Battery Drainage
Discussion in '2.5 Gen Tundras (2014-2021)' started by DWE, Nov 3, 2021.
  1. Nov 3, 2021 at 10:13 AM
    DWE
    DWE [OP] New Member
    Dave
    2015 Black Tundra 1794 Edition
    Stock
    I'm having issues with the battery draining if I do not drive my Tundra for several days. Any help on guiding me to the component that is causing the drain. Thanks
  2. Nov 3, 2021 at 10:44 AM
    DWE
    DWE [OP] New Member
    Dave
    Stock
    I replaced the battery, a years or so ago thinking that it was the issue.... The issue has continued. The entire truck is stock. I have not modified a thing. I will take a moment and introduce myself.
    NewImprovedRon likes this.
  3. Nov 3, 2021 at 10:45 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    If original battery on your 2015, time to replace that. Could be a bad cell, even if newer.
    If battery checks out ok (you need to do a load test), then you will need to start checking for parasitic drain somewhere. Not hard, but a bit tedious.
    https://www.youtube.com/watch?v=lRcj1fQcWwU
    HulkSmurf14 likes this.
  4. Nov 3, 2021 at 10:46 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    My Tundra battery didn't last very long on any generation I had. I ended up buying an X2 and haven't had any problems since.
    HulkSmurf14 and AZBoatHauler like this.
  5. Nov 3, 2021 at 12:49 PM
    2mchfun
    Check for rodent damage too, might not be charging when you do drive.
    frichco228 likes this.
