Battery Replacement Discovery!
Discussion in 'General Tundra Discussion' started by ApoRam, Mar 22, 2024.
  1. Mar 22, 2024 at 10:45 PM
    ApoRam
    ApoRam [OP] New Member
    Charles
    2019 Tundra TRD 4X4
    2019 Toyota Tundra
    MAKE CERTAIN YOU HAVE MORE THAN 40 MILES OF GAS STILL LEFT IN YOUR TANK BEFORE CHANGING THE BATTERY!
    The computer will refuse to start the car because it will "THINK FALSELY" that the truck is TOTALLY OUT OF GAS!
    Thankfully, there remains a very small amount in reserve so if you continue to turn the ignition it will eventually start as long as there is a gas station VERY CLOSE BY!
    I hope this helps some of you and that you will REMEMBER to put just a little gasoline into your tank BEFORE you replace your truck battery.
    Charles
    Leo's first likes this.
  2. Mar 23, 2024 at 12:21 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Well that’s a new one. It’s normal after replacement of the battery for the truck to start, then die. Restarting afterward it should idle. This is caused by the ecm relearning the throttle idle position due to carbon build up.
    The pump has a computer controlling it, but I’ve never seen low fuel cause the pump to not run. Odd. Fuel pump only runs when it sees engine RPM. So they don’t prime like domestic vehicles do. Pump only runs once the starter starts spinning
  3. Mar 23, 2024 at 6:05 AM
    boatsnbikes
    boatsnbikes New Member
    Never heard that one but will keep it in mind
  4. Mar 23, 2024 at 6:25 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    In over six years of ownership I have never allowed my tank to get anywhere near that low. Most I have filled it (38 gallon tank) is 32 gallons meaning I had 6 gallons (about 100 miles) left.
    Bammer likes this.
  5. Mar 23, 2024 at 9:09 AM
    CMikeB
    CMikeB New Member
    I've never seen my fuel light since buying my 2010 SR5 brand new!:D
    Bammer likes this.
  6. Mar 23, 2024 at 9:36 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Sorry, but I'm not buying this one.
  7. Mar 23, 2024 at 9:45 AM
    Yep. Very iffy.
    GODZILLA and 1lowlife like this.
  8. Mar 23, 2024 at 9:52 AM
    CMikeB
    CMikeB New Member
    I ain't sellin', just stating a fact.
  9. Mar 23, 2024 at 10:19 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Facts from where?
  10. Mar 23, 2024 at 10:23 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    How would you know, you've never been in the OP's situation?
    @NewImprovedRon wasn't quoting your post..:rolleyes:
    I've had my battery disconnected and/or replaced more times than I'd like to remember on my 2014.
    Multiple levels of fuel I'm sure.
    As previously stated, it would turn and die on the first key turn, but always stated after that.
    There may be something else wrong with @ApoRam's truck..
    Besides that, his 2019 has a multiple-gallon reserve when on empty, all Gen 2.5 tundras do.
    NewImprovedRon and Black Wolf like this.
  11. Mar 23, 2024 at 2:11 PM
    CMikeB
    CMikeB New Member
    Fact from me buying my truck with 4 miles on it and now showing 88,000. Being the only driver 99% on those miles. I thought my comment was clear enough.
  12. Mar 23, 2024 at 2:36 PM
    Is it possible that there is a miscommunication going on? I rarely ever let my Tundra's gas level get low enough for the light to come on. When I drove to Alaska in my 09 Taco...I miscalculated on where I could fuel up. I was on fumes when I got to Contact Creek. Tiny gas station. Tiny snacks. Filled up which was equivalent to $6.50 a gallon. Late November 2011. Got a freebie calendar which I still have. My Frontier has never seen a low fuel light. Yet....ha!
    NewImprovedRon likes this.
  13. Mar 23, 2024 at 2:47 PM
    CMikeB
    CMikeB New Member
    Probably. I should just shut up and go lie down for a while!:D
  14. Mar 23, 2024 at 2:51 PM
    Pretty sure their statements were directed at the original post, not at yours.
    PSA:
    Folks, this is why the little quote button or tagging (like this @NewImprovedRon ) is so important. Then people know what you are commenting on and can follow a conversation.
  15. Mar 23, 2024 at 3:14 PM
    CMikeB
    CMikeB New Member
    Yeuup! :oldglory:
    Black Wolf likes this.
  16. Mar 24, 2024 at 7:14 AM
    NewImprovedRon
    Ron
    NW Arkansas
    To be specific, this was the post that I was referring to when I said
    I have had my battery disconnected a number of times while doing electrical work and it always dies on the first restart when the battery is reconnected regardless of the fuel level.
    Black Wolf and GODZILLA like this.
