BAMF Rambler XL (Hard shell full pop camper)
Discussion in 'Bay Area Metal Fabrication' started by jlee, Aug 27, 2025.
  1. Aug 27, 2025 at 10:48 AM
    jlee
    jlee [OP] New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    There is a new camper hitting the market. Many of you know the failed Vagabond Outdoors company. Well I stepped in to help those that they screwed over get a camper and it did not work out with the patent holder of their designs that's all I can say, So I cut all ties with him and developed my own camper. The BAMF rambler is like no other camper out today. Full aluminum hard side tent construction not cheap composite sides, they are fully framed with 1" 6061 tubing skinned with aluminum sheet. Electric linear actuators to lift and lower the tent not struggling with tent fabric everything folds up nice and tight with a flick of the remote.
    I'm the only company that I know of offering a built in auto system for those that like tunes while sleeping. Or just rocking out with your CO*K out we don't judge.
    https://www.bayareametalfab.com/Rambler-XL-full-size-truck-bed-camper-_p_217.html
    Standard Options Include:
    · 1/8" marine grade Aluminum Construction
    · One-piece solid aluminum Lid
    · Linear Actuators Raise the tent walls and roof
    · Waterproof aluminum Hard side tent
    · LED 3rd Brake Light & Wiring
    · Solid tempered Glass Cab Window Or plexi for weight reduction.
    · Rear aluminum door with tempered glass Window w/Keyed Lock and recessed hidden hinges.
    · Lockable Stainless-Steel Latches for the Lid
    · Camper Attachment Clamps & Bulb Seal Gasket
    Made In the USA
    DETAILS
    Body
    · Laser cut & CNC bent 1/8” 5052 Aluminum 7 panel design with 4 reinforced corners, 1 front panel and 2 sides complete the lower frame.
    [​IMG]· Fully welded panels & stainless-steel bolts & nuts for connection points
    · Sealed panel connections with in house made Butyl rubber gaskets laser cut for an exact fit.
    · The tent frame is constructed from Laser cut 3"x4"x.125" wall 6063 aluminum tubing with relief cut outs for optional fans/storage, power
    · Attaches to truck bed with aluminum clamps and bulb seal.
    Roof
    · Single piece 5052 .125" aluminum reinforced with 1"x1" tubes to handle loads on top of the camper.
    · Havelock Wool insulation with durable light weight interior aluminum ceiling panels.
    · Linear Actuators and hinges recess into the camper when closed.
    Tent
    · Full pop hard sided folding panels make up the tent. Waterproof, durable, 1x1 tube framed with 16 gauge aluminum outer skins (With optional insulation)
    · 30 gauge clear Vinyl side and rear windows.
    Sleeping Platform
    · Bed platform can be lifted to fully lift the bed out of the way for full use of living space.
    The suspended Laser cut formed aluminum bed slats create a floating like support under the mattress, breathable as well keeping the under side of the mattress dry.
    3" thick 2 layered Memory Foam Mattress made by FOAMMA with Water Resistant Organic Cotton Cover, 1" memory foam top with a 2" Firm High Density Foam Base, USA Made, CertiPUR-US Certified
