Bed Cover with a Lock that is Waterproof
Discussion in 'Tonneau Covers, Caps and Shells' started by PedroTundra, Feb 12, 2024.
  1. Feb 12, 2024 at 6:34 AM
    PedroTundra
    PedroTundra [OP] New Member
    Good Morning All,
    What is the best suggestion for my 2023 TRD Pro Tundra?
  2. Feb 12, 2024 at 6:48 AM
    Truly waterproof is next to impossible. Closest is likely the least attractive, which is the old style fiberglass hinged by the cab that wraps over the sides of the bed and tailgate. Then you have to seal up the tailgate area gaps. The rest typically use drain tubes to redirect water and rely on proper adjustments to keep a good seal contact to keep water out. They work ok, but are not truly waterproof.
  3. Feb 12, 2024 at 6:57 AM
    DRP
    DRP Old Member
    Dave
    Been happy with the BAK Revolver x4s so far. It lets a little water in at the tailgate but nothing to really worry about for me. There are no drain tubes to worry about either. I would agree with Knabores that none are really waterproof and I don't think any make that claim, at least the roll up or fold up models.
  4. Feb 12, 2024 at 7:47 AM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    Malinois38, WtnTN, 1lowlife and 2 others like this.
  5. Feb 12, 2024 at 7:57 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    I 2nd the Revolver. That said it was not waterproof out of the box. Added a tailgate seal kit which you have to do for any topper. Then some extra horizontal stripping between tailgate edges and the truck at the tip.
    The only water proof cover I have ever had was a one piece one that overhangs all 4 bed sides. But removing those is a PITA and they don't look as good
    Matt2015Tundra likes this.
  6. Feb 12, 2024 at 8:40 AM
    TheCrazyludwig
    TheCrazyludwig New Member
    Diamondback HD is pretty solid.
    Malinois38 likes this.
  7. Feb 12, 2024 at 9:23 AM
    SD Surfer
    Bruce
    So Cal
    Got a link &/or some pics? My MX4 is pretty dry except for the tailgate corners. Is there a seal kit that's better than others?
  8. Feb 12, 2024 at 10:51 AM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
  9. Feb 12, 2024 at 11:01 AM
    Breathing Borla
    AZ
  10. Feb 12, 2024 at 11:37 AM
    SD Surfer
    Bruce
    So Cal
  11. Feb 12, 2024 at 5:19 PM
    tcap23
    tcap23 New Member
    Patrick
    2023 Capstone
    I have the Retrax MX also. Almost no water at tailgate. The only water I see is drained thru the tubes of the roller takeup reel and drain out of the bed thru the drain tubes. I would buy another if this got damaged. Absolutely not the lowest price, but one of the best IMO. Very satisfied. I got it from Real Trucks and the first two that came were damaged from the factory. They paid for the shipping back for return.
    sandiegosteve likes this.
  12. Feb 12, 2024 at 5:22 PM
    sandiegosteve
    San Diego
    DM SantanaRealtruck. He will at least give you a quote. They carry more than the Retrax at RealTruck.
  13. Feb 12, 2024 at 5:26 PM
    Cassidy1866
    Cassidy1866 New Member
    2023 Tundra Limited TRD Off-Road
    I’ve also had a positive experience with my Retrax. Not waterproof but pretty darn good. I’ll also give a nod to the ESI Ultimate Tailgate Seal. Took me a few tries to get it in all the right places but once you crack the code it does a fantastic job of keeping out water (and dust).
  14. Feb 12, 2024 at 5:31 PM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    You only want the lock to be waterproof?
    ArcticEd and 1lowlife like this.
  15. Feb 12, 2024 at 5:32 PM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    2024 SR5 TRD Offroad Lunar Rock
    Diamondback.
    this is the way.
    you will need to weatherstrip the tailgate.
    Malinois38, coldcanuk and WtnTN like this.
  16. Feb 12, 2024 at 5:32 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    One necessity with any cover is a rubber bed mat. Any water that leaks in at any corner goes under the mat and out the front drains or out the back and your load stays dry.
  17. Feb 12, 2024 at 9:03 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2023 Tundra Platinum Hybrid
    Dobinsons IMS 2"/1", BMS 1" Wheel spacers with OEM Platinum Wheels. Icon Sway Bar Spacer. 285/65/20 Firestone Destination XT Tires.
    x2 to this. I didn't weather proof anything, and didn't use the drain tube. All the water drains around the bed mat. Anything on the mat stays relatively dry.
  18. Feb 13, 2024 at 3:53 AM
    Philipl
    Philipl New Member
    Philip
    North Mississippi
    Had my Diamondback HD for a couple of weeks and very happy with it
  19. Feb 13, 2024 at 4:39 PM
    Tho4x4
    Tho4x4 New Member
    2024 Tundra Limited Hybrid OR
    Got a diamondback switchback about a month ago. We got some very heavy rains last week and I got no water in the bed at all.
  20. Feb 14, 2024 at 2:43 PM
    559Tundralona
    559Tundralona New Member
    Alex
    Fresno
    2023 Ice Cap Tundra Limited TRD OR Hybrid
    Diamondback switchback Eibach Pro-Lift Rays Gram Lights 57DR-X 17x8.5 +0 YotaLEDS grille lights Tufskinz overlays
    second that, Diamondback switchback as well and no issues.
  21. Feb 14, 2024 at 8:08 PM
    WtnTN
    WtnTN New Member
    Wyatt
    2024 Platinum Tundra
    Diamond back hd water tight since day one
  22. Feb 15, 2024 at 6:27 AM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    On the bed mat, how grippy are these? I haul a pedal drive fishing kayak in the bed of my truck almost weekly. I have the kayak on a cart and slide it into the bed. Will the mat keep it from sliding in easily?
    Thanks!
  23. Feb 15, 2024 at 7:07 AM
    DRP
    DRP Old Member
    Dave
    I had a rubber mat in my last truck and I would say it won't cause you any issues sliding in the kayak. Less slippery for sure, but not a big problem. I plan on getting one for the latest truck as that composite bed is like a skating rink...
    Dfrink[QUOTED] likes this.
  24. Feb 15, 2024 at 8:07 AM
    PNW Tundra Mike
    Back in So Cal
    It definately has grip when clean. Sliding a heavy cardboard box or lumber on it can be tough. Wouldn’t trust it to keep anything from slipping out with the gate down. Always tie down anything.
    Dfrink likes this.
  25. Feb 17, 2024 at 5:22 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
  26. Feb 17, 2024 at 5:47 PM
    Breathing Borla
    AZ
    ya I’ll try, it’s kinda complicated to get it dust and water tight but I did do it .
    I think I counted and have done 9 tonneau covers lol
  27. Feb 17, 2024 at 10:22 PM
    Malinois38
    Malinois38 New Member
    Pa.
    2022 Platinum Hybrid WCP
    Once you go Diamondback, you never go back…
  28. Aug 26, 2025 at 6:56 AM
    Gunslinger-13
    Gunslinger-13 New Member
    Tom
    2025 Limited
    Diamondback HD with a tailgate seal kit FTW.
  29. Aug 27, 2025 at 6:02 AM
    HerdManager
    HerdManager New Member
    Stephen
    2023 Limited Hybrid Crewmax
    Can't understand why anyone would buy a cover that doesn't give you full access to your truck bed? Diamondback looks like a great product but every model seriously restricts your access to the bed.
  30. Aug 27, 2025 at 6:10 AM
    Not everyone has the same needs
