Battery goes dead
Discussion in 'General Tundra Discussion' started by ATB, Oct 15, 2021.
  1. Oct 15, 2021 at 8:08 AM
    ATB
    ATB [OP] New Member
    Andy
    2006 Tundra
    I have a 2006 Toyota Tundra and if the front windows are rolled down and no key in the ignition, the battery goes dead........today i sat in the truck for 10 minutes with the key in the ignition but off and the battery almost went dead. Is the window being down tied to the ignition switch? I often leave the rear window down and have no problem?
    I have owned this truck for 6 years with zero problems.
    Help if you can and THANKS!
  2. Oct 15, 2021 at 8:38 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Have your battery checked.
    I can't think of anything in the windows that would cause that battery issue, it may be just coincidence.
    Maybe if your battery is weak and you are rolling the windows down with the engine off, it's draining the battery.
  3. Oct 15, 2021 at 8:38 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Have you checked to see if your battery is bad? Needs to be load tested
  4. Oct 15, 2021 at 8:40 AM
    PentagonTundra
    PentagonTundra New Member
    2018 Tundra Platinum 4x4
    fully stock
    x2 its the battery, when was it last replaced ?
    NewImprovedRon likes this.
  5. Oct 15, 2021 at 8:57 AM
    ATB
    ATB [OP] New Member
    Andy
    2006 Tundra
    Battery check and is good. This has happened about 5 times in the last year. My guess is not the battery.........guess. I will have battery looked at again.
  6. Oct 15, 2021 at 11:11 AM
    ATB
    ATB [OP] New Member
    Andy
    2006 Tundra
    I had the battery load tested.
  7. Oct 30, 2021 at 12:31 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Are your lights on at all while you sit with it off? Or any other accessories? If any of them are on a auto off future the auto off won't work unless the door gets opened.
    If it goes dead with the windows all the way down an key in ignition but off.
    Does it go dead if key is removed?
    Does it go dead if key is still in but the windows are 2" from the bottom of being all the way rolled down?
  8. Oct 30, 2021 at 5:53 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Load test battery... Official welcome
