Battery Drain
Discussion in '2nd Gen Tundras (2007-2013)' started by Ruffman, Oct 27, 2021.
  1. Oct 27, 2021 at 12:45 PM
    Ruffman
    Ruffman [OP] New Member
    Daulton
    Tundra 2009 lifted 5.7 Crewmax
    lifted air shocks
    I'm having to keep a charger on my 2009 Crewmax Tundra. Not constantly because I don't want to cook my battery which is fairly new.
    How do I find what is causing this drain on my electrical system? It may be getting worse. I avoid driving it because of the cost of gas.
  2. Oct 27, 2021 at 12:56 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Saltyhero13 likes this.
  3. Oct 27, 2021 at 1:10 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Put a clamp-on current probe around the wire(s) coming off of the + battery terminal and start pulling fuses. Look at the reading each time you pull one. That’s where I would start.
    wakeboarder and Filthyphil like this.
  4. Oct 27, 2021 at 1:14 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    That’s a very old, but very effective way to find a parasitic battery drain. I always started with all the 15A fuses first since that is where usually found the most problems.
  5. Oct 27, 2021 at 2:02 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    How about we start by finding out if you actually have parasitic drain? Your battery could just be shit.
    Unhook your positive terminal. Put a multi meter between your cable and the positive terminal. Allow some time for the truck to go to sleep and measure how much current draw you got. Report back what you measure.
  6. Oct 27, 2021 at 2:31 PM
    Danny3737
    Good point. He could actually have one of the cells starting to go bad.
  7. Oct 28, 2021 at 5:36 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    Using a battery "maintainer" continuously won't "cook" your battery (it might actually increase the life of your battery). My Tundra sits for weeks at a time and a "smart" charger is connected to the battery all the time. There is some normal parasitic drain on the battery when the truck is just sitting.
  8. Oct 28, 2021 at 12:10 PM
    Ruffman
    Daulton
    lifted air shocks
    Thank you all for your suggestions. Makes sense and I'll start doing those things. I'm kind of retarded when it comes to electrical issues, which I shouldn't be at my age. I have the multimeter but not very competent with it.
    My Tundra is a 2009 with about 97.5 thousand miles and, I'm surprised that my battery was purchased in Dec 2019. Maybe it is weak. I buy so many batteries it's hard to remember when I buy them and for what. I do have the charger on right now. Maybe I should look for a maintenance charger to keep on it.
    Other question was do I have any new electrical component that were installed about the time I started having problems. I bought one of those android Chinese radios I still can't figure out, new mirrors for towing, and a couple of cameras, front and back, so something could be up with those.
    Thanks for your suggestions as they are very welcome. Y'all have a good day.
  9. Oct 28, 2021 at 4:42 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    1.) are battery terminals clean an tight
    2.) -V does the battery when charged sit around 12.8V (the - flat line V is DC ~V is AC)
    3.) when the Tundra is running is the Battery getting 13.2V to 14.8V
    after preforming these let me know the answer, an we can go from there.:)
  10. Oct 28, 2021 at 6:16 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome.. Any pics of 09' Rig?
  11. Oct 29, 2021 at 4:32 PM
    Ruffman
    Daulton
    lifted air shocks
    Thanks for your reply. Good points to check.
    Terminals are clean and tight. I will have to go out and check those things with a meter but I do appreciate that. I've been outside cutting trees in my yard and doing other manly stuff. I need to go put the charger on it so that will be a good opportunity to check.
    Reply to Toyofan; I don't have a picture handy. It's silver and jacked up 6 inches. It has the 5 ft bed which irritates the heck out of me. Have to use a trailer to go get building materials. I use the truck to pull a 30 ft trailer which it does just fine. It needs some new 30" tires at this point. I've had a lot of complements on it. My grandson uses it more than me. I need, and am looking for, a camper shell so I can take my dogs with me.
