Bakflip X4 Revolver Seal not sitting flush
Discussion in 'Tonneau Covers, Caps and Shells' started by TundraDrew, Dec 9, 2018.
  1. Dec 9, 2018 at 5:53 PM
    TundraDrew
    TundraDrew [OP] New Member
    Drew
    Hahira, GA
    2020 White Tundra 1794 4x4
    Bakflip Revolver X4, Nitto Ridge Grappler 275-60R20
    Just wondering if anybody with a Bakflip Revolver X4 has had the issue that I'm having with mine and if you have any suggestions to fix it? Bottom line, I can't get the seals to sit flush with the side rails. Yes, I've used a heat gun and left it out in the sun for a couple of weeks now. It seems like the cover sits too low in the rails which flares the seals up too high on the rails for them to be able to sit flush. I've had a X2 before and all it took was a heat gun/sun to get the seals to sit flush, but not with this X4. I've also received a second X4 under warranty, but I'm having the same exact issue. I'm pretty confident that I installed everything correctly and have reviewed the instructions to see if I've missed anything. I have a 2018 CM with bed rails (5'6" bed) for reference.
  2. Dec 11, 2018 at 7:09 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    I just installed mine yesterday. the rail sits flush to the bed rails and precisely close-ish with the tailgate.
    Im assuming you've checked the alignment of the cover? you've checked the X4 rails are level?
    there are alignment shims mentioned in the instructions for down the rails to assist in leveling them, which would effect the cover. My rails just had a single ribbed strip of rubber down the x4 rail so I didnt do anything other than mount them. The instructions say these alignment shims come pre-installed and that you remove the ones per your application.
    Edit: on second look, the x4 rails look pretty good, its the cover thats not sitting in the rail groove. are you 100% sure its aligned right?
  3. Dec 11, 2018 at 7:57 AM
    Bacaboy69
    Bacaboy69 New Member
    2015 Charcoal Grey SR5 Tundra Crewmax 4x4
    When I did mine this weekend, I never had any shims to level. It says "Specific Vehicles" so I am assuming that if they didn't give them to you then your/our trucks don't require them.
    I may be wrong. I am no expert.
  4. Dec 11, 2018 at 8:05 AM
    B737
    Jersey Shore
    yes and it shows shims on the diagram... maybe its for the X2, i ended up just disregarding as none came preinstalled.
    I feel like the only thing that could cause the OPs X4 to be sitting so high is the locking tabs down the side are riding on the rail, there should be 1/8" gap between them and the rail channel where it locks.
  5. Dec 11, 2018 at 10:41 AM
    MikeCim209
    MikeCim209 Not all those who wander are lost.
    Michael
    Woodbridge, CA
    2018 Barcelona Red Metallic 1794 with TRD Package
    None yet, but soon..
    I have the X4 installed and it sits flush with no issues. I can post pics if you would like.
  6. Dec 11, 2018 at 10:58 AM
    Bacaboy69
    Can you do that please. I would like to compare it to mine.
    Thank you.
  7. Dec 11, 2018 at 7:03 PM
    gman31
    gman31 New Member
    New Orleans
    Mine sits flush and still leaks really bad. Needless to say, I'm not happy with this cover at all.
  8. Dec 11, 2018 at 7:07 PM
    B737
    Jersey Shore
    After installing mine I can see how bad this is going to leak too. Not too big a deal but coming from a dry, crappy, cheap vinyl roll up cover....
  9. Dec 12, 2018 at 6:48 AM
    TundraDrew
    Drew
    Hahira, GA
    It's definitely aligned right, and everything is sitting correctly/evenly in the rails and it has no problems locking. The shims were my first thought, but there aren't shims on the rails with the track system, just a rubber strip. I'm going to call the company I bought it from and see if they have any suggestions, otherwise, I'll be returning it. I'll pass on what I find out.
