Battery size
Discussion in '3rd Gen Tundras (2022+)' started by AND, Aug 24, 2022.
  1. Aug 24, 2022 at 3:59 PM
    AND
    AND [OP] New Member
    Washington, PNW
    Does anybody know the starting battery size? Can’t find it anywhere, dealership doesn’t know either.
    * for the 2022 Tundra non Hybrid***
  2. Aug 24, 2022 at 4:02 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
  3. Aug 24, 2022 at 4:17 PM
    AND
    AND [OP] New Member
    Washington, PNW
    Where did you find this info? the dimensions look way different
  4. Aug 24, 2022 at 4:46 PM
    NewImprovedRon
    Ron
    NW Arkansas
    Sorry, I suppose I should have asked what year your vehicle is and verified that it is a Tundra before replying.
  5. Aug 24, 2022 at 5:47 PM
    AND
    AND [OP] New Member
    Washington, PNW
    I updated the post to reflect vehicle
  6. Aug 24, 2022 at 8:43 PM
    kj5385llc
    kj5385llc New Member
    Owners manual page 536
    When replacing the battery
    ● Use a genuine battery specifically designed for use with the Stop & Start system or a battery with equivalent specifications to a gen- uine battery. If an unsupported battery is used, Stop & Start sys- tem functions may be restricted to protect the battery. Also, battery performance may decrease and the engine may not be able to restart. Contact your Toyota dealer for details.
    ●Use a battery that conforms to European regulations.
    ●Use a battery with the same case size as the previous battery and an equivalent 20 hour rate capac- ity (20HR) or greater.
    • If the sizes differ, the battery can- not be properly secured.
    • If the 20 hour rate capacity is low, even if the time period where the vehicle is not used is a short time, the battery may discharge and the engine may not be able to start.
  7. Aug 24, 2022 at 9:28 PM
    AND
    AND [OP] New Member
    Washington, PNW
    Thanks for that, I was looking for that, but it still doesn’t say what group/size it is.
    I saw in the @xoverland tundra build video they fit a group 31. It is so bizarre that nobody knows what the stock size is.
