Bed cap repair
Discussion in 'Tonneau Covers, Caps and Shells' started by Yoturmotor, Aug 24, 2018.
  1. Aug 24, 2018 at 9:34 AM
    Yoturmotor
    Yoturmotor [OP] New Member
    Kyle
    Suffolk, VA
    2010 Double Cab, 5.7L Tundra
    Does anyone here have experience replacing the internal parts of this type of cover? I picked this cover up yesterday for free, the shell is in okay shape, will need to be repainted, and the internal metal frame is good but the lift arms, brackets and locking mechanism is shot.
  2. Aug 24, 2018 at 9:45 AM
    Yoturmotor
    Kyle
    Suffolk, VA
    It's made by toyota but I'm having issues trying to find the parts. I'm also not trying to spend more than it's worth so if it gets too much, itll be either free to a new home or find it's way to the dump
  3. Aug 24, 2018 at 2:03 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    The fix is fairly easy, it's finding the parts. The lift assist arm for the driver side and the gas props should be readily available at any cap dealer. The handle is going to be a little harder to find but from your picture I think a Leer twist handle would work fine as a replacement. Lift assist arm, gas props, handle, rotary latches and cable are going to run around $140ish.
    Pudge likes this.
  4. Aug 24, 2018 at 4:21 PM
    Yoturmotor
    Kyle
    Suffolk, VA
    @Roman does toyota still offer parts to replace these items duece292 listed?
  5. Aug 27, 2018 at 8:56 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Just checked the struts and brackets, and it looks like they are discontinued.
    ColoradoTJ likes this.
  6. Aug 27, 2018 at 11:22 AM
    Yoturmotor
    Kyle
    Suffolk, VA
    Okay thank you
    Roman[QUOTED] likes this.
  7. Aug 27, 2018 at 11:42 AM
    I would just go to the local fiberglass shell business. The lift struts are cheap and can be matched up according to size.
    The brackets, might be a little more tricky and expensive.
