Bed Bounce Fix?
Discussion in 'General Tundra Discussion' started by Rica25, Feb 24, 2018.
  1. Feb 24, 2018 at 7:07 AM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    What have you guys replaced for the bed bounce at highway speeds issue?
  2. Feb 24, 2018 at 7:14 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    I've never heard of this. What exactly does it do?
    Fiesta346 likes this.
  3. Feb 24, 2018 at 7:21 AM
    Better suspension
    831Tun and 15whtrd like this.
  4. Feb 24, 2018 at 7:24 AM
    15whtrd
    15whtrd Mr. Blonde
    Nothing is really going to get rid of it completely. It’s mostly just sections of Highway that cause it. The easiest solution is putting weight in the bed. I saw someone made a bracket that’s supposed to help that bolts into the surface of the bed. Some claim that getting different springs in the rear help along with shocks. Some say it’s better with the swaybar some say it isn’t. I think I even saw some claim that getting different shackles can help. There is no real answer other than a combination of things changed on the truck hoping it does something. For me I don’t drive on sections of road that cause it often enough to bother me. I would just put a couple hundred pounds of weight over the rear axle. Try some sandbags.
  5. Feb 24, 2018 at 7:25 AM
    JohnH
    JohnH From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    I've heard some simply replaced the bushings and some it went away. Others will surely chime in on this.
    I plan on a combination of shackles, shocks, bushings and maybe K37 springs.
    15whtrd likes this.
  6. Feb 24, 2018 at 7:41 AM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    I put on new shocks and a sway bar...I can’t say it’s gone but it’s not only much less noticeable I got the advantage of a lot better ride 100% of the time
    15whtrd likes this.
  7. Feb 24, 2018 at 7:53 AM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    Right now I have a 200lbs of sand bags in the bed. It will help but not get rid of it. I've researched a bit and it seems upgrading the suspension system is the answer.
    I've also read that it is caused by binding in the bushings at all the suspension connection points. Could this be part of it also, yes it could be. If your going to change the bushings you may as well change the shocks/coils/springs also IMO. In the end the suspension will be getting changed anyway.
  8. Feb 24, 2018 at 8:33 AM
    nk1794
    San Jose, CA
    So I'm not experiencing that problem because I have about 400-500 lbs of combined weight from the Snugtop + Decked storage. I also have the TRD Swaybar installed.
    boostedtrdpro likes this.
  9. Feb 24, 2018 at 8:38 AM
    Rica25
    Ricardo
    Tulare
    I have updated bed mounts from 2013 models I also have new Billstein shocks and TRD sway bar but in some sections of some highways it can get pretty bad
  10. Feb 24, 2018 at 9:27 AM
    Sandy01, Trooper2, Darkness and 9 others like this.
  11. Feb 24, 2018 at 9:28 AM
    nk1794
    San Jose, CA
    :rofl: That should do it.
  12. Feb 24, 2018 at 9:33 AM
    Oh, that's a waistband boner shrinker...for at least a week.
    @batman
    toyofan87, BGoodiE, GODZILLA and 3 others like this.
  13. Feb 24, 2018 at 9:34 AM
    Slump busting!!
  14. Feb 24, 2018 at 9:37 AM
    I still get the occasional bed bounce although not as bad. There is a new stretch of concrete on the I-225 near me. At 55 mph it flat out sucks. Now way to really eliminate it completely. Simply changing out rear leaf OEM bushings can help.
  15. Feb 24, 2018 at 9:38 AM
    I have to ask, since you are a metrologist, how would you go about measuring this total weight? :D
    GODZILLA and nk1794 like this.
  16. Feb 24, 2018 at 9:39 AM
    Drive to a semi truck scale.................:bananadance::bananadance::bananadance::bananadance::bananadance:
  17. Feb 24, 2018 at 9:39 AM
    NCinCO
    Gary
    Thornton, CO
    "Testing in process of the new Tundra Duelly"
  18. Feb 24, 2018 at 9:43 AM
    nk1794
    San Jose, CA
    I think this mod should help.
  19. Feb 24, 2018 at 9:44 AM
    Would definitely turn heads, especially if it had a diesel..
    15whtrd and nk1794[QUOTED] like this.
  20. Feb 24, 2018 at 10:03 AM
    NCinCO
    Gary
    Thornton, CO
    A Tundra duelly diesel? I think I just got a woody
    Trooper2, GODZILLA, 15whtrd and 2 others like this.
  21. Feb 24, 2018 at 10:03 AM
    nk1794
    San Jose, CA
    NCinCO[QUOTED] and Black Wolf like this.
  22. Feb 24, 2018 at 10:06 AM
    nk1794
    San Jose, CA
  23. Feb 24, 2018 at 10:23 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Hey now, fellas. This is 2018, were supposed to embrace and celebrate "curvy" ladies now.
  24. Feb 24, 2018 at 10:42 AM
    Rica25
    Ricardo
    Tulare
    Does anyone know if 3rd generation is different on those mounts to the 2nd generation
  25. Feb 24, 2018 at 10:48 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Curvy ladies yes. But hail damage and cottage cheese isn't for me. :sorry:
  26. Feb 24, 2018 at 10:50 AM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    LOL, hail damage. Don't think I've heard that one yet!
    GODZILLA and 1UPPER[QUOTED] like this.
  27. Feb 24, 2018 at 11:28 AM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
  28. Feb 24, 2018 at 11:32 AM
    More like meteorite damage.[​IMG]
    Trooper2, Tundyfundy, 15whtrd and 2 others like this.
  29. Feb 27, 2018 at 11:22 AM
    920Tundra
    920Tundra New Member
    2011 RW double cab white
    I've had the same issue with my 2011 RW double cab. Threw a A.R.E. cap on it last spring and it went away. Now it's back and worse. I plan to swap out the front/rear shocks and bushings we'll see if that helps.
  30. Feb 27, 2018 at 11:38 AM
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    I think that I read some where that there is a tsb to replace the rear cab mount bushings. I have the bounce too and it really sucks on certain roads/speeds.
