Battery Gauge Fluctuates
Discussion in 'General Tundra Discussion' started by Chet, Jun 25, 2019.
  1. Jun 25, 2019 at 7:52 AM
    Chet
    Chet [OP] New Member
    Orlando FL
    2007 Toyota Tundra Regular Cab V6 4.0
    Got a new battery for my '07 Tundra about a month ago. Went to start my truck the other morning and it wouldn't start, after a few attempts the battery pretty much died. First step was to check the connections, disconnected then reconnected both positive and ground leads. Truck started right up!
    Since then it starts up fine, but the voltage gauge fluctuates a bit, it increases then decreases just a little from the baseline.
    Could it be the alternator, starter or even the new battery?
    Thanks,
    Kurt
  2. Jun 25, 2019 at 9:40 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Gauge fluctuation sounds like a short or loose connection/ground in wiring associated with the charging system or the battery. If you don't find the problem, it may lead to alternator or battery failure.
    Welcome from the Texas Hill Country.
  3. Jun 25, 2019 at 9:47 AM
    Chet
    Orlando FL
    Thanks John, that's what I figured...Taking truck in tomorrow to troubleshoot, just hope it's not one of those things that takes 3 or so visits to the mechanic to get it taken care of.
