Bakflip MX4: F150 will fit Tundra?
Discussion in 'Tonneau Covers, Caps and Shells' started by The Patriot 1776, Oct 12, 2020.
  1. Oct 12, 2020 at 8:44 AM
    The Patriot 1776
    The Patriot 1776 [OP] Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    Will a Bakflip MX4 that’s made for a 2004-14 F150 (5.5” bed) fit a 2016 Tundra CrewMax?
    Thanks!
  2. Oct 12, 2020 at 8:53 AM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Probably not correctly
  3. Oct 12, 2020 at 8:55 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I just went on Bak's website and punched in the specs for each truck; the part number was different for the Ford vs Toyota so assuming they are different. Not saying that they are NOT compatible or interchangeable but they are two different part numbers. I would guess that if they were interchangeable they would be the same part number.
  4. Oct 12, 2020 at 11:24 AM
    The Patriot 1776
    '16 TSS CM 4x4
    I did the same but my assumption was the way they attach is the difference, hence different numbers. If that’s all that’s different, I can work with that.
  5. Oct 13, 2020 at 7:31 PM
    ATHiker
    ATHiker New Member
    Tom
    2015 DC SR5TRD 5.7L 4X4
    I think it would be worth it to contact Bak. Maybe able to talk to someone in customer service?
