Battery won't take a charge
Discussion in 'Electrical' started by Rockport kev, Jan 23, 2022.
  1. Jan 23, 2022 at 7:03 PM
    Rockport kev
    Rockport kev [OP] New Member
    Kevin
    2019 Tundra TSS
    I have a issue that happened today.
    A few weeks ago I wired some undercarriage lights on my truck. Somehow today in daylight they must have been turned on and I did not know. So running errands stop start several times . Last stop no restart, battery drained. Tow truck jump start , good. Got home turned truck off will not restart. Put on charger for two hours still no start. Wondering if there is a fuse in box not letting it start or is battery just so dead it won’t take a charge,
    Do I replace battery “help”.
    2019 Tundra TSS.
  2. Jan 23, 2022 at 7:20 PM
    2mchfun
    Turn on headlights, if dim very low battery, pretty bright then you have a different issue. Just noticed you have a 19, likely your battery is done!
  3. Jan 23, 2022 at 7:21 PM
    2mchfun
    Btw, welcome to the forum!
  4. Jan 23, 2022 at 7:28 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Welcome from TX!
    If your battery is fully drained it would take a bit longer than 2 hours to charge it up. If you've gotta jump box with a battery tester on it that would be one way to see if it's still good.
    Your best bet is to throw a charger on it overnight and see what she does in the AM. My OEM battery gave up the ghost after 4 years.
  5. Jan 23, 2022 at 7:35 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    The majority of Toyota (& others) oem supplied batteries in the last several years are getting replaced in 2-3 years. Not unusual but kind of crappy of Toyota to put in low life or substandard batteries.
  6. Feb 17, 2022 at 10:35 AM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I got an AGM 27F to replace the battery on my 19...I got it at batteries plus and no issue. I had to put the device in the Alt S spot of the fuse box to get charging up to over 14 volts off the alternator and on occasion hook it up to the CTEK charger. Since it is hybrid battery I get a lot out of it because of all the lights and things i'm running. This thread explains how to boost the voltage without much modification. Mine has been running two years with no issue.
    https://www.tacomaworld.com/threads/the-northstar-agm-battery-voltage-booster-upgrade.604478/
    cavalry bear and HulkSmurf14 like this.
  7. Feb 22, 2022 at 6:30 AM
    adoboyota_newengland
    adoboyota_newengland New Member
    Ricco
    2018 Barcelona Red Crew Cab Limited
    recently purchase May 10 2021
    dkrou thanks for the the link
