Base SR radio, adding amp....
Discussion in 'Audio & Video' started by Eric32444, Apr 10, 2019.
  1. Apr 10, 2019 at 12:10 PM
    Eric32444
    Eric32444 [OP] "Pick up your balls and load up your cannons..."
    Eric
    Panama City FL, Lynn Haven
    apparently my base SR truck has no amp....will the plug and play harness adapters available for the non-JBL radios with amp work for me? I will be wiring up directly to back of HU...
    I am thinking I am going to have to go with a general "Toyota" harness or cut harness as needed...
    I will be wiring from Factory HU to in dash Clarion EQ ( which has built in LOC inputs ), then to aftermarket amp....then out of amp back to the dash to utilize factory wiring out to doors....
    anyone add an amp to a base model with no factory amp?
    thanks for any help!
  2. May 1, 2019 at 4:30 AM
    18TRDSport
    18TRDSport New Member
    Western Mass
    2018 TRD Sport Sequoia in White
    Window tint, terrainContact AT tires, skid plate, less restrictive muffler and TRD air cleaner
    Interested...how did you make out?
