Bed cut sound system Tundra CM
Discussion in 'Audio & Video' started by lowenvy, Oct 9, 2018.
  1. Oct 9, 2018 at 3:51 PM
    lowenvy
    lowenvy [OP] New Member
    Marcus
    2013 MGM Toyota Tundra CM
    4/6 McGaughys drop Racing exhaust AFe intake Bed cut sound system
    Has anyone done a bed cut system on a CM? I’m currently in the process. Just wanted verification as to if I’m one of the first or not. People on my IG are saying that I am. Thoughts? B88A3EB3-E65B-4631-B757-3BDD63483BAD.jpgD11A0F80-95A3-4ECD-85DE-9F11AF183326.jpgB88A3EB3-E65B-4631-B757-3BDD63483BAD.jpgD11A0F80-95A3-4ECD-85DE-9F11AF183326.jpgBDD1BFF3-2DA7-4984-8E04-4440B4A92091.jpg
  2. Oct 9, 2018 at 3:54 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Umm yeah you're definitely the first. You cut a hole in your cab and bed for some subs? You lose the rear window roll down and almost all of the bed space, and a ton of resale. To each their own but this definitely is not for me. Is this a audio show truck?
  3. Oct 9, 2018 at 3:56 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Bad ass!
    What monsters are going in that beast box?
  4. Oct 9, 2018 at 3:59 PM
    lowenvy
    Marcus
    Yes I cut a hole in the cab. The rear-window feature is a nice touch but I never really used it. The truck is paid for and I don’t plan on getting rid of it. It’s my daily.
  5. Oct 9, 2018 at 3:59 PM
    lowenvy
    Marcus
    Thanks!! Two Digital Designs 15” 9900 series subs.
  6. Oct 9, 2018 at 4:00 PM
    Pudge
    CT
    You are one ambitious man. Like I said it's not for me but quite an amazing undertaking.
  7. Oct 9, 2018 at 4:01 PM
    Danimal86
    Daniel
    Sacramento, CA
    Wowza. What amp are you using?
    Better yet, you got a parts list for the build?
    jewsNbrews likes this.
  8. Oct 9, 2018 at 4:02 PM
    lowenvy
    Marcus
    Thanks man! Just trying to be different. Got tired of shallow subs behind the seats. I got kids, so I couldn’t just take them out.
    Darkness and Mountun Goat like this.
  9. Oct 9, 2018 at 4:03 PM
    lowenvy
    Marcus
    Lol, let me finish the build and I will share insight to the spec sheet. I’m going to use a Sound Digital 8800.1 amplifier.
  10. Oct 9, 2018 at 4:04 PM
    Pudge
    CT
    What will you use to line the wood on the box where its exposed to weather? Like between the cab and bed? I assume you'll have a cap or tonneau? Would bedliner work for something like this (wood)? And how about weatherproofing / exhaust fume proofing the holes cut? Rubber seals so you can remove it easily or silicone?
    NewImprovedRon likes this.
  11. Oct 9, 2018 at 4:06 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I have always wanted to do this...but I can't unless I get a second ride. I need my cab and bed to flex and not worry about anything in-between when off roading for fishing and hunting. This is probably a first, or at least the few first to do this. Can't wait to see final project
    lowenvy[OP] and Pudge like this.
  12. Oct 9, 2018 at 4:07 PM
    lowenvy
    Marcus
    The box will be bedlined just as the bed for weather. Between the cab and bed an industrial lining to prevent water from gettin in the cab. I have a tonneau currently. Depending on the sound output, I may go hardtop. It will be fully weatherproof my man and easily removable.
  13. Oct 9, 2018 at 4:08 PM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    Doesn't the bed flex independently of the cab causing the enclosure to move? Anyway, kudos for the ambitious project and looking forward to seeing the completed build.
    NewImprovedRon and lowenvy[OP] like this.
  14. Oct 9, 2018 at 4:08 PM
    lowenvy
    Marcus
    Right on. My truck is lowered. The off-road life is not for me. I’m into the street scene and shows and what not. Fortunately I don’t need my bed. I’m an office junkie lol
  15. Oct 9, 2018 at 4:09 PM
    Pudge
    CT
    Good thought @jewsNbrews about the cab and bed flex
  16. Oct 9, 2018 at 4:09 PM
    lowenvy
    Marcus
    The bed will have some flex which is why the hole itself was cut slightly larger than the sub box port. The lining will seal around said port.
