BDS vs Kings CO lift
Discussion in 'Suspension' started by tpc303, Mar 17, 2017.
  1. Mar 17, 2017 at 11:49 AM
    tpc303
    tpc303 [OP] New Member
    Castle Rock, CO
    2012 Limited
    3/1.5 Toltec
    can someone tell me the difference between these two styles of lifts and which one will be the smoothest ride?
    ColoradoTJ likes this.
  2. Mar 17, 2017 at 12:02 PM
    Hey Tim. Can I assume you want the 3" lift right?
  3. Mar 17, 2017 at 12:03 PM
    tpc303
    Castle Rock, CO
    2012 Limited
    3/1.5 Toltec
    I'm more interested in ride comfortability than height.
  4. Mar 17, 2017 at 12:04 PM
    n2deep
    n2deep Pavement Princess
    Depends on what you plan to do with your truck. BDS is a bracket lift and King/Fox/ADS is a coilover with no bracket.
    Bracket lift will allow you to lift it higher than 3 inches while the CO lift is maxed at about 3 inches. Coilover setup will perform better off-road but there is more to it than just throwing it on there for a smoother ride. There is spring rate and valving to consider. It comes down to: How do you plan to use your truck?
  5. Mar 17, 2017 at 12:27 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    These lifts really aren't comparable.
    BDS has a 3" spacer lift, 4.5" drop bracket lift with spacers above coilovers, 4.5" drop bracket lift with replacement coilovers, 7" drop bracket lift with spacers above coilovers and 7" drop bracket lift with replacement coilovers
    King has a 0-3" lift via coilovers
    T-Rex266 and Law323 like this.
  6. Mar 17, 2017 at 12:29 PM
    csuviper
    Broomfield, CO
    BDS
    King
  7. Mar 17, 2017 at 12:29 PM
    csuviper
    Broomfield, CO
    Dude you live in Colorado. Look up Toytec Lifts.
    Toyteclifts.com
  8. Mar 17, 2017 at 12:50 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Leave it stock then
  9. Mar 17, 2017 at 12:57 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    +1 on toytec lifts.
    T-Rex266 likes this.
  10. Mar 18, 2017 at 6:33 PM
    tpc303
    Castle Rock, CO
    2012 Limited
    3/1.5 Toltec
    I have their 3/2 level kit on right now which is ok for the most part, but there's a stretch of highway that I use daily that is absolutely dreadful.
  11. Mar 18, 2017 at 6:36 PM
    tpc303
    Castle Rock, CO
    2012 Limited
    3/1.5 Toltec
    Mostly road driven, but I try to take my sons dirt biking on the weekends in the summer and the occasional hard to access fishing spot.
  12. Mar 18, 2017 at 6:37 PM
    TheBeast The Beach
    Kings FTW!
  13. Mar 18, 2017 at 6:43 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Just talked to a guy at home depo today about his tundra...said he had a BDS with fox shocks and rode better than stock......looked badass too.
  14. Mar 18, 2017 at 6:52 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    And this is the in coil spacer or coilovers?
  15. Mar 18, 2017 at 9:19 PM
    csuviper
    Broomfield, CO
    Spacer lift?
    The concerte hi way thing is because of the rear leaf springs. Not much can completely fix that.
