Ball Joint Replacement
Discussion in '2nd Gen Tundras (2007-2013)' started by tunderdude, Nov 14, 2022.
  1. Nov 14, 2022 at 7:07 AM
    tunderdude
    tunderdude [OP] New Member
    2013 Tundra 4x4
    DV8 Front Bumper
    Went to dealer for oil change and they tell me I need new upper and lower ball joints.
    My 2013 Tundra has 240k miles and there is a noise in the front end when I go over bumps, so I believe they are due for replacement. Dealer wants a whopping $3500 to do the job, so that's obviously a non starter.
    I'm planning to do the upper and lowers myself and was planning to order OEM parts from the dealer, but they tell me you can't order BJs for that year, you have to replace entire control arms. I know these are readily available at parts stores, but I'd like to get something that is at least as good as OE. My question is, what brand is recommended to replace upper and lower ball joints for my 2013 Tundra (4x4, 5.7L).
    Thanks!
  2. Nov 14, 2022 at 8:34 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
  3. Nov 14, 2022 at 8:36 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    Select suspension/ ball joints
  4. Nov 14, 2022 at 10:53 AM
    tunderdude
    2013 Tundra 4x4
    DV8 Front Bumper
    Thanks for the link.. I'll take a look.
