Battery company installed new battery backwards 2017 Tundra
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by jwMike97, Oct 7, 2023.
  1. Oct 7, 2023 at 4:38 PM
    jwMike97
    jwMike97 [OP] New Member
    2017 Toyota Tundra CrewMax SR5
    Garage installed new battery backwards at first. Now other than being able to start the vehicle, none of the interior electronics work including the accelerator. All dash warning lights are on. Cannot shift out of park without using the manual release. HELP!
  2. Oct 7, 2023 at 4:50 PM
    Have you called the garage? They are going to be responsible for a few things....
  3. Oct 7, 2023 at 4:51 PM
    Vizsla
    Vizsla 2 = 2.5
    Connecting the battery backwards blows the main fuse block buried in the under hood fuse box, not an easy job to replace. There is a window in it that you can try to see through to verify. Wouldn’t hurt to check other fuses, maybe get lucky?
    Black Wolf and jwMike97[OP] like this.
  4. Oct 7, 2023 at 4:51 PM
    jwMike97
    I was at the garage when it happened and made them fully aware of what their employee had done. Thanks!
  5. Oct 7, 2023 at 4:55 PM
    jwMike97
    ive checked all fuses under the hood. Tomorrow I check all the fuses behind the driver side kickplate. Additionally, I will test the 100 amp fuse under the hood. But visual inspection it doesn’t seem to be blown. What really aggravates me is generally, I know better than to let anybody else touch my truck!
    Retired...finally likes this.
  6. Oct 7, 2023 at 5:02 PM
    Vizsla
    Vizsla 2 = 2.5
    Not my picture, but circled where the main fuse block is. Hard to see through the windows, especially after a few years worth of dirt and dust. There is more than one fuse in the block.
    NewImprovedRon likes this.
  7. Oct 7, 2023 at 6:10 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    You'd probably get a better response on this if you post in just the general 2.5 thread (not the Pro thread)...
    Good luck on a quick and easy resolution; hopefully they didn't fry anything beyond a fuse or a relay or 2 :thumbsup:
    Black Wolf likes this.
  8. Oct 8, 2023 at 3:19 AM
    jwMike97
    And if I understand correctly, to get that fuse link out you have to remove the entire fuse block and access the link from underneath???
    Ruggybuggy likes this.
  9. Oct 8, 2023 at 6:10 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    I would have my truck towed to the closest Toyota dealer, have them repair the fuse block, and give the bill (+ tow charges) to the garage that did it.
    rodm1 and Black Wolf like this.
  10. Oct 8, 2023 at 6:11 AM
    coTony
    Tony
    Montrose, CO
    Look for the ground straps that connect the body to the engine. There is one on the passenger side under the air cleaner section and another on the drivers side. They usually take the load first so that may be the cause or contribute to the cause. They would be either burnt in half or severely burnt
  11. Oct 8, 2023 at 6:14 AM
    This^. Seems the offending garage is of no concern.
  12. Oct 8, 2023 at 8:28 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Unless they didn't use an 'F' battery, I don't know how this is even possible.
    The POS cable won't reach the NEG battery post..
    Doesn't matter which way the battery is positioned, the cables are extremely short..:confused:
    At least that is how my 2014 is setup.
