BATTERY GAUGE FLUCTUATES
Discussion in '2nd Gen Tundras (2007-2013)' started by Chet, Jun 25, 2019.
  1. Jun 25, 2019 at 9:07 AM
    Chet
    Chet [OP] New Member
    Orlando FL
    2007 Toyota Tundra Regular Cab V6 4.0
    Got a new battery for my '07 Tundra about a month ago. Went to start my truck the other morning and it wouldn't start, after a few attempts the battery pretty much died. First step was to check the connections, disconnected then reconnected both positive and ground leads. Truck started right up!
    Since then it starts up fine, but the voltage gauge fluctuates a bit, it increases then decreases just a little from the baseline.
    Could it be the alternator, starter or even the new battery?
    Thanks,
    Kurt
  2. Jun 26, 2019 at 8:38 PM
    Black4X2
    Black4X2 New Member
    Bill
    2007 Black Tundra Limited 4X2
    By what you describe my guess would be either the battery or the connections.
    Chet[OP] and Black Wolf like this.
  3. Jun 26, 2019 at 9:07 PM
    Take a pic of your battery and terminal connections
    GNTundra likes this.
  4. Jun 26, 2019 at 9:17 PM
    GNTundra
    Gino
    2013 White
    How many miles?
  5. Jun 27, 2019 at 6:38 AM
    Chet
    Orlando FL
    Hey all, thanks for the responses. Took my Tundra to the mechanic yesterday ...he tested everything, battery, starter, alternator etc., couldn't find any issues so it was likely poor connections so he reconnected and cleaned everything up. 100k miles.
  6. Jun 27, 2019 at 8:38 AM
    Black4X2
    Black4X2 New Member
    Bill
    Disconnecting and then reconnecting the battery and everything was okay was the clue.
    Sundown5oh and Chet[OP] like this.
  7. Jun 27, 2019 at 8:43 AM
    Chet
    Orlando FL
    Well, I disconnected then reconnected the leads myself...then the truck started right up, but the battery gauge/meter started fluctuating. The mechanic did the same but also checked the other leads, i.e. voltage regulator etc. I'd read that a fluctuating gauge could be due to a faltering alternator. Whatever the case, it's fixed...for now.
  8. Jun 27, 2019 at 8:49 AM
    Black4X2
    Black4X2 New Member
    Bill
    All you can do is watch it for now.But it sounds like it may be fixed.Good luck.
  9. Jun 27, 2019 at 9:03 AM
    Chet
    Orlando FL
    Thanks! Yeah, it's one of those things that sometimes there's no clear answer to.
  10. Jun 28, 2019 at 7:18 PM
    RogueTundra
    RogueTundra New Member
    Tyler
    2011 Limited CrewMax
    7" BDS Lift. 35" RBPs. 20x14 Fuel Mavericks. K&N Intake. Muffler delete.
    Had this happen today. I drove it kinda hard on the way home. Noticed after i calmed down that the gauge was moving quite rapidly but only little movements. I came home and cleaned all my grounds and connections. I fired it up and it immediately died. Fired it again and it ran but really low idle. After a minute or so it leveled out. The gauge isnt moving now and is sitting just a hair below the middle mark. The battery is getting about 13.7 volts at idle. I'm hoping my alternator isnt on its way out.
  11. Jun 28, 2019 at 9:01 PM
    Black4X2
    Black4X2 New Member
    Bill
    That's about what mine has always put out.When it's really cold out it will put out 14 volts but only for a short time then it drops to about what yours is. When you disconnect the battery on these Tundras and start it up the first time they immediately die. Then they are okay. I have no idea why they do this but they just do. It sounds like you probably fixed your problem.
    RogueTundra[QUOTED] likes this.
  12. Dec 24, 2019 at 8:34 AM
    james33440
    james33440 New Member
    James
    2010 Tundra Double Cab
    Magnaflow Exhaust
    Mine is doing this too. Once I disconnect the leads from the battery and reconnect, it cranks but then dies. After a few minutes it will level out and be ok but it’s frustrating.
