Battery
Discussion in 'General Tundra Discussion' started by farleymcjohnson, Sep 13, 2022.
  1. Sep 13, 2022 at 3:59 PM
    farleymcjohnson
    farleymcjohnson [OP] New Member
    Eric
    Cokato MN
    2017 Super White Limited Double Cab
    ARE Topper Prinsu Cab and Topper Rack
    What batteries are you guys putting in your Tundra's?
    Mine just took a dump so I'm looking to replace, I use the lights in my topper a lot but they are LED strips, they dont use much for power, other than that I have a light bar and ditch lights but rarely run them without the truck running. I have a camping setup in the back of the truck but no electric accesories yet, maybe a fridge in the future.
    That said I have looked at the Optima Yellowtop, seems like a good battery for my setup but what cheaper ones do you guys reccomend?
  2. Sep 13, 2022 at 4:10 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Saltyhero13 likes this.
  3. Sep 13, 2022 at 4:14 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Optima got bought out I think....
    Definitely a Northstar (Odyssey) fan.
    reywcms and alb1k like this.
  4. Sep 13, 2022 at 4:14 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Odyssey Red top 27F / with diode
  5. Sep 13, 2022 at 4:19 PM
    AZBoatHauler
    So.Arizona
  6. Sep 13, 2022 at 4:38 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    Odyssey grp31
  7. Sep 13, 2022 at 4:53 PM
    farleymcjohnson
    Eric
    Cokato MN
    Do I need a voltage booster with the X2?
    I think stock is a group 24, I'm guessing I can get a group 27 in there? If I was to go to a group 31 what else would I have to do, I'm guessing an aftermarket battery tray but would that require a different alternator? Clearly I dont know much about batteries!
  8. Sep 13, 2022 at 5:13 PM
    AZBoatHauler
    So.Arizona
    Need? I mean - it’ll work without one but the Tundra puts out voltage that is outside it’s specified charging range. Easy fix.
    des2mtn likes this.
  9. Sep 14, 2022 at 3:30 PM
    farleymcjohnson
    Eric
    Cokato MN
    Went with the X2 from Batteries Plus. I'll have to do the voltage booster mod, now that I have a better understanding of it all. Thanks for the help!
  10. Sep 14, 2022 at 4:56 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I don't get much of a boost out of the HKB. Might as well do GM diode imo.
    WVI likes this.
  11. Sep 16, 2022 at 7:22 AM
    jessenavarro
    jessenavarro New Member
    Jesse
    Oak Glen, CA
    2018 White Tundra TRD Off-Road 4x4
    Front Fox 2.5 Coil-over shock with adjustable reservoir -- DSC Rear Fox 2.5 shock with adjustable reservoir -- DSC Total Chaos Fabrication UCA -- tubular Method Race Wheels MR701 18x9 + 25mm -- Matte Black BFG KO2s - 35x12.5x18 Demello Sliders RetraxPro XR bed cover Yakima Roof Rack setup Baja Designs S8 40" light bars x2 (amber and white LED) Baja Designs Squadron Pro ditch lights Baja Designs Squadron Sport fog lights Switch Pros SP-9100 Midland MXT400 GMRS radio
    I have had such bad luck with Costco, unfortunately. However, their warranty is great. If I had to do it all over I’d get a super premium optima battery from the start