  10. Dec 12, 2018 at 7:00 AM
    B737
    Jersey Shore
    please keep us posted. Here is how mine looks. On the tailgate, the vertical gap between the tailgate and inside seal is about 3/16" and 1/8" on the metal T rail. This thing is gonna leak like crazy but i knew that going in. You can see how much further back the old vinyl cover went onto the tailgate by the dirt line. the X4 only overlaps by maybe an 1/8th.
  11. Dec 12, 2018 at 7:28 AM
    TundraDrew
    Drew
    Hahira, GA
    Well now I feel like I might just be OCD. To me it looks like your seals aren't laying completely flat either. I had the glossy version (X2 Revolver) on my last truck and maybe it just sat down better because it had that smooth surface to stick to instead of the rough surface that the X4 has. I just sent pics to the seller, so I'll see what they think.
  12. Dec 12, 2018 at 7:39 AM
    B737
    Jersey Shore
    I agree, after i went out and looked closely, they actually look very similar.
    They made this nice cover, and its like no thought went into finishing at the tailgate. There needs to be closer tolerances, additional seals and or end caps...
  13. Dec 13, 2018 at 4:55 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    I've had my X4 for about 9 months and have had no issues with the rubber gaskets curling up our not sitting flat. The cover overlaps the tailgate by about 1/2" (I'll check later to make sure) but you can adjust that when installing by making sure it's not too far forward where it meets the cab. The rubber gasket with sticky tape should only be used at the front of the bed near the cab. I didn't use any shims and I don't remember any coming with the cover. I get very minor water leaks.
  14. Dec 13, 2018 at 7:27 AM
    B737
    Jersey Shore
    Thanks Mike, Im gonna unbolt the cover and slide it back some...
    overall i like the design, im sure later revisions will clean things up at the tailgate. The installation is easy, they did a nice job making all the hardware work together and align on the rails. It looks clean, its quieter than the vinyl cover drumming as it flapped away. I like the finish they Bak uses on the x4, time will tell how it holds up to everyday exposure.
  15. Jan 6, 2019 at 11:07 AM
    B737
    Jersey Shore
    Did the seller respond to you since you reached out?
  16. Jan 6, 2019 at 12:03 PM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    @B737 your looks flush to me. I think mine is flush just like yours.
  17. Jan 6, 2019 at 2:16 PM
    TundraDrew
    Drew
    Hahira, GA
    They did and Bakflip sent new seals, but still no luck. I’m in the process of trying to return it right now.
  18. Jan 10, 2019 at 5:56 PM
    TundraDrew
    Drew
    Hahira, GA
    Just following up for anybody interested. I asked for a refund and Bakflip just said to field destroy it and send pics for a full refund, so at least they back up their products. Not sure why the seals wouldn't sit, but in the end, I'll be trying a different style of cover. Maybe a sit on top cover like diamondback. Biggest takeaway for me is that Bakflip has great customer service and will back up their warranty/products. I've had their covers before, this one just didn't work out unfortunately.
  19. Jan 10, 2019 at 6:09 PM
    tstieb
    tstieb New Member
    2014 CM TRD
    If your truck is lifted, I wonder if the Tundra lean could cause the bed to not be level and make the cover not sit properly.
  20. Jan 10, 2019 at 6:15 PM
    TundraDrew
    Drew
    Hahira, GA
    No lift, still factory. I tried to move the brackets up/down/middle and it didn't make a difference either, the rail/cover move together with the brackets. It just seems like a design flaw to me because the cover sat too low in the rails, forcing the seals to flex up. Tried two covers, replaced the seals, used sun/heat gun...nothing worked. The first gen bakflip revolver on my last truck had no issues like this and looked great for years.
  21. Jan 10, 2019 at 6:24 PM
    tstieb
    tstieb New Member
    2014 CM TRD
    Sux man. My cover took quiet a bit of adjusting and still isn't right but I just live with it. Good luck.
  22. Jan 11, 2019 at 8:52 AM
    B737
    Jersey Shore
    I commend them for making the situation right. It seems like the X4 needs more refinement. After seeing the photos in another thread of one cracking at the seams, I dont have a lot of confidence this cover will outlast the cheap vinyl one I replaced with it. It is shocking they are getting a grand for these things...
