Battery recommendations for 2020 with lots of LED’s?
Discussion in 'Electrical' started by Shagman82, Dec 8, 2023.
  1. Dec 8, 2023 at 8:07 PM
    Shagman82
    Shagman82 [OP] New Member
    2020 SR5
    Hi all! Happy Friday!
    My battery on my 2020 SR5 kicked the can yesterday and I’ve spent the last couple hours researching batteries on the forum. Looking for some recent thoughts on what the best battery for our tundra is. Worth noting.. I am soon going to be running roughly 10-12 diode dynamics SS3/SS5 light pods so looking for something that has enough juice to power all the LEDS. I shouldn’t be using them much with the truck off, but still want to ensure I have enough battery.
    as of right now, looking at the X2 27F or optima Red top. Anyone have an opinion on what to buy for my use case?
    thanks everyone and have a great weekend!!
  2. Dec 8, 2023 at 9:29 PM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    The alternator powers your electrical needs while the engine is running. So, it don't matter what size 12-volt battery you get as long as it has enough amps to crank the starter. If you plan on having the lights on with the engine off, then battery size becomes more relevant.
    Shagman82[OP] and 1lowlife like this.
  3. Dec 8, 2023 at 9:39 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    If you buy an AGM battery, the 2 you have listed, plan on topping them off with a charger once a month.
    I had an X2 and I guess it was a lemon, it died on me twice in 6 months.
    Batteries Plus screwed me on the warranty and I used it for a $20 core charge swap for my Interstate MTP.
    Several threads on the forum regarding AGM batteries..
    I'm big on Interstate batteries myself.
    MTP-27F battery | Interstate Batteries
    What was your stock OEM battery, 27F or 24F?
    If it was 24F, you'll need a bigger 27F tray to fit a 27F battery..
    74431-0C020 - Battery Tray - 1996-2022 Toyota | Sparks Parts
    Good luck.
  4. Dec 10, 2023 at 9:02 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Aren’t some folks packing a group 31 battery in the OEM location? A bit of cable rework is likely necessary because the terminals may swap locations on you.
  5. Dec 11, 2023 at 3:03 AM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    Yep, rago battery tray fits a group 31. Had to use a 6 lug battery terminal to get the original positive to reach.
  6. Dec 11, 2023 at 3:34 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Been using an X2 for the past 2 years, still going strong.
  7. Dec 11, 2023 at 3:50 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    I have asked before and no one actually answers the question.
    But why are people doing this costly swap???
    The X2 Power 27F is sub $400 and mounts right up.
    An Odyssey 31 is like $530 + about $200 in parts to get it to fit and mount safely.
    You are looking at $300+ for 11 more pounds, only more 200CCA, and 8ahs?
    It just seems like a lot of money for very little return.
    I have had 4 vehicles with X2 power batteries now. 2 Toyotas, a GM, and a Ford. They have been great, no diode/voltage booster, no monthly top offs, no dead batteries.
  8. Dec 11, 2023 at 4:48 AM
    Dawoofles
    Santa’s Village
    I upgraded the alternator, and upgraded the wiring for my stereo. Didn’t want my lights to dim when the bass hits or have problems with system draining the battery. Could a smaller battery work? Yes but in the winter when it’s -20, I rather have the extra CCAs.
    Cruzer likes this.
  9. Dec 11, 2023 at 5:59 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I used to have a shit ton of LED pods and bars and would notice that my headlights would dim when I turned a few of them on. That problem went away when I too upgraded to a higher output alternator.
  10. Dec 11, 2023 at 6:05 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    For some, the upgrade is worth the cost. “Only 200 more CCA” is how many percent over stock? Same for the AH increase…. it’s all gains.
    No different than spending $1,500 for exhaust to gain just a few HP. Is it worth it? Not for everyone.
  11. Dec 11, 2023 at 8:32 AM
    Black
    Much more than stock.
    But the X2 is more than stock as well.
    Spending $1500 on an exhaust I will ask the exact same question.
    I am cheap and don’t have a ton of money so every penny counts.
  12. Dec 12, 2023 at 9:52 AM
    Shagman82
    2020 SR5
    Hey all!! Ended up going with the Interstate Acid lead 27f from Costco. Couldn’t make my mind up on going with X2, so figured I would just go standard for now and spend the savings on the SDHQ billet terminal upgrade. Once I get my LED’s installed and notice the battery being an issue I may upgrade to the X2, but figured I wouldn’t be using my light pods with the truck off that much so it wasn’t worth the premium. Also (just being super nit picky) I didn’t like the 27F X2 was almost 20 pounds heavier than the stock battery. Almost a 70 pound battery :eek:
    thanks everyone for the help and input!!!
