Bed Divider You Recommend?
Discussion in '2.5 Gen Tundras (2014-2021)' started by EIRE1916, Nov 17, 2018.
  1. Nov 23, 2020 at 5:59 PM
    :thumbsup:
  2. Dec 4, 2020 at 4:24 PM
    AlexJet
    AlexJet New Member
    2021 TRD Offroad CrewMax
    Interesting solution, but I have a concern. When I looked at my bed (CrewMax), I found only 1 potential slider location for 2×8, located about 6-8" behind of the wheel wells. Unfortunately it only leaves 18 sharp between 2×8 and the tailgate. I measured my bags and they are roughly 22" long which makes it 4" shorter. I wish there were more options to slide the 2×8.
    P.S. did Toyota specifically made the slides for 2×8 or is it just convenient to be used in such application? I see some other pickups has several vertical ribs on the bed sides which may or may not give more options...
    Rica25 likes this.
  3. Dec 5, 2020 at 8:24 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Thanks for the help Jim and @NewImprovedRon. I've wanted one of these for a loooooong time. At $200 cad ($150usd), I couldn't resist. Turns out it was the real deal.
    Looks, feels and works great. Now to rig up a lock for it so it doesn't get swiped.
  4. Dec 6, 2020 at 5:49 AM
    :hattip:
  5. Dec 6, 2020 at 6:19 AM
    biebs96
    PA
    maybe..
    https://www.boltlock.com/locks
  6. Dec 6, 2020 at 6:37 AM
    biebs96
    PA
    Use the cable lock and go through one of the factory bed tie downs
    BravoDeltaRomeo likes this.
  7. Dec 6, 2020 at 6:47 AM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    I may not be getting creative enough with my Google searches. This part # showing up on Ebay in the $305-$350 range. Does that sound right? Just seems like a lot for a static piece.
  8. Dec 6, 2020 at 8:11 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Yeah, it's going to be tough to get it fully locked down.
    I was thinking even a cable lock that loops through the mesh grate and the other end on the bed tie down. All it would take is a screwdriver or bolt cutters for a real thief, but it would stop kids from stealing for no reason than they want to be pricks.
    A thicker cable with a crimp mechanism to create loops at each end (no lock) would even help opportunists downtown from stealing it for scrap metal. Similar to the brake safety cable on a trailer.
    TelemarkTumalo likes this.
  9. Dec 6, 2020 at 9:20 AM
    Matt / PA
    Matt / PA New Member
    2017 SR5 Double Cab, Rocky Ridge K2
    They always have a 20% off coupon online and even a 25% right now for this weekend.
    I have 2 of these. They work awesome.
    Boerseun likes this.
  10. Dec 6, 2020 at 2:33 PM
    AlexJet
    AlexJet New Member
    Yes, $507 in Canada from dealership installed.
    I sourced one used this morning for 200. Had to drive 100km to get it and then 100 back, but I think its worth. It
  11. Dec 6, 2020 at 3:49 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    AdamK and TelemarkTumalo like this.
  12. Dec 6, 2020 at 4:32 PM
    AlexJet
    AlexJet New Member
    I was looking for that option, and I actually talked to the Tundra owner this morning and checked out his bedextender. Its not bad for small items, but I won't be able to use it if I need to put a couple of bags and a cooler even for a small picnic. It's just not deep enough...
  13. Jan 14, 2021 at 10:34 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I have a backflip cover and it drops the factory rails down the bedside in order to fit the covers rail. How much room does the Toyota bed divider have below it between the divider and the bed? Wondering if it would still fit with my lowered tie down rails.
  14. Jan 15, 2021 at 7:22 AM
    AlexJet
    AlexJet New Member
    OEM Bed Devider leaves several inches between the bed itself and the divider. Its very convenient if you have something attached to the sides or have mats, etc on the floor. It stilaalows to slide something underneath of the divider, like 2x4 or 2x6 flat down, but its main reason to divide the bed for big cargo items and its steel, so it withstand anything you through in the bed, I think it can even secure 200 gallon barrel if needed from sliding or rolling. I'm happy with mine.
