Bed cover recommendation
Discussion in '3rd Gen Tundras (2022+)' started by Lawnmower, Jun 5, 2023.
  1. Jun 5, 2023 at 8:24 AM
    Lawnmower
    Lawnmower [OP] New Member
    I just bought a 23 Tundra and I need to buy a fold back or roll back bed cover that doesn't leak. I'd prefer to stay below $1,000.00, do you have any suggestions?
    Raging Iron Thunder and Tmymac like this.
  2. Jun 5, 2023 at 8:32 AM
    Tb2
    Tb2 New Member
    James
    Backflip
    Lawnmower[OP] likes this.
  3. Jun 5, 2023 at 8:44 AM
    Hella Krusty
    Hella Krusty New Member
    I had a Roll n Lock on my last Tundra. Never ever would I buy one again. Rattled, leaked, periodically would just roll open, freeze shut. Thing was garbage. I would go tri-fold, probably Backflip considering OEM are under a recall right now
  4. Jun 5, 2023 at 8:49 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    They will all somewhat leak but if you get the full cap it wont leak at all. Those just look Ol skool. I have the Peragon and it leaks a lil bit, just not sure if they make it for your year. Good luck.
    SWB Tundra and Lawnmower[OP] like this.
  5. Jun 5, 2023 at 9:15 AM
    Tb2
    Tb2 New Member
    James
    I like the back flip because it enable full use of bed
    Hugh_Jaynus and Lawnmower[OP] like this.
  6. Jun 5, 2023 at 9:29 AM
    BluePete
    BluePete New Member
    Utah
    2023 SR5 TRD Off-Road Blueprint
    I just got my truck last week and installed the Bakflip MX4 the same day. Very happy with it so far. If I didn't get the Bakflip, I think I would have gotten the Peragon. I like that the Bakflip sits more flush on the bedrails and gives you full access to the bed when you flip it up against your cab. I like the Peragon panels dropping into the bed so they don't block the view out the back of the cab. I think the Peragon rails sit higher and don't love that. I know how side mirrors work, so ultimately went with the Bakflip
    KClav, Lawnmower[OP] and Beesta like this.
  7. Jun 5, 2023 at 9:53 AM
    Dan_Gleesac14
    Dan_Gleesac14 New Member
    2023 Tundra SR5;2018 Tundra Platinum (SOLD)
    Just threw a Backflip MX4 on my new SR5 I picked up last Wednesday. Got a great deal on it from another local member, I just bought some expanding foam tape from Home Depot to use at the bulkhead to seal it up which worked perfect. Its a great cover, sits as flush as can be as others have mentioned. Haven't rained or been washed since installed so can't speak on water yet..
    KClav and Lawnmower[OP] like this.
  8. Jun 5, 2023 at 9:54 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    I modified the mouthing inserts to in the rails for my peragon. I just not a fan of blocking my rear view if I needed the bed space. Just my opinion thou.
  9. Jun 5, 2023 at 10:00 AM
    What are your priorities? Is cost the only one?
    You get what you pay for. I learned the hard way buying a Paragon....and then purchased a ReTrax XRPro.
    Lawnmower[QUOTED][OP] and Beesta like this.
  10. Jun 5, 2023 at 10:24 AM
    Lawnmower
    Thank you for all your responses and user experience. I've never had a bed cover before and my main three interests are a dry bed, price and security in that order. Let's face it, if someone wants to get inside any of them, all they need is time. Locks just keep the honest people out.
    Raging Iron Thunder likes this.
  11. Jun 5, 2023 at 10:47 AM
    Hella Krusty
    My OEM Toyota ( one under recall) doesnt leak at all. No dust either
  12. Jun 5, 2023 at 10:56 AM
    DFS
    DFS New Member
    2022 Capstone Tundra
    BAK MX4 is the answer
    TundraDan723 and Lawnmower[OP] like this.
  13. Jun 5, 2023 at 2:00 PM
    badgerd
    badgerd New Member
    Chesapeake, VA
    23 SR5 Army Green
    I’ve got a Bak X4s (doesn’t fit right, waiting for customer service to respond about that) and a friend has the Truxedo Sentry CT. Both are similar and keep the bed dry. Truxedo is cheaper but uses the rails to mount, Bak moves the rails and uses the mounting bolts.
    Both meet the security requirements, do well at keeping the bed dry, but Truxedo is cheaper and just a little over budget.
  14. Jun 5, 2023 at 3:40 PM
    Tmymac
    Tmymac New Member
    Tommy
    1794 Magnetic grey
    None
    A little over a grand but bakflip MX4s seals pretty good. Looks awesome
  15. Jun 5, 2023 at 4:01 PM
    KClav
    KClav MGM Limited
    2022 Tundra Limited CM MGM TRD OR
    My BAKFlip MX4 seals great as well. I’ve sprayed it with the pressure washer and nothing gets in.
    Lawnmower[OP] and Hella Krusty like this.
