Battery terminals
Discussion in 'New Member Introductions' started by Oilfieldtundra, Feb 19, 2023.
  1. Feb 19, 2023 at 2:29 AM
    Oilfieldtundra
    Oilfieldtundra [OP] New Member
    2010 tundra crew max sr5
    Stock
    Hey all new to the hang out spot. My truck needs new battery terminals what all are the best ones out there? I’m always driving on dirt roads and fields.
  2. Feb 19, 2023 at 4:02 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Many here use the GP audio or SDHQ billet terminals but they are pricey. I’m still using OEM with an AGM battery. The factory terminals did corrode when I still had my original Toyota battery. I use the red and green felt washers and a dab of grease on the post and terminal. My son used a cheap gold plated marine terminal that was solid and smooth so easy to wipe clean.
    bulldog93 and Oilfieldtundra[OP] like this.
  3. Feb 19, 2023 at 4:37 AM
    Welcome from NY.
  4. Feb 19, 2023 at 4:38 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! I have never had any issue with the OEM terminals as long as I greased them to prevent corrosion.
    Demented Canine likes this.
  5. Feb 19, 2023 at 5:33 AM
    Demented Canine
    Demented Canine Hiding in the Baffles
    Extreme Southeast Georgia
    2020 MGM SR5 DC
    Once you get the new terminals installed, spray them with this stuff:
    bulldog93 likes this.
  6. Feb 19, 2023 at 7:12 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
  7. Feb 19, 2023 at 3:57 PM
    Oilfieldtundra
    Stock
    Thank you for a quick response
  8. Feb 19, 2023 at 3:57 PM
    Oilfieldtundra
    Stock
    Thank you all
  9. Feb 19, 2023 at 4:30 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  10. Feb 23, 2023 at 4:57 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal. No issues with my battery terminals. Always used those felt battery washers.
  11. Feb 23, 2023 at 5:32 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    Another vote for SDHQ, cry once type of deal. I went thru 3 styles before biting the bullet and getting the SDHQ ones. So much nicer. And if your planning on adding anything, like winch lines, or a/m lamps the extra bolts are a huge help.
    A work in progress:
  12. Feb 23, 2023 at 6:23 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    another vote for SDHQ. I have the terminal protection kit too, its great for all the add on wiring I have and its solid as a rock.
