Ball Joints vs Uniball UCAs on your 1st Gen?
Discussion in '1st Gen Tundras (2000-2006)' started by Mctodd, Sep 13, 2020.
  1. Sep 13, 2020 at 12:58 PM
    Mctodd
    Mctodd [OP] New Member
    Todd
    Nor Cal
    2003 SR5 4wd TRD
    F. Fabtech Dirt Logic 2.5, Icon 1.5 Add a Leaf pack, BFG KO2s 285/75/17, 1.25 Spydertrax, SPC UCAs.
    Hey Everyone,
    I'm needing to replace the ball joints on my stock UCAs and looking to make the plunge and upgrade. There's a lot out there debating the merits of something like the SPCs with a ball joint vs switching over to a uniballs (Total Chaos or Camburgs), but most of the talk is on taco forums or for later version Tundras. It ain't cheap so I'd like to hear from some first gen tundra folks to hear what your running and what you liked/didnt and why.
    I've got an 03 SR5, 2" lift up front, Icon Add a Leaf in the rear, and running 285/70/17s. It's a daily driver for me so i see a lot of road miles but try to get out in the dirt on the wknds as much as possible. The old girl has a lot of mile (220ish) but looking to keep building out and eventually turn it into more of an off road adventure rig.
    Thanks for the your insights and opinions
    Darkness likes this.
  2. Sep 13, 2020 at 2:27 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I live in Southern California :hattip:
    I've been running Camburg since 2010 and no real trouble to speak of other than for the first month they groaned like hell whenever I turned the steering wheel. Once that went away all was good. I just replaced the bushings and balls around December 2018, hope to see another decade of use.
    Important note about them is you might have seen complaints about ball squeak. I am pretty sure that was from the original design where they used Aurora balls. Like I said mine groaned the first month, when i replaced the balls I went with the newer FK balls (standard now on new arms) and not a bit of noise.
    Not sure what part of California you're in but I don't drive on any salted roads in my truck. I've done the occasional run up Big Bear or Shaver Lake but I rinsed after getting home.
    Back when I bought Camburgs they were $599 and TC were $750, there were no other options. Now both of those prices would be considered a steal and there are options like SPC or JBA. Several members here happily run those.
    bmf4069 likes this.
  3. Sep 13, 2020 at 2:30 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I went with SPC primarily because of cost. So far, no complaints. But I have heard of some people experiencing premature failure of the SPC ball joints. JBA just started offering UCA's for our trucks and I've heard good things.
    I will say that if you go with uniballs you may have to grind down the edge of the bucket. Total Chaos for several people and at least one person with Camburg. Though others with Camburg said they clear.
    https://www.tundras.com/threads/first-gen-spc-mevotech-upper-control-arms.60591/#post-1588027
    Here is a picture of where they might touch. It's really not a big deal but made me wonder how they managed to screw that up.
    SouthPaw, bmf4069 and Darkness like this.
  4. Sep 13, 2020 at 11:20 PM
    Mctodd
    Todd
    Nor Cal
    2003 SR5 4wd TRD
    thanks guys gents.
    I'm up in Sacramento so I do a little driving in snow/salt when i head up to Tahoe but not a ton.
    @Darkness I had read a few folks complaining about the noise issue with Camburgs but it sounds like that may have been addressed so thanks for the info. The price point is certainly a little more agreeable with them then the TCs, do you any other big differences other then the name?
    Also have you found you've had to do much regular maintenance with your camburgs? from what i'm reading it seems like the Uniballs were built for more 4x4 racing applications where you'd be tearing things down and rebuilding fairly regularly. Given i'm running mine as a daily driver and don't really want to be under there making sure they're not getting all jammed up they may be overkill for me at this point.
    As for the SPCs, they also seem pretty great, and certainly a more favorable price point. How long have you been running yours @FirstGenVol? Thanks for the heads up on potential fitment problems
    Anybody else out there weigh in on the up/downsides of Uniball vs Ball joints, or the SPCs vs JBAs (I hadn't seen much on these so i'll be looking into them
  5. Sep 13, 2020 at 11:30 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I run the uniballs on all my Toyota trucks. My 01 Tacoma had total chaos arms that were put on in 2006. 2013 I rebuilt those arms not because of noise but because they were getting sloppy. 7 years of trouble free life in the salt belt, I only run uniballs now. Tundra has camburgs and I have icon uppers on the 01 Tacoma’s new frame.
    Only maintenance I’ve done is greasing the bushings once a year
  6. Sep 13, 2020 at 11:32 PM
    empty_lord
    05 rollover special
    All that being said the SPC will offer more adjustment. The uni all setups are a fixed increase in castor
  7. Sep 14, 2020 at 5:18 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I've only had mine about 14 months, maybe 7,000 miles. @Festerw has put a lot of miles on his though.
