bed cover is iced shut
Discussion in '3rd Gen Tundras (2022+)' started by kylea311, Nov 19, 2022.
  1. Nov 19, 2022 at 8:17 PM
    kylea311
    kylea311 [OP] New Member
    Dazz
    too damn cold where you can walk on water :-)
    2022 Tundra Platinum 4x4
    With the temp dipping below zero and snow, the bed cover is iced shut.
    What would you use to keep to minimize that? I must've tried a low grade silicon on my other car which turned yellow with low temp and didn't do much.
  2. Nov 19, 2022 at 8:22 PM
    Taco-Spike
    Two Trucks
    Do your doors still open when this happens?
    curios, I don’t deal too much with freezing temps where I live
    BravoDeltaRomeo likes this.
  3. Nov 19, 2022 at 8:28 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    What kind of bed cover? My work pickup has a diamondback. You can use a coat of paste wax which may or may not work, or I just slide a small screwdriver in between the rubber seal and the bend and slide it to break the ice bond.
  4. Nov 19, 2022 at 8:30 PM
    kylea311
    Dazz
    No.. the hard cover is iced over the gate so can't open gate or hardcover.. If you mean the cabin doors, yes they open.
  5. Nov 19, 2022 at 8:54 PM
    kylea311
    Dazz
    It is the Toyota OEM which has soft rubber lip which is easy to freeze but terrible to release. My 2020 F150 Plat had the the bakflip which had a round thick lip over the tailgate so it was easy to get a sharp object and release it..
    My friend uses mechanic grease on his old truck and it works but messy.
  6. Nov 20, 2022 at 4:13 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Spray bottle with methanol lol