  17. Oct 9, 2018 at 4:24 PM
    .manny.
    .manny. New Member
    Manny
    2018 Cement Tundra SR5 Crewmax
    ayyyyyyy! Have you seen Soundman's build on Youtube? He did in on an F-150.
    jewsNbrews and lowenvy[OP] like this.
  18. Oct 9, 2018 at 4:29 PM
    lowenvy
    Marcus
    Yeah I’ve seen that video. He used two large PVC pipes for ports right? His videos are hilarious!!! My best friend showed me that video and it inspired this build.
    .manny.[QUOTED] and jewsNbrews like this.
  19. Oct 9, 2018 at 4:31 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I have seen the boxes getting ported in 2 the cab with tubes or pipes but not the whole actual box. Thing is going to be a beast that’s for sure! And u want this as ur daily driver ur loco my friend lol
    Coolhardy and lowenvy[OP] like this.
  20. Oct 9, 2018 at 4:32 PM
    lowenvy
    Marcus
    That’s what bass knobs are for lol and my wife would agree I’m a little loco
  21. Oct 9, 2018 at 4:34 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Well good luck with ur project if your in SoCal I would love to hear that thing pounding when ur all finished. Please tell me ur doing a lot of mids and highs and making it a complete system tho right? Not just this super load bass and no voice
    lowenvy[QUOTED][OP] likes this.
  22. Oct 9, 2018 at 4:38 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Just curious why build the box out of plywood vs MDF?
    KB Voodoo likes this.
  23. Oct 9, 2018 at 4:39 PM
    lowenvy
    Marcus
    Thanks bro! I’ve got Quinn’s for mids and highs and they’re crystal clear. 6.5s in the doors and 4” in the dash. If it’s not enough, I’ll add more. My highs would drown out the previous 2-10” JL Audio TW3s I had. Should go well with the new speakers and box. If ever in SoCal I got you! If ever in Texas look me up!
  24. Oct 9, 2018 at 4:40 PM
    lowenvy
    Marcus
    It is MDF my man. Or Birch. My sound shop built the box.
  25. Oct 9, 2018 at 4:51 PM
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
  26. Oct 9, 2018 at 4:54 PM
    lowenvy
    Marcus
    I stand corrected. It’s like Birch. It’s 3/4 sanded ply. MDF is heavy and eventually swells. MDF is like a sponge.
    Boerseun likes this.
  27. Oct 9, 2018 at 5:06 PM
    dragos28
    dragos28 New Member
    dragos
    tundra
    nothing much
    FUCKING EPIC!!!
    i'm bass head so my motto is: "When Too Much Is Just Right!"
    lol
    unfortunately all i have are two 10's in my CM... there's a local bass addict group here locally and they'll have soundoffs in the parking lot of my store.
    fuking hell... one dude has a walled minivan.. that thing shakes my walls...
    lowenvy[OP] likes this.
  28. Oct 9, 2018 at 5:07 PM
    Ericsopa
    Ericsopa Old man and the sea
    Well......hmm.....I've always had this dream of building a ray-gun that could zap the electronics of the dude that pulls up next to me at a stoplight with his subs loud enough to be heard in the next county. :cool:
    That said, good luck with your project.
  29. Oct 9, 2018 at 5:13 PM
    dragos28
    dragos28 New Member
    dragos
    tundra
    nothing much
    That reminds me, back in my college days one of my cars was a Volvo station wagon.. i think it was a 760 or something like that.
    anyhow, had all the windows limo tinted and in the back I had 2 15's and 2 10's
    holy hell was that a wicked setup.. i'd have to shift it into neutral at the stop light and keep the rpm over 2k so the engine wouldnt die from the bass....
    i do remember one time i was just subbing like crazy and i look over and see this old man foaming at the mouth yelling at me. I pause it and he's yelling at me that its too loud and yada yada.. so i just turn it back on and drive away..
    i was a dick...
  30. Oct 9, 2018 at 5:32 PM
    I’ve never seen one on a Tundra, but lots of mini trucks and what not.
    Mostly, they ported into the cab with 4-6” tube.
    Cool to see your final product and how it’s all designed/finished.
