Banging and clanking when accelerating from a stop
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by JDEtundra, Mar 14, 2023.
  1. Mar 14, 2023 at 7:34 AM
    JDEtundra
    JDEtundra [OP] New Member
    I have a 2016 tundra trd. The issue I have not been able to find an answer for. So when stopped and accelerating normally off the line, the truck makes a bunch of banging, clanking, random noise from frontend and I also notice a sluggish feeling in gas peddle like truck has no power little. This only happens at speeds between stopped to 20mph. It then goes away after that. It also is random, doesn't happen every time, can do it two times then may not happen again for several stops. occasionally like twice now, it flashed the traction control light for second then it would go out. I can not see anything out of place and or broken. I checked belts, fluids, and connections. No codes present. Engine idles fine in neutral and when taken to higher rpms and held there is no issues. Please help.....
  2. Mar 14, 2023 at 7:52 AM
    Refusuck
    Refusuck New Member
    Si Tres
    Arch Cape OR
    2021 TRD Pro
    What's the history of the vehicle? Mileage? Maintenance? Modifications?
  3. Mar 14, 2023 at 7:54 AM
    JDEtundra
    2016 with 109k, maintenance is always taken care of by me. Everything is kept clean and new. No mods.
  4. Mar 14, 2023 at 7:57 AM
    CookieMonsterTundra
    CookieMonsterTundra New Member
    Trip
    2018 1794 Tundra
    My first though is something to do with the 4WD engagement. Assuming you are in 2WD, cycle in and out of 4WD to see if this affects the symptoms.
  5. Mar 14, 2023 at 8:02 AM
    JDEtundra
    So it is a 4WD, I have driven it in 4WD to see and could not duplicate sound and feel the two times but could not get it to make the sound and feel. But yes I am normally in 2WD when this sound and feel presents itself.
  6. Mar 14, 2023 at 8:09 AM
    Refusuck
    Refusuck New Member
    Si Tres
    Arch Cape OR
    2021 TRD Pro
    So your traction control light flashed every time this situation occurs? Have you added larger tires or wheels or a lift kit recently?
  7. Mar 14, 2023 at 8:12 AM
    JDEtundra
    The traction control light only has done it twice out of the ten times or so. No lift and no tires changed. same setup have had for life of truck.
  8. Mar 14, 2023 at 8:25 AM
    Refusuck
    Refusuck New Member
    Si Tres
    Arch Cape OR
    2021 TRD Pro
    Throttle body / MAF ever been cleaned? You're positive the truck doesn't throw codes? Have you ever had any codes thrown?
  9. Mar 14, 2023 at 8:28 AM
    JDEtundra
    Ok so failed to mention, has a K&N filter installed, but it has been for years. I did clean MAF at the time of install. I am not aware if ever had codes prior to this, this is the first time having a issue with truck. But when trying to check codes, no DTCs present
  10. Mar 14, 2023 at 8:36 AM
    Refusuck
    Refusuck New Member
    Si Tres
    Arch Cape OR
    2021 TRD Pro
    I'd start with the cleaning of the MAF and TB.
  11. Mar 14, 2023 at 8:40 AM
    JDEtundra
    Could that explain the noise? Would it make the truck have such a random noise? Thanks for the input and help with this
  12. Mar 14, 2023 at 8:46 AM
    Refusuck
    Refusuck New Member
    Si Tres
    Arch Cape OR
    2021 TRD Pro
    Hard to tell - you said it goes away after about 20 mph and is random. If it was a constant banging and clanking noise all the time I would think that would be something else. The one thing that is unusual is the traction control light coming on, but not everytime. So I'd do the things that are easy and see what happens.
  13. Mar 14, 2023 at 8:50 AM
    JDEtundra
    I agree this is odd. the fact it could happen 3 stops in a row and then go away for next 5 or so is what is confusing me. I called Toyota about this and for them to look at it they want 144.85 a hour. I could only imagine this could be hundreds to figure it out before the fix.
  14. Mar 14, 2023 at 8:51 AM
    GNTundra
    Gino
    2013 White
    You grease and maintain the driveline support bearing?