    I wonder is this really normal or could by alternator be going out
  13. Dec 24, 2019 at 9:41 AM
    Black4X2
    Black4X2 New Member
    Bill
    It's normal for it to die the first time after you reconnect the battery. I haven't a clue why. I guess only Toyota knows why it does this.
  14. Dec 24, 2019 at 11:37 AM
    ajax1
    ajax1 New Member
    2012 black trd limited modded up
    Tires, suspension, bumpers, soft topper
    Neither of my Toyotas die after the first start when disconnecting, they will however idle low due to the ecu relearning
  15. Dec 24, 2019 at 12:21 PM
    Black4X2
    Black4X2 New Member
    Bill
    Maybe only the earlier models do it. Both our 2007 Tundra and 2010 4runner do it. However I don't remember the idle being low. If anything the Tundra seemed high till I drove it a bit.
  16. Dec 24, 2019 at 12:51 PM
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    -20% tint all around and over factory -2” ToyTec leveling spacer -275 70 18 BFG KO2 -TRD duel exhaust -TRD Pro skid plate -TRD Pro grille -TRD sway bar -TRD performance air filter -vinal wrapped front bumpers -Xenon Vision led head/ fog lights and interior lights -AJT Design billet shift knob
    I replaced the battery in my truck about a month ago. Its a 2017 and it died on first start up after installing the new battery..sooo its not just the earlier models. I did not have low idle either. Maybe just luck of the draw?
  17. Dec 24, 2019 at 1:16 PM
    ajax1
    ajax1 New Member
    Interesting I’ve owned two early tacos 97 and 2000, couple runners from same time, they all did the low idle for couple starts till ecu relearned. My 94 fzj80 does real low idle to point of almost dies till it has had few starts. My tundra does low idle for first couple starts but has never died. Either way it’s the ecu having to relearn everything
  18. Nov 22, 2024 at 8:21 PM
    jbpkeen
    jbpkeen New Member
    2010 white tundra limited
    Hello I have a 2010 tundra limited with a 4.6 my truck battery gauge with hold 14 volts while I give it fuel but when I stop at red lights or idle it will keep dropping off until the truck dies I changed the alternator this morning it sucks big time and I crank the truck back up and it idle real low and about 10 mins maybe 5 mins and it died again battery gauge start dropping off and I would give it fuel it jump back up and then fall faster idk what else to do the battery was bought July last year
  19. Nov 22, 2024 at 8:38 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Its the battery brother.... I've killed off more than enough to know. I've yet to replace my alternator and I'm running without a skid plate for over a decade.
    jbpkeen[QUOTED] likes this.
  20. Nov 22, 2024 at 8:52 PM
    jbpkeen
    jbpkeen New Member
    10-4 I’ll give it a try and I run with that skid on the bottom as well damn things just gets in the way
    blackdemon_tt likes this.
  21. Nov 22, 2024 at 8:56 PM
    blackdemon_tt
    Main reason I just ditched it... it sits in my garage. It made a 20 minute oil change into an hour plus ordeal. Don't off road, except for those food vending trucks down the street.
  22. Nov 24, 2024 at 11:33 AM
    jbpkeen
    jbpkeen New Member
    Changes the battery this morning and it did not solve the problem wonder if the voltage regulator going bad
  23. Nov 24, 2024 at 12:59 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Every toyota I've had dies immediately after starting the first time after disconnecting and reconnecting battery. It's a relearning type thing.
    Load test your battery to know if it's truly bad. Voltage doesn't mean much. Anything around or below 10v when you crank is bad.
  24. Nov 24, 2024 at 3:30 PM
    jbpkeen
    jbpkeen New Member
    It did not die immediately it was about 10 mins running at a idle in the yard I walked out to check on it my battery gauge was dropping I gave it some fuel and it climb back up then right after that when you come out the fuel when it dies
