Bed Cap with RTT???
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bmendez1124, Jan 6, 2019.
  1. Jan 6, 2019 at 3:56 PM
    Bmendez1124
    Bmendez1124 [OP] New Member
    Modesto, CA
    2016 Tundra Crewmax
    ◾️Mod List: 2016 MG Tundra Crewmax ◾️Rims: @methodracewheels — Con6 18x9 ET +18 ◾️Tires: @bfgoodrichtires — KO2’s 35x12.5x18 ◾️Suspension: @kingshocks ◾️Headlights: @spyderauto ◾️Fog lights: @cali_raised_led ◾️Bed Rack: @max_modular_truck_bed_racks ◾️RTT: @tepuitents — Explorer Kukenam 3 ◾️Tanks: @rotopaxofficial ◾️Suspension/Wheels/Tires work: @88rotorsoffroad — One of the best spots for any of your truck work.
    Been trying to find research on running a bed cap on a crew max with my RTT mounted on top as well Ive looked at several companies and seen the static weight suggestions. Just curious who currently has this set up and it could be any brand just looking for details on whether or not they like it and if the cap can truly support the weight. Thanks pics for details.
    derkks likes this.
  2. Jan 6, 2019 at 7:21 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I will be running an Eezi-Awn 1600 T-Top on my ARE Z-Series starting this summer. I ran it on a Range Rider canopy on my 2003 Tacoma for long before RTT's were cool (over a decade) with zero issues. I just got the ARE canopy on the new Tundra last month so won't put on the RTT until late spring.
    Fiberglass canopies are like boat hulls. They can take a tremendous amount of pressure/load as long as it's dispersed evenly. You can put a thousand pounds in the boat and the hull won't break - but you hit it with a hammer and it will crack. Same thing with a canopy. As a STATIC load (standing still/parked) you can easily have +500 lbs up there.
    No company will give a rating beyond standard roof rack (around 200 lbs) with a few exceptions. The big reason is static vs dynamic. A litigious public can't understand the difference. Regardless of the vehicle, canopy, etc, it is rare that a load greater than 200 lbs is safe on a moving vehicle. It changes the centre of gravity and in a crash it's simply dangerous. This is why no canopy company wants to say yes to any load higher than what a Yakima or Thule cross bar is rated for.
    There are some caveats that really have nothing to do with a RTT, but more the fiberglass cap. For daily use and overlanding they are great. I've done some crazy trails in the past that pushed the articulation of the truck beyond it's limits. But fiberglass isn't great for dessert jumpers and really crazy offroad. There are torsional stresses that crack fiberglass and any weight on the roof multiply the impact.
    My advice, is to get a good quality canopy like an ARE or Snugtop. Use a track system and 3 crossbars to disperse the weight evenly.
    If you really want to research RTT's go to www.ExpeditionPortal.com
    JRock, ccdawnpatrol, Spitfire and 2 others like this.
  3. Jan 6, 2019 at 8:56 PM
    Bmendez1124
    Modesto, CA
    2016 Tundra Crewmax
    Huge thanks for the information that explains a ton and makes sense I’ll def check into that website for further research. Thanks again much appreciated.
  4. Jan 6, 2019 at 8:57 PM
    Bmendez1124
    Modesto, CA
    2016 Tundra Crewmax
    Nice!!! Would love to see pics of the whole system complete thanks
  5. Jan 6, 2019 at 10:29 PM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    I have a SnugTop with the Sportsman Package which includes a thicker roof to support 500lbs. I’ve got a Prinsu rack on top that holds my Tepui Ayer tent and an ARB 2500 awning. I also have one Baja Design S2 Sport work/scene light in each left and right side of the rack and 2 on the rear of the rack (1 work/scene & 1 combo amber as a chase light).
    Let me know if you would like any detail photos of anything
  6. Jan 7, 2019 at 4:57 AM
    Stig
    Stig New Member
    Where'd you find that picture?
  7. Jan 7, 2019 at 6:30 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    ARE V-Series with FrontRunner rack.
  8. Jan 7, 2019 at 9:16 AM
    mountainpete
    Can a rack be sexy? Roof rack. On a canopy folks. Mind out of the gutter.
  9. Jan 7, 2019 at 11:40 AM
    SpeshulED
    Whoa! Never knew something like this existed. If needed how easy is it to uninstall?
  10. Jan 10, 2019 at 4:16 PM
    Bmendez1124
    Modesto, CA
    2016 Tundra Crewmax
    Sorry for the late reply I just googled searched and it popped up
  11. Feb 17, 2019 at 9:27 AM
    Quikrete
    Quikrete New Member
    Could you post some additional photos of your rack setup. I've got the same SnugTop and I'm on the fence between the prinsu and rhino rack pioneer platform. I like the prinsu asthetic, but wonder how strong the rack is without the additional lateral supports. Just looking at the design, the pioneer platform looks like it would be sturdier, but would love some real world input based on your setup. TIA
  12. Feb 17, 2019 at 10:32 AM
    Sunnier
    Sunny
    San Diego, CA
    If you have any you can post along with those requested above, can you please post photos of your scene lighting. Mainly the areas it lights up. But also helpful would be, where it's mounted on the rack, the path the wires were routed... and what controller you're using (where). Have you got a second battary?
    You've got a great set up; I'd like to know more. Thanks in advance!
    So... if you check out KevinK's Komodo build, his (wife's) MGM crew cab has a JB Grand Raid RTT mounted over a custom (low profile) bedrack.
  13. Feb 18, 2019 at 10:55 AM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    The guy I bought my shell from ran this setup for a few years. Basic Snugtop (it does have the thicker area in the middle of the roof) with 3 Yakima cross bars. He had no issues with him, he's a big guy, and his wife and a couple of dogs.
  14. Feb 18, 2019 at 11:09 AM
    Sunnier
    Sunny
    San Diego, CA
    If you mean you want to see pics of KevinK's CC with the Grand Raid, use the search feature (small magnifying glass near top of your screen on the right, below the Alert. For subject enter "Komodo" and enter KevinK as the poster. You'll get multiple hits and can look through these to find his build.
    I didn't post a link here because, with 248 posts under your belt, I want to make sure you know how to search to get the best info. Someone showed me back when, and it totally got me going.
  15. Feb 18, 2019 at 12:12 PM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    Wow! There are some real badass scenic camping shots in this thread.
  16. Feb 18, 2019 at 3:31 PM
    Taco-Blender
    AZ
    2010 DC 4x4
    Hey @SpeshulED, can you post up pics of your side lights?
    Sunnier likes this.
  17. Mar 2, 2019 at 11:26 AM
    SpeshulED
    Here is a pic of the @Baja Designs S2 Sports. The sides are clear work/scene reflectors. The rear middle is clear wide/cornering with work/scene reflectors until I switch out to spot lens. The right passenger side rear is amber combo lens for my chase light. I plan to add another rear S2 on the driver side with a red combo lens.
    Here are some side photos
    Let me know if you have any other questions. I also some detailed photos on my IG account @bigfuun
    COTundra23, Spitfire and Sunnier like this.
  18. Mar 2, 2019 at 6:33 PM
    Taco-Blender
    AZ
    2010 DC 4x4
    Very nice! Gives me ideas. Thank you Sir.
    SpeshulED[QUOTED] likes this.
  19. Mar 2, 2019 at 7:20 PM
    Alta0
    Alta0 New Member
    I have an A.R.E cx hd with the hd bars. It has a dynamic rating of 550
    SpeshulED likes this.