  16. Jun 5, 2023 at 5:46 PM
    SCbuckeye12
    SCbuckeye12 New Member
    Ted
    2022 Limited
    Was recently shipped the MX4 and while installing I discovered the predrilled holes for installing the clips near the cab weren't the correct size. Actually broke off a post trying to tap it in. Customer service was very responsive and is sending another clip installation kit. Also told me to use a larger screw to enlarge the the hole, rather than redrilling like most people do. So this is a common problem? Oh well, hopefully I'll be happy with the end result.
  17. Jun 6, 2023 at 8:20 AM
    Hella Krusty
    You will know if its a problem if it flies off like the OEM ones LOL
  18. Jun 6, 2023 at 8:53 AM
    ChiefG
    ChiefG Limited 4X4 TRD OR
    Burlington Township, NJ
    2022 Tundra Limited Off Road 4X4
    Just minor stuff. For example, Undercover bed cover, Tufskinz custom door sill protectors, and TRD air filters.
    IMG_5927.jpg I went with the Undercover Elite because I had it before and never had water, dust, etc. get into the bed. It is a clamshell so must be removed (pretty easy though) if you want to use the bed totally uncovered. I figure it’s a small price to pay for the few times I may need to remove it. Great secure cover with no problems. I did add a rubber strip to the inside tailgate edge should the tailgate be opened accidentally with the cover closed to prevent potential scratches.
    ColoradoTJ and Lawnmower[OP] like this.
  19. Jun 6, 2023 at 8:59 AM
    Hella Krusty
    I liked my clamshell I had on my F350 but my short wife couldnt open it HAHAHAHA.....
    Lawnmower[OP] and ChiefG[QUOTED] like this.
  20. Jun 6, 2023 at 9:36 AM
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    Not under $1000 but I love my Diamondback cover. Very secure, keeps out most of the water, I can walk on it, load on top of it, and takes 5 minutes to remove with a 9/16 socket.
    I load my rack on top when I’m camping then take my @KB Voodoo rack off when I’m DD
    Bucng8r, MoneyMan55, Blufin and 4 others like this.
  21. Jun 6, 2023 at 10:27 AM
    SD Surfer
    Bruce
    So Cal
    Very happy with my Bakflip MX4 so far. (I've only had this truck 8 months or so)
    IF ANY water gets in, it's only a tiny bit at the corners when really heavy rain or going through the car wash. None of the tri-folds are gonna' be completely watertight.
  22. Jun 6, 2023 at 2:42 PM
    Twin2turbo
    Twin2turbo New Member
    Pacific NW
    2023 Hybrid MGM Platinum
    Email Santana.Lee@realtruck.com for the best price. I paid less the $900 for my BakFlip MX4 back in January. With free shipping.
    Sixty9Four20 and Lawnmower[OP] like this.
  23. Jun 6, 2023 at 5:08 PM
    HMNYC
    HMNYC New Member
    I went with the Truxedo X15. I like that it rolls up almost completely out of the way and will work with Billie Bars. Planning on installing this week.
  24. Jun 7, 2023 at 4:35 PM
    WoodyOne
    WoodyOne New Member
    Spring, TX
    2023 1794 Blueprint 4x4
    I agree with @PapaDave418, I love my diamondback. It does take me a bit longer to remove though.
    MoneyMan55 and Lawnmower[OP] like this.
  25. Jun 8, 2023 at 4:39 AM
    Hugh_Jaynus
    Hugh_Jaynus New Member
    2023 Silver Tundra Platinum 4x4 Crewmax
    For those of you with the Bakflip MX4, was installation easy? Do I have to drill holes or modify the truck in any way?
    TIA
  26. Jun 8, 2023 at 4:48 AM
    BluePete
    BluePete New Member
    Utah
    Super easy to install. I did the whole thing by myself in under 2 hours and I was going slow. I never looked at the included instructions but just followed this video:
    https://youtu.be/0VJ69_h0yyk
  27. Jun 8, 2023 at 7:13 AM
    Lawnmower
    Thank you for all your information and suggestions. I bought an MX4 and expect it to be here in a couple of days.
    Beesta likes this.
  28. Jun 8, 2023 at 7:17 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I have the Extang Exceed on my Ram and it’s been excellent. It’s a trifold but can be folded all the way to open the entire bed. My last one only fold the first two and I didn’t like that. Look for one that exposes the entire bed when needed.
  29. Jun 8, 2023 at 8:31 AM
    SD Surfer
    Bruce
    So Cal
    Super easy for me! I dropped it off a few doors down from my office at the camper shell place where I bought it, and then picked it up when it was done. :rolleyes::rofl:
    Was gonna' do it myself 'cuz I know it's easy, but he didn't charge me much to install. (I sell them fasteners and gave him a ridiculously good price for just that reason) :bananadance:
    Hugh_Jaynus[QUOTED] likes this.
  30. Jun 8, 2023 at 12:01 PM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    The only thing that requires drilling is optional. The drain tubes require a hole in the bed floor. I usually just run them under my bed mat and they drain out under the mat which keeps my crap dry.
