax cover which requires 2 drain holes. They are located in the corners of the bed closest to the cab. I drilled the holes out to 5/8” to accommodate the drain tubes. I drilled from the underside of the bed liner. You do not need to go through the actual metal bed, just the liner.
    Also, I’m impatient and went straight to a 5/8 bit. I would definitely start smaller and work your way up.
    gmotoring likes this.
  10. Mar 9, 2023 at 10:52 AM
    smkmsqt_23
    I’ll crawl under there and see! Appreciate the quick reply!