  8. Sep 14, 2020 at 6:33 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    About 35k at this point. Nothing bad to say about them. Ball joints are still tight and tires are wearing evenly.
  9. Sep 14, 2020 at 8:57 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @Mctodd I've heard people say that they need a lot of maintenance, but I don't find that to be true at all. Once a year I loosen the pivot bolt and grease the busings, then tighten the pivot bolt. That doesn't require aligners anything so its a simple maintenance. For the uniballs the first year I had them i would wipe them down after car washes and put a few drops of triflow lube on them. Eventually I got too lazy and stopped doing that, nothing bad happened.
    I too, like Empty Lord, only rebuilt mine because my uniballs were a little worn. Thats not any different than changing a ball joint occasionally except that ball joints are a bit cheaper.
  10. Sep 14, 2020 at 10:50 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I have SPCs that I'm waiting to install on my Tundra, but I ran them on my T4R and loved them. I think its probably personal preference and price. The only thing I've heard is Uniballs don't necessarily do well with salty/sandy conditions and aren't adjustable.
    I'm sure if you hose them off or add a little lube after driving in those conditions they'd be fine.
    I add a little grease to the balljoints on the SPCs every time I do an oil change.
  11. Sep 14, 2020 at 10:59 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I would get ball joints. I have uniball uppers on my 4th gen 4runner and ball joint uppers on my tundra (both camburgs) and the uniballs squeak except immediately after a car wash and lubricating them. Any dirt and squeak city, and I'm on my second set of uniballs so these ones are as fresh as possible. Less maintenance, less cleaning, less noise, same capability from the ball joint and the aesthetics of the two are essentially identical (you wouldn't know the ball joint wasn't a uniball since it's hidden underneath a cap). I see no advantage to uniballs unless it's a high performance application.
  12. Sep 14, 2020 at 4:05 PM
    Mctodd
    Todd
    Nor Cal
    2003 SR5 4wd TRD
    Thanks guys, at this point I'm certainly leaning towards the ball joints. They seem a little easier to maintain, less noise considerations, and easier on the wallet. If was was building a performance race truck it might be a diff story but I'm not, just looking for something tough and reliable.
    SPCs seem to be the go to in this category, reliable, tough and adjustable which I like. I was a little concerned that the adjustability would create more weak points but I haven't read anyone having issues like that.
    The JBAs seem pretty nice too (although not a fan of the red color), y'all know anyone running those on their first gen...it looks like they haven't been making them for too long for Tundras?
    Any other good options out there I'm missing? Looks like ppl like the Icons too but they seem priced pretty high.
    I also came across a video of a dude (Filthy Motorsports?) reviewing UCAs and he had some good stuff to say about the Moog, Problem Solver ball joints. they are pretty cheap and solid according to him? ... i guess they could serve to kick the can a little further down the road and put off dropping a chunk of change on a UCAs this week ;)
  13. Sep 15, 2020 at 5:08 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    @MrAristo just put in JBAs.
  14. Sep 24, 2020 at 7:55 PM
    MrAristo
    MrAristo Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    JBAs are great, greasable uppers/bushings, look sick and very cost effective. Also the JBA owner is a great guy for those who’ve ordered from him should already know.. Haven’t taken off-road just yet but will let y’all know.
    revtune and bmf4069[QUOTED] like this.
  15. Oct 3, 2020 at 6:57 PM
    Mctodd
    Todd
    Nor Cal
    2003 SR5 4wd TRD
    I ended up going with the SPCs for the adjustability. Just finally got them mounted up, after a bit of a battling with the ball joint for a while and running all over town looking for the right press adapters. Now i just need to get them greased up and adjusted before I take it in for alignment.
    SPC recommends 3%-5% moly grease for the BJs. I found some Valvoline Full Synthetic that says Moly Fortified but I can't find the percentage? does anyone out there happen to know or have a recommendation for a different or better grease?
  16. Oct 4, 2020 at 7:15 AM
    Professional Hand Model
    Hand Protectors
    Tried to find the % for you, but no success. I’d use STP Moly EP (extreme pressure) as its readily available and cost about $5 tub. I’ve used it on my drive shaft zerks successfully for years.
  17. Oct 4, 2020 at 7:16 AM
    Hand Protectors
    Post up some pics of your UCA and those required adaptors for future reference.
  18. Oct 4, 2020 at 7:36 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    I've been using this, seems to be working fine.
    https://www.grainger.com/mobile/product/MOBIL-Mobilith-SHC-220-5ZN11?fc=MWP2IDP2PCP
  19. Oct 4, 2020 at 7:53 AM
    Hand Protectors
