Bamufflers systems differences and which one to go with.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Doxiedad, Jan 12, 2020.
  1. Jan 12, 2020 at 5:25 PM
    Doxiedad
    Doxiedad [OP] Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    So on my 2020 Crewmax with the 5.7L I've searched on here and decided that i really like the sound the Bamuffler from dirty deeds industries.
    My question is fitment and which set to go with. I was looking at either the standard 8" system or the Toyota TRD replacement system.
    It looks like the standard 8" system has one exhaust exit in stock location past the rear tire. I don't care about shiny exhaust tips and such.
    The TRD replacement system has an exhaust exit behind each rear wheel, I kinda like this better appearance wise, but not set on it.
    I'm guessing the mild setup for the TRD will sound about same as 8" system?
    I'm 40+ and don't want/need an obnoxiously loud exhaust that drones.
    Which setup would be best for me?
    Thanks.
    Rica25 likes this.
  2. Jan 12, 2020 at 5:41 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    The 8” bolts to factory pipes after the cats and ties in to the stock tail pipe after the mufflers. I would assume 8”or 10” would be what your after. I have the 6” and it’s definitely louder then stock. You can call Keith and he will walk you through it. Great guy.
    I go a little extra when I install my Dirty Deeds systems and paint the factory tail pipe section to match. I have never heard the TRD replacement system so can’t speak to that.
    Pictures just cause...
    tundra_20, Rica25 and Doxiedad[OP] like this.
  3. Jan 12, 2020 at 5:51 PM
    Doxiedad
    James
    Charleston, SC
    Awesome, thanks. Is it pretty easy to install? Any welding required? I may wind up going with that when i upgrade. Want upgraded sound but not necessarily new shiny tailpipe. Thanks for awesome pictures
    Juanjoolio007 and Rica25 like this.
  4. Jan 12, 2020 at 5:59 PM
    Doxiedad
    James
    Charleston, SC
    so looking at your pics and the pic on their website after the mufflers when they converge to that flange, everything after that will be the stock pieces? In this picture the bottom 3, on the right is the front of the truck where it connects to the cats, then the mufflers, and to the left is where I would attach my stock tailpipe assembly?
    Attached picture is from their site
  5. Jan 12, 2020 at 6:04 PM
    Rica25
    Ricardo
    Tulare
  6. Jan 12, 2020 at 6:05 PM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Yes that’s correct. Check out this link (http://dirtydeedsindustries.com/product/standard-8-system/), watch the first video near the bottom. It will show you exactly how it ties in.
    Rica25 and Doxiedad[QUOTED][OP] like this.
  7. Jan 12, 2020 at 6:16 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Unless you have the TRD dual exhaust setup, you want the 8” standard system. They are not interchangeable systems.
  8. Jan 12, 2020 at 6:20 PM
    Juanjoolio007
    Oregon
    Really easy install. It’s easier if your truck is lifted but not required. I just did it in the driveway with no jacks. Just slide under there. No welding but you do need a 2” hole saw bit to drill the resonator hole. That part takes the longest. You have to fit the resonator then mark the flange and pull out the tailpipe to drill it.
    Rica25 likes this.
  9. Jan 12, 2020 at 6:33 PM
    Doxiedad
    James
    Charleston, SC
    I watched the install video and it didn’t look bad. Should be able to do in driveway.
    The resonator looks a little tricky though.
    How bad is it without the resonator?
  10. Jan 12, 2020 at 6:36 PM
    Rica25
    Ricardo
    Tulare
    Resonator is easy with a hole saw takes just a few minutes
    AZBoatHauler likes this.
  11. Jan 12, 2020 at 6:38 PM
    AZBoatHauler
    So.Arizona
    IMO, you’ll want the resonator. It is also simple. 2” hole saw and about 10 minutes if you take the time to remove the tail pipe to drill the hole.
    Rica25 likes this.
  12. Jan 12, 2020 at 6:41 PM
    Doxiedad
    James
    Charleston, SC
    Ok so maybe I’m confused with video. When he was installing tailpipe section he mentioned seating the gasket by turning and tightening. Would you instead line it up and then mark And cut hole without tightening it up to flange and gasket? Or seat gasket then mark and remove to cut hole.
    AZBoatHauler and Rica25 like this.
  13. Jan 12, 2020 at 6:43 PM
    Rica25
    Ricardo
    Tulare
    I marked mine on the truck let it sit and marked the out line of the saddle and then pulled of tail pipe and cut on the ground
    WFD473 and Doxiedad[OP] like this.
  14. Jan 12, 2020 at 6:43 PM
    Juanjoolio007
    Oregon
    I marked the resonator location before removing the stock system. Then I forgot I did that and painted the tail section.:frusty:. So I had to put it back in, mark it again, then drill the hole. Still took less time then letting the paint dry to the touch.
    Doxiedad[OP] likes this.