  15. Jan 16, 2021 at 8:40 AM
    Tundyfundy
    Bay Area, CA
    I hear you. My issue is not the cover closing it’s the fact that my bed rail system is now lower on the bedside due to the cover which reduces the clearance under the bed divider. (The bed rails are relocated about 3 inches lower than factory location. Can sombidy measure under the bed divider? I’d like to know if the bed rails being lower still allow the divider to be installed or if it won’t fit because it’s too tall.
  16. Jan 16, 2021 at 9:16 AM
    AlexJet
    AlexJet New Member
    OEM Bed Devider has 2-3/4" from the bed floor to the divider. But if you turn the brackets with know down, you'd probably gain another 1/4". Also the bolt has some room and if you add a few washers under the bolt then you can raise divider a bit more if needed.
    I have Leer Cap installed and my rails are in stock position with no issues and all bed cleats can easily be slider at any position.
  17. Jan 16, 2021 at 11:52 AM
    Tundyfundy
    Bay Area, CA
    Thank you sir! I’ll go measure the drop in my rails. I’d love to add the bed divider so hoping it works!
  18. Jan 17, 2021 at 7:56 AM
    AlexJet
    AlexJet New Member
    As I mentioned my divider slides from the bottom to lower it, but if you revert the brackets upside down, it will be higher due to thickness of bracket wall plus you can regulate the height by adding washers as spacers on the bolt. If you slide it from the top then nothing stops to make it higher.
    Tundyfundy[QUOTED] likes this.
  19. Jan 17, 2021 at 9:07 AM
    #49
    TelemarkTumalo
    Mark
    Bend, OR
    Curiously following this thread. I'm trying to imagine what you are describing here. Are you saying you can flip the brackets and adjust how high the divider rides above the bed floor? How much difference does that make?
    Tundyfundy likes this.
  20. Jan 17, 2021 at 9:50 AM
    #50
    AlexJet
    AlexJet New Member
    Yes, the square bracket can be installed with slot on the bottom (as I have, see picture above) to slide the bed divider from the bottom, or you can flip the bracket 180 degree (slide it upside down into the rail, so hand-screw will be located from the bottom) with slot on the top to slide the divider from the top down. In the second case there is nothing prevents you to add washers or spacers to the bolt and adjust the height up. In my case I have the divider to slide from the bottom and this way I'm having it closer to the bed floor.
    Brackets are universal and can be installed on either Left or Right rail, either with U-shape "holder" facing up or down. When you have the opening on the top its easier to install/remove the divider as you lift it up to remove or slide in to install, but having the opening on the bottom allows to install it 1/4-1/2" lower to the floor. Its up to you how you want to mount it.
  21. Jan 17, 2021 at 10:07 AM
    #51
    TelemarkTumalo
    Mark
    Bend, OR
    Ah.... thanks for the explanation and pics. I found a divider on eBay that I'm going to order. Appreciate the information from this group.
    #51
  22. Jan 17, 2021 at 8:22 PM
    #52
    Tundyfundy
    Bay Area, CA
    Thanks a million. I think I’m going to order it! I totally get what your saying now.
  23. Feb 6, 2021 at 2:57 PM
    #53
    PermaFrost
    PermaFrost New Member
    Washington
    2017 CM MGM SR5 TRD
    Should have just bought the Platinum!
    ... just stumbled upon this gem. Totally doing this. Thanks @JoshuaA !
    JoshuaA[QUOTED] likes this.
  24. Feb 6, 2021 at 3:07 PM
    #54
    BravoDeltaRomeo
    Bruce
    MB Canada
    I tried a DIY 2x4 version on mine...it didn't hold tight enough for that I wanted it to do.
    It's worth a shot though and you can always use it for firewood of it doesn't turn out
  25. Feb 6, 2021 at 3:15 PM
    #55
    PermaFrost
    Washington
    2017 CM MGM SR5 TRD
    Exactly.... minimal commitment! :)
  26. Feb 6, 2021 at 3:16 PM
    #56
    BravoDeltaRomeo
    Bruce
    MB Canada
    Yup. It was a fun project for the kid and I, and only set us back about $15 cad.
    If you Google DIY Bed Divider, you'll see others that have made metal and adjustable ones for the Tacoma too
  27. Feb 6, 2021 at 3:25 PM
    #57
    PermaFrost
    Washington
    2017 CM MGM SR5 TRD
    Yes. Exactly what I was thinking - kiddo/dad project....to make mom happy that her groceries aren't sliding all around the truck bed!
