Banging drivers side after 6112 install
Discussion in 'Suspension' started by Spitfire, Feb 8, 2020.
  1. Feb 8, 2020 at 8:43 AM
    Spitfire
    Spitfire [OP] New Member
    Long Island
    2018 Cement Limited Trd off road
    Just had my 6112s installed at 1.3 setting. Was driving today and did a hard left turn in a parking lot to turn around into a spot. There was a banging noise coming from the drivers side. There was a bit of slope to the parking lot.
    Any ideas? Thx
  2. Feb 8, 2020 at 8:49 AM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Did it do this one time only? If so, perfectly normal, occurred on my Tundra and 4Runner with the 6112 setup. The coils needed to fully seat themselves in the top hat bearing you are using. In my case, I used a KYB top hat bearing for both, so I could keep my OEM coilovers intact.
  3. Feb 8, 2020 at 8:54 AM
    Spitfire
    Long Island
    It's the first time I went full lock with them on. And turned into a slope. It happened again when I turned again.. drove around in circles twice. Lol.. had to get into a bday party with my kids so I'll see if it continues
    georgiey22[QUOTED] likes this.
  4. Feb 8, 2020 at 9:02 AM
    georgiey22
    Keep us posted? If it is full lock and occurs more than once, I’d be more concerned with one of your bolts not being fully torque correctly. Or, wheels coming in contact with something like the skid.
    15whtrd likes this.
  5. Feb 8, 2020 at 9:20 AM
    Spitfire
    Long Island
    I will.. tires are still stock no modifications there
  6. Feb 8, 2020 at 9:50 AM
    georgiey22
    Good, easy to eliminate the offset of after market wheels.
  7. Feb 8, 2020 at 9:52 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Did a shop install or you?
  8. Feb 8, 2020 at 9:52 AM
    georgiey22
    It should be something like an inaccurately torque bolt then. The 6112 doesn’t include a sway bar spaced or anything, so it’s really a factory replacement. Who assembled your shocks/coils?
  9. Feb 8, 2020 at 10:14 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I bet it’s not torqued down and the springs is separating and slamming. You got picks. Especially if the top bolts and main shaft nut
    15whtrd likes this.
  10. Feb 8, 2020 at 10:21 AM
    rustytoys
    rustytoys New Member
    Possibly top hat bolts not tightened so coilover is slamming into shock tower like TundyFundy said. Or, possibly sway bar bolt left off. Or, even lower main coilover bolt left off. Or, depending on how they installed - like if they popped the top control arm ball joint on the spindle - perhaps they tightened by hand but forgot to torque it and seat the ball joint on the control arm.
    How do you like the ride of the 6112 at 1.3 setting otherwise?
    15whtrd likes this.
  11. Feb 8, 2020 at 10:28 AM
    Spitfire
    Long Island
    Got it assembled through boss 4x4.. and then shop installed...like the 1.3 setting so far
  12. Feb 8, 2020 at 10:30 AM
    rustytoys
    I'm fairly positive the shop screwed something up and either left a bolt off, or hand-tight at most.
    The coilover top hat bolts are the most likely candidate - I have almost forgot to those a few times myself. Go out in your driveway and stick your hand on top of the shock tower and see if any of those four nuts are loose - to make a banging noise were talking very loose, you should be able to turn them by hand easily.
    15whtrd likes this.
  13. Feb 8, 2020 at 10:47 AM
    Danman34
    Danman34 New Member
    Danny
    Most shops just tighten a couple uggu’s. They rarely put a torque wrench on stuff like this. Somethings probably not torqued down properly
    15whtrd likes this.
  14. Feb 8, 2020 at 12:18 PM
    Spitfire
    Long Island
    Seems like everything is tight.. of course the shop is closed and not open tomorrow either.. shouldn't not drive truck? Wish I could upload the video with the sound
  15. Feb 8, 2020 at 1:04 PM
    Spitfire
    Long Island
  16. Feb 8, 2020 at 1:04 PM
    Spitfire
    Long Island
    Another
  17. Feb 8, 2020 at 1:07 PM
    Danman34
    Danman34 New Member
    Danny
    You’re not going to visually see if anything is lose. You won’t know till you put a torque wrench on it and see what the nuts and bolts are at.
  18. Feb 8, 2020 at 1:26 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Try jacking up the truck and see if anything contacts oddly or clunks. Is it my eyes or does the washer on the top center shock nut look bent
    15whtrd likes this.
  19. Feb 8, 2020 at 1:39 PM
    Danman34
    Danman34 New Member
    Danny
    im with him. Something does look odd with that center nut. Here’s mine.
    15whtrd likes this.
  20. Feb 8, 2020 at 1:58 PM
    Spitfire
    Long Island
    Better pic of center nut
  21. Feb 8, 2020 at 1:59 PM
    Spitfire
    Long Island
    Looks like it's way further down the nut unless yours wasnt tightened yet. Both sides look identical from my eye
  22. Feb 8, 2020 at 2:11 PM
    georgiey22
    Appears there is a missing nut on the rear coilover bolt.
    Black@Blue19 and NewImprovedRon like this.
  23. Feb 8, 2020 at 2:13 PM
    Danman34
    Danman34 New Member
    Danny
    Um. You’re missing a nut....
    Or is it behind something?
    eirher way, you need to put a torque wrench on there and see what you have
    Rica25 and georgiey22 like this.
  24. Feb 8, 2020 at 2:13 PM
    Danman34
    Danman34 New Member
    Danny
    mines on a higher setting.
    Rica25 likes this.
  25. Feb 8, 2020 at 2:19 PM
    georgiey22
    OP - you may also want to look closely at your cam towers? Looks like they may be leaking based on the photos you’ve posted.
    TheBeast and Rica25 like this.
  26. Feb 8, 2020 at 2:20 PM
    georgiey22
    Here are mine with 10,000 miles and lots of dirt.
    TheBeast likes this.
  27. Feb 8, 2020 at 2:28 PM
    Spitfire
    Long Island
    Yeah now that I mention it.. looks bad.. wtf
  28. Feb 8, 2020 at 2:30 PM
    georgiey22
    Don’t sweat it, it’s fully warrantied. How does the driver side look?
  29. Feb 8, 2020 at 2:40 PM
    Spitfire
    Long Island
    That is drivers.. passenger looks better but only have a blurry pic.. dark now
    Rica25 likes this.
  30. Feb 8, 2020 at 2:41 PM
    rustytoys
    You may be missing a top hat nut (though I think its just the angle of the pic), but either way I don't think that would matter - you have three tight ones - its not going to bang around like that.
    The sway bar, lower coilover bolt, top hat bolts, coilover assembly and top control arm ball joint - all look fine.
    It's so hard to say without hearing the noise, if its not too loud maybe its just the sway bar creaking a bit from the geometry change of being higher?
    NomadicFrog likes this.
