Battery not charging
Discussion in '2.5 Gen Tundras (2014-2021)' started by Steplift20, Sep 8, 2025 at 4:22 PM.
  1. Sep 8, 2025 at 4:22 PM
    Steplift20
    Steplift20 [OP] New Member
    2018 Tundra
    2018. 34000 miles. My battery light came on so I Put in a new battery. It was on my list anyway. The battery light is still on.
    I checked 5he out put on 5he alternator and it’s not putting anything out
    I’m wondering if it’s the fuses. I don’t know where they are
    I think I have 4 of them. I can’t believe that one day it’s charging fine then today it’s not. No warning. ‼️. I would like to know what you guys think?
    I’m bringing her into the dealer tomorrow I believe she ( my truck) is still under warranty
  2. Sep 8, 2025 at 4:39 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    You just got unlucky it seems. Definitely sounds like alternator.
    Corndog123 and 2mchfun like this.
  3. Sep 8, 2025 at 4:54 PM
    2mchfun
    You might have waited too long to replace the battery. An alternator can be destroyed by a weak battery. What warranty program do you have?
  4. Sep 8, 2025 at 5:02 PM
    Steplift20
    2018 Tundra
    Extended warranty from toyota
    My battery was tested when I got a oil change and they said it was a good battery
    HulkSmurf14 likes this.
  5. Sep 8, 2025 at 5:03 PM
    MadMaxCanon
    They should take care of it without issue hopefully
  6. Sep 8, 2025 at 5:24 PM
    2mchfun
    Well then maybe it will be covered. If you replaced the battery, they may try to claim that you caused the issue. These clowns nowadays....
    Corndog123 likes this.
  7. Sep 8, 2025 at 6:13 PM
    Steplift20
    2018 Tundra
    I hope so. I will post here the results. I’m thinking it’s a fuse only because yesterday it was good. Now today. Nothing. Not charging
  8. Sep 9, 2025 at 8:14 AM
    MadMaxCanon
    I've found that alternator usually go out all of a sudden.
    2mchfun and AZBoatHauler like this.
  9. Sep 9, 2025 at 9:00 AM
    Steplift20
    2018 Tundra
    All of a sudden? That’s exactly what happened, one day it was good the next day it wasn’t charging at all
    I remember when your alternator went out or was go8ng out the battery light would fade on then you gave it 5he gas and it would go out or was
    But with today’s advancement. It gives you no warning. Fantastic. But 8 will let you know what happens when i get my truck back. It’s in now.
    Now I have to reprogram everything. But in my 1969 GTO you can take the battery out. Put it in and everything is as it was. That’s progress. B/ S
  10. Sep 9, 2025 at 11:47 AM
    Steplift20
    2018 Tundra
    Just got the answer
    It was my alternator.
    I owned cars my whole life,junk cars,used cars, and I can’t only remember one time I had to change an alternator.
    Now Toyota, the tundra no less. Built tough,built to last. The alternator fails
    2mchfun likes this.
  11. Sep 9, 2025 at 12:08 PM
    2mchfun
    How old was that battery that you replaced?
  12. Sep 9, 2025 at 12:26 PM
    RawRunner
    RawRunner New Member
    Monday
    I need a new battery too. Last time my battery was dead but didn't know I thought it was a good idea that day to use the remote start only to hear the alternator cranking nonstop.
  13. Sep 9, 2025 at 2:33 PM
    MadMaxCanon
    Covered under warranty right?
  14. Sep 10, 2025 at 6:19 AM
    Steplift20
    2018 Tundra
    My battery was the original to my 2018. So it’s 7 years old and it was still good. The alternator failed.
    Yes they covered the part and labor under the warranty if I had to pay for a new alternator the price would be over $1400.00. She told me that’s what they paid bu5 if I was responsible it would have been over $2000.00
    For an alternator? Really. And 5he rear brakes were worn down just as bad as my front brakes, how is that possible
  15. Sep 10, 2025 at 7:40 AM
    2mchfun
    That old battery likely killed the alternator prematurely. Rear brakes work equally hard on the 2.5 gen Tundra.
    NewImprovedRon and PermaFrostTRD like this.
  16. Sep 10, 2025 at 7:54 AM
    PermaFrostTRD
    Northern NY
    Not trying to be confrontational but I can assure you that the original, from-the-factory battery that is 7 years old is far from "good". As others have suggested I bet its recent lack of "goodness" is what resulted in your alternator failure. My understanding is that an alternator swap on these trucks is a bit of a bear, so it will involve some labor.
    Regarding your brakes - also a known issue as others have indicated. 34k miles might be a little early, but do you tow much? Haul much? lots of city stop and go driving? Heavy on the go pedal too (generally means heavy on the stop pedal as well)? All of these things (and more) can lead to premature brake wear.
    7 years and a new battery, alternator (that you didnt have to pay for thanks to your warranty), and new brakes?? Pretty good all things considered. I certainly would keep those kind of complaints to the 2nd gen forums :spy:
    NewImprovedRon likes this.
  17. Sep 10, 2025 at 1:14 PM
    Steplift20
    2018 Tundra
    They always checked my battery when I got my oil change and it always came back good. I had no problem at all with the battery.
    As far as my brakes. I don’t know why they were worn down that much. I drive very carefully I don’t take off fast and I don’t stop fast. Actually I’m a good driver I drove a 18 wheeler for 40 years and got awards. I know how to drive that’s what doesn’t make sense. I don’t tow and I don’t have weight in my bed. True my wife could loose a few pounds lol I didn’t say that.
    PermaFrostTRD likes this.
  18. Sep 10, 2025 at 1:26 PM
    MadMaxCanon
    Battery voltage is not an accurate indicator of battery health. Load test is.
    Its also important to top off your cells with distilled water to increase life on battery.
    PermaFrostTRD and 2mchfun like this.
  19. Sep 10, 2025 at 3:28 PM
    Steplift20
    2018 Tundra
    The battery was fine. The alternator went bad.
    I’d did replace the battery only because it was getting old not because it went bad
    The alternator was the problem. I think I just got a bad one
    7 years old and only 34000 miles and my truck was always taken care of.
    I also did the brakes and brake line flush
    And don’t forget. I. T. S. A. T. U. N. D. R. A. Toyota. Let’s go places. Yeah right. Very surprised that the alternator failed at such low miles and a pretty new truck. That was taken care of. 100 percent from day 1
  20. Sep 10, 2025 at 4:45 PM
    MadMaxCanon
    Yes, its 100% toyotas fault. You in no way stressed a component that is near unheard of to fail before 100,000 miles.The unqualified 19 year old screwing up your oil change was absolutely correct that your almost 8 year old battery he likely never even checked was good. Toyota sucks. Lock this thread.
  21. Sep 11, 2025 at 3:02 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Stuff is going to happen. It sucks that a bad alternator was put on but as you know, anything man made can fail at any time. At least you SHOULD be g2g now.
  22. Sep 11, 2025 at 6:06 AM
    Steplift20
    2018 Tundra
    I hope you are right. I should not have that problem for a long time now. I also had my brakes done. Front and back and a brake fluid flush. I was very surprised that they said they could resurface the rotors. My rotors were to me perfect condition. I know they always want to replace them. So that was good that they didn’t. Still over $1000.00 but it’s O. E. M. Brake pads Toyota fluid. All. O. E. M
  23. Sep 11, 2025 at 6:42 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    THIS ^^^^^^^^^.
    I've been in an around Toyotas since 1985. I have never heard of or experienced a Toyota alternator "going bad" at 34,000 miles. Veeeeeeeeeery unusual.