  15. Jan 12, 2020 at 6:45 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    I drilled the resonator in about 30 seconds with a kobalt hole saw....very easy...usually everything I touch turns to crap but the entire install was easy
    Rica25 likes this.
  16. Jan 12, 2020 at 6:45 PM
    Juanjoolio007
    Oregon
    I think Keith did it that way cause he has a plasma cutter. I would imagine it would be a huge PITA to drill with the pipe in the truck.
    Rica25 likes this.
  17. Jan 12, 2020 at 6:46 PM
    Doxiedad
    James
    Charleston, SC
    Ah yeah that does seem like a smart way to do it (minus the painting)
    thanks
    Juanjoolio007[QUOTED] and Rica25 like this.
  18. Jan 12, 2020 at 7:27 PM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    I tightened everything up and cut the 2" hole while the pipe was still on the truck. It wasn't that bad...
  19. Jan 12, 2020 at 7:55 PM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    His system bolts up to the stock piping. If you want TRD replacement, you have to purchase the dual exit.
    8" should sound awesome but if you tow, he will recommend 10"
    Where are you located, maybe someone local can help you as well!
    Rica25 likes this.
  20. Jan 12, 2020 at 8:17 PM
    Juanjoolio007
    Oregon
    well that’s good to know in case I get another new Tundra/DD exhaust. I should also get a new hole saw bit cause mine sucks. Haha
    Rica25 likes this.
  21. Jan 14, 2020 at 7:07 AM
    pop's
    pop's 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
    Rica25 likes this.
  22. Jan 14, 2020 at 7:15 AM
    pop's
    pop's 1794
    Michael
    North Aurora IL
    $7500 in upgrades
    I went with the TRD exhaust and am keeping my original just incase. The TRD is a Toyota product and won't mess with your warranty, The sound level is just right under all loads. You should buy it at your Toyota dealer for around $1150 out the door no shipping cost. I'm 57 years old.
    Yota100 and Doxiedad[OP] like this.
  23. Jan 14, 2020 at 7:33 AM
    Cfincke
    San Antonio
    I went with the TRD replacement and had keith make turn downs that dumps before the rear axle.
    Flyinryank, tundra_20 and Rica25 like this.
  24. Jan 14, 2020 at 8:25 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    My truck sits lower than most, and it was pretty easy for my old self to slide under the truck, drill the hole in the tail pipe and install the resonator. Having already relocated the spare to the bed several months prior to installing the cat back, I had plenty of room.
  25. Jan 14, 2020 at 9:46 AM
    Juanjoolio007
    Oregon
    Huh... who would have thought the absence of that spare tire would give you more room..
    I took the wife’s out on her 4Runner the day before when I did hers. Turns out that is a useless step as it gives you no more room so I left it in on the Tundra. Plus I was painting mine anyway.
    Rica25 likes this.
  26. Jan 18, 2020 at 5:40 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Has anyone purchased a 12 inch system? I have seen vids and reviews of the 6, 8 and 10....would love to hear more about a 12 inch standard system.
    Kbrdbnt and Rica25 like this.
  27. Jan 18, 2020 at 5:42 PM
    paradizecityz
    Richmond, TX
    since you’re looking at 12” system, I’m assuming you’re thinking more of incab noise?
    I asked Keith as I was hesitant ordering the 10”, was thinking of going to 12”, but he said as far as incab, they’re both about the same. Maybe lose a little bit more on the outside though
    Rica25 likes this.
  28. Jan 18, 2020 at 5:50 PM
    18" TRD Off Road Wheels
    A catback exhaust won't cause you any warranty issues. If you replace anything from the cats forward they might be able to deny a claim, but only on stuff that it could have caused. You're warranty isn't something that can be voided either. They can deny claims if they can reasonably prove that your modification caused the problem, but it's not a single thing that you can "void" with a mod. For example, if your transmission died on you after you put in a new exhaust they cannot deny that warranty claim because the exhaust did not cause the transmission to fail. Do a search on the Magnusson Moss Act (might have the exact name wrong) and you can see that the dealer talk of voiding warranties is a scare tactic.
    yeti23 and Rica25 like this.
  29. Jan 18, 2020 at 7:40 PM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    I had the 12 inch system on my previous Tundra. Feedback below is based on using tailpipe resonator. Never tried without.
    The 12 has a deeper tone compared to stock, with a slight increase in interior volume. Under acceleration, it has a subtle growl, which levels off at around 3000 rpms +/-. The sound doesn’t build throughout the rpm band. It is noticeably louder on the outside compared to stock under heavy throttle. I would put it in between stock and the TRD exhaust on the inside. It pretty much goes quiet around 60 mph when cruising.
    It’s a nice system if you want a deep crisp tone, but not a lot of volume.
    tundra_20 likes this.
  30. Jan 18, 2020 at 8:38 PM
    frichco228
    Thanks for the feedback! Did you do any towing with the 12 inch system? That's really my only concern. Saw a video of the 10 inch and loved the sound but wondered if it may be too much towing a camper for several hours.
    Rica25 likes this.
