Bed Divider You Recommend?
Discussion in '2.5 Gen Tundras (2014-2021)' started by EIRE1916, Nov 17, 2018.
  1. Nov 17, 2018 at 6:34 AM
    EIRE1916
    EIRE1916 [OP] New Member
    Hi
    So I have a 2018 Platinum Tundra, it has the Line-X bedliner with the adjustable rails on the side.
    I’m looking for something like a bed divider, that can be adjusted along the railings with quick connects, to put things in so they are not sliding all over the rear of the truck bed
    Any recommendations on a good quality one?
    Thanks in advance
    TelemarkTumalo and Bigboitundra like this.
  2. Nov 17, 2018 at 6:51 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  3. Nov 17, 2018 at 8:48 AM
    EIRE1916
    Only thing I don’t like about that one is it looks like it has a gap that things could pass through and then bounce around in behind the divider
  4. Nov 17, 2018 at 8:03 PM
    EIRE1916
    Where did you buy these from? Do you happen to have the part number?
    Thanks!!!
  5. Nov 18, 2018 at 9:02 AM
    EIRE1916
    The problem is the OEM one from Toyota says it will NOT work with tonneau covers, I have a Line-X liner and Toyota bed cover, and the Toyota bed rail system.
    So I don’t know if it’ll definitely fit???
  6. Nov 18, 2018 at 9:30 AM
    EIRE1916
    Thanks man could be worth a try
    NewImprovedRon likes this.
  7. Nov 18, 2018 at 9:52 AM
    Mine works fine. I have the factory spray in bed liner, factory rubber mat, deck rail system and a Gator tonneau cover. All good.
  8. Nov 18, 2018 at 12:43 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Cheapo here, 8x2" lumber stained black slides into the groove, 4x4 spacer, under tonneau.
  9. Nov 18, 2018 at 2:33 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Brilliant! Perfect for the back and buy a cheap bed bar from Amazon for the front of the bed and I am in business. Thanks for sharing.
  10. Nov 18, 2018 at 2:50 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    I got a wing nut to replace the big knob and it work is the 17 CM and Lomax.
  11. Nov 18, 2018 at 2:52 PM
    4Runner
    4Runner New Member
    Columbia, SC
    This! Damn. I want this. Would you mind sharing the width of each? Thanks for posting.
  12. Nov 18, 2018 at 4:02 PM
    Yota-Man
    Yota-Man New Member
    2016 White TRD PRO Double Cab
    JoshuaA . You beat me to it.
  13. Nov 18, 2018 at 5:51 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I think it's 66" across, you can double check based on the type of liner you have. Mine's a 8x2 so I can still take it in and out while my DiamondBack is closed, you could easily fit a 10x2 or 12x2 for increased height. A fastened perpendicular 18.5" 4x4 fits right in the groove nicely and keeps the long board from moving, it's a pretty cheap mod, coat with Behr or whatever solid wood stain and sealer, you only need the small 7oz can.
    For lighting, I'm using this motion sensor LED, I keep it turned OFF so I don't have to recharge it often.
    Deebo likes this.
  14. Dec 12, 2018 at 3:29 PM
    mgxsequioa
    mgxsequioa New Member
    Are you using the magnet to adhere this to your Diamondback or another method? Still happy with the product? I'm all over the place with my bed lighting options and this may be the right answer as either a permanent solution or until I decide what I want.
  15. Dec 12, 2018 at 4:50 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    It comes with a magnetic strip but the tape wore off and stopped sticking to the db lid so I pealed and cleaned off all the tape residue, I then applied better 3M double-sided tape which has been solid.
    I maybe charge the bar every 2 months. Just pulled it off because you reminded me lol.
    mgxsequioa[QUOTED] likes this.
  16. Dec 12, 2018 at 6:03 PM
    mgxsequioa
    Thank you!
  17. Dec 28, 2018 at 8:31 PM
    BlueBruteSR5
    BlueBruteSR5 New Member
    2019 SR5 Cavalry Blue
    I used a 2x10 cut to 66 inches. Primed it. Black Plasti Coat and some flat black spray. Just gotta get my Renegade cover on it. I'll post a pic when I get it all together.
    JPritch likes this.
  18. Dec 28, 2018 at 8:36 PM
    Highly recommend for sanity, no matter what year.
  19. Dec 28, 2018 at 8:56 PM
    flying dave
    flying dave New Member
    NC
    ^^^Lol. In my house we talk politics. Works every time...
    On topic the 2x8 is a great and simple idea. I like how the cooler fits right in that space like it was meant for it.
    TelemarkTumalo and ColoradoTJ like this.
  20. Dec 28, 2018 at 9:08 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    :laughing::rofl::laugh:
    Rica25 and ColoradoTJ[QUOTED] like this.
  21. Dec 28, 2018 at 9:14 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Yeah but doesn't help with snoring. My wife snores like a damn grizzly bear!
  22. Dec 28, 2018 at 9:21 PM
    That’s what separate rooms are for. I haven’t slept next to my wife in 16 years. Lol
  23. Dec 28, 2018 at 9:22 PM
    Tacogrande
    Jeremy
    She usually ends up on the couch after I start kicking her! I need to sleep in peace and quiet. Lol
  24. Dec 28, 2018 at 9:51 PM
    Rica25
    Ricardo
    Tulare
    I've had the same 2x10 on mine for 10 yrs now also painted black
    JPritch likes this.
  25. Jul 4, 2019 at 11:23 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    awesome!!! going out now to measure my 75qt grizzly cooler!!! thanks
  26. Jul 4, 2019 at 1:45 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
  27. Nov 23, 2020 at 5:48 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    A quick question....did anything change in terms of fitment for the bed divider over the years?
    This one has come up, but it looks more squarish and not slopped on the sides to clear the wheel wells
  28. Nov 23, 2020 at 5:50 PM
    EIRE1916
    Mine def has the tapering over the wheel wells. I still had to modify it because I have a bed liner
    BravoDeltaRomeo likes this.
  29. Nov 23, 2020 at 5:52 PM
    That's the one I have in my 2018, it clears the wheel wells.
  30. Nov 23, 2020 at 5:58 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Thanks!
    I am trying to buy one on Kijiji, shipped, so am just confirming it doesn't look wonky. I was lining up where the angles start on the sides and it looks legit, I think it's camera angles
    Price is right and he's willing to ship. I've wanted one since I bought the truck, but dealer price is crazy and I have never seen one come up locally.