  15. Mar 14, 2023 at 8:59 AM
    JDEtundra
    yes but I been looking at the carrier bearing and play, I may change it soon. I still think that it is ok. the sound comes from way up front. Plus I feel no vibration like that would cause, at least what i think.
    GNTundra likes this.
  16. Mar 14, 2023 at 9:14 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Might be worth looking at all of your abs sensors for damage or looseness.
    The ABS makes terrible sounds from under the hood when activating. Also would cause the Trac light to flash as the truck believes a wheel is slipping.
  17. Mar 14, 2023 at 9:18 AM
    JDEtundra
    Thats worth looking into for sure. I will give ABS sensors and MAF a look and see.
  18. Mar 15, 2023 at 8:13 AM
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    added power mirrors, auto fold mirror, 2019 TRD head and FOG lights, FORTIN remote start, retrax tonneau cover, 18" fuel BFGK02, TRD sway bar, TRD intake
    step 1
    i think you need to determine is it engine or chassis..
    how many miles? do you off road?
    (banging and clunking) is a little vague....
    might suggest you jack front end and shake wheels... see what's loose..
    if your not getting any codes... might inspect mass air flow sensor, remove and clean.. especially if your using a oil based K&N or trd filter
  19. Mar 15, 2023 at 8:21 AM
    JDEtundra
    I cant determine engine or chassis. it sounds like very front kind of right side when noise occurs. It also has a sluggish feel to it when starts with noise. this happens from stop to 20mph. doesn't happen every time. I dont off road truck. its well taken care of and maint. I jacked it last night and checked wheels, spun free, did not shaking when pulled on. this truck has 109k on it. I pulled MAF last night, looked clean, little lite haze, I cleaned and stuck it back in. Problem still there..
  20. Mar 15, 2023 at 8:23 AM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    Does it feel like you’re going over a rumble strip? Could it be transmission related?
  21. Mar 15, 2023 at 8:24 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    try turning on 4wd and see if it makes the issue go away.
  22. Mar 15, 2023 at 9:04 AM
    JDEtundra
    drove with 4WD and got it to do it one time. So 2WD and 4WD does it, but its so random. drove it last night, got it to do it twice and then would not happen again and tried like 20 times. thats why I am at a loss.
  23. Mar 15, 2023 at 9:06 AM
    JDEtundra
    does not feel like rumble strip, it smooth, when sound happens its just a clanky, banging noise thats inconsonant with a hesitation in power feel.
  24. Mar 15, 2023 at 9:06 AM
    Bad CV joint?
  25. Mar 15, 2023 at 9:09 AM
    JDEtundra
    CV joints appear to be good. No rips in boots and I dont hear or feel vib or anything.
  26. Mar 15, 2023 at 10:28 AM
    MadMaxCanon
    have you checked your wheel bearings for play?
    Edit: Just saw that you checked the wheels for play.
    Maybe try torquing all of your suspension and chassis bolts in the general area? I saw a vid where there was alot of noise and play on the front of a car and 2 of the front subframe bolts were loose from a recent service and that solved the problem.
    Also, have you checked your driveshaft for play/loose bolts? How does your carrier bearing look?
  27. Mar 15, 2023 at 10:35 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Any chance its coming from the rear? I had a braking noise, and I swore it was out of the front, turned out it was a rear disc that had cracked, and took my caliper with it... It was on the inside/backside, All I could see from the outside once it failed was the brake pad waving at me.
  28. Mar 15, 2023 at 10:39 AM
    JDEtundra
    So i looked at all suspension last night, nothing appeared loose. drive shaft and carrier bearing look good as well, I checked play and I assuming in tolerance. But with that, its a noise that only comes up randomly. its not constant. so that is where I don't get this. Also all noise is right up front almost right side sounds.
  29. Mar 15, 2023 at 10:44 AM
    blackdemon_tt
    Have you done suspension upgrades? If so I would check the sway bar. My brake issue was random, but all I'm suggesting is pulling your rotors and inspecting them... Nothing worse than losing your brakes in heavy traffic like it happened to me.
  30. Mar 15, 2023 at 10:44 AM
    MadMaxCanon
    im wondering if it might be your steering rack or front diff? Do you use 4wd relatively often? Do you get any noise when you turn the wheels? Did you check sway bar links and bushings and skid plate hardware?
