battery light on then off
Discussion in '1st Gen Tundras (2000-2006)' started by 3bears, Oct 27, 2024.
  1. Oct 27, 2024 at 6:57 PM
    3bears
    3bears [OP] New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    so brand new battery...preventative for winter and this old one was dated 6/21
    been no issues but its not my daily driver. today drove for about 30 miles with several shut downs and starts...all fine. then got home and a few hours later started it to move and battery light came on. shut off and then restarted no light and ran about 15 minnutes...no light. shut off...sat half hour... restart no light...torque pro showed 13.4 volts. my son needs to borrow for a week.
    Ideas ?
  2. Oct 27, 2024 at 7:01 PM
    shifty` I'm having daydreams about night things
    Possible that your cables are loose, you didn't tighten them.
    The alternate possibility is your alternator is getting fucky.
    Doublecheck the cables, wiggle, make sure they're tight. If tight, keep an eye on it, if the light comes on again, see if you can verify your voltage before turning the truck off. If it's low, your alt may be going out. Actually, if the light pops on again the alternator may also be going out, but ...
    3bears[OP] likes this.
  3. Oct 27, 2024 at 7:28 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    My first thought was alternator also. It holds the voltage regulator for the whole entire truck
    3bears[OP] and G_unit3000 like this.
  4. Oct 27, 2024 at 7:48 PM
    3bears
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    thanks,,,but I cleaned terminals and connections when put new battery in...and when this happened this afternoon I checked my connections and terminals...all tight...guess my alternator is on its way out, hope it gets threw the week with my son borrowing...
  5. Oct 27, 2024 at 10:00 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The alternators are not hard to change in these trucks
    3bears[QUOTED][OP] likes this.
