BakFlip Cover Specific Discussion
Discussion in 'Tonneau Covers, Caps and Shells' started by rizico, Mar 16, 2022.
  1. Mar 16, 2022 at 12:42 PM
    rizico
    rizico [OP] New Member
    Johnny-Don
    Luling, Tx
    '22 Capstone 4x4
    I was hunting for specific info and felt like I had to dig and search way too hard to get it in the 2 relevant threads that existed, so wanted to hopefully help someone out who may have been in the same boat as me, and also I plan to document my install here.
    With ZERO luck finding an OEM cover in stock for my 5.5, and no ETA I just pulled the trigger on a BakFlip MX4. (Out of stock at , but in stock at ) After a lot of reading here and on some FB groups, I came to the 'conclusion' that the OEM is made by Bak industries (A subsidiary of Truck Hero). According to Bak, the OEM cover is a rebranded Bakflip G2, contrary to most reports that it's a rebranded MX4. I believe there is some weight to this because on another post, a tundra owner who said he had an MX4 on his old Tundra was arguing that the OEM cover is NOT and MX4, it's "better" because it's "Lighter", this is likely because the G2 has a 1/2" core, while the MX4 has a 5/8" Core. Also the G2 is only good for 300Lbs of evenly distributed weight, and the MX4 is good for 400Lbs. If anyone with an OEM cares to get with me to to an in depth comparison once mine comes in, I'm game.
    arrampico and gmcguire7220 like this.
  2. Mar 16, 2022 at 12:56 PM
    gman54313
    gman54313 New Member
    Ironically, I just got off the phone with tonneauworld and was told I would have to ditch my rail system on the 22 Tundra. Do you have the rail system?
    rizico[OP] likes this.
  3. Mar 16, 2022 at 1:53 PM
    rizico
    Johnny-Don
    Luling, Tx
    '22 Capstone 4x4
    First, Thank you, second Darnit.
    After a lengthy chat with a Bakflip Rep (tonneaucoversworld.com and Bakflip.com are the same people BTW). The part number BAK-448440 is in fact the part number for a 5.7' bed with OR without deck rails, what it will NOT be compatible with is the Trail Special Edition Storage Boxes. However, they are 6-8 weeks out. The rep said at this point covers for the 22' are made to order, and they are gaging demand. The shipping time hasn't updated on tonneaucoversworld.com, and any order you put in will ship in 6-8 weeks. With this new information, I may cancel my order, but maybe not.
  4. Mar 16, 2022 at 4:33 PM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    I think the primary reason that drives the OEM Bed Cover is a rebranded MX4 (vs the G2) is the cover itself. I'm at work and can't get a thickness on my cover for awhile, but here are pics for comparison of the construction of the 3 covers.
    Note the underside material mimics the MX4 vs the "exposed" aluminum of the G2.
    OEM:
    MX4:
    G2:
    One thing that does support the OEM cover being a rebranded G2 are the rails. The rails on the G2 are "cheaper" than that of the MX4. The G2 rails have exposed aluminum ends whereas the MX4 rails have more of a "finished" look to them. The fit & finish of the MX4 rails are better. I might suspect they mixed by using the higher quality cover with the cheaper rails, but that's pure speculation on my part.
    At the end of the day, I'm pretty sure the only real meaningful difference between the two is the core thickness that drives load capacity on top of the cover. The actual "locking" and stay pole mechanisms are the same, I believe.
    The OEM cover instructions and info about the cover on Toyota.com don't state a load capacity rating for on top of the cover, so it's tough to tell without a thickness measurement.
    arrampico, gman54313 and rizico[OP] like this.
  5. Mar 16, 2022 at 5:06 PM
    rizico
    Johnny-Don
    Luling, Tx
    '22 Capstone 4x4
    KroppDuster likes this.
  6. Mar 16, 2022 at 6:29 PM
    rizico
    Johnny-Don
    Luling, Tx
    '22 Capstone 4x4
    Well even after I had someone confirm a ship date after Bak rep told me what she did, they’re still telling me it will ship to deliver next week. Only time will tell I guess. I’ll keep y’all posted, on delivery and then on fit if/when it arrives.
  7. Mar 17, 2022 at 5:28 AM
    gman54313
    Getting good information from manufactures is like trying to herd cats now days. Please keep us update.
  8. Mar 18, 2022 at 5:40 AM
    rizico
    Johnny-Don
    Luling, Tx
    '22 Capstone 4x4
  9. Mar 21, 2022 at 8:24 AM
    rizico
    Johnny-Don
    Luling, Tx
    '22 Capstone 4x4
    UPDATE: MX4 Order cancelled, as I found an OEM cover at the dealer. Install help video and discussion of that cover here.
    arrampico likes this.
  10. Mar 21, 2022 at 10:21 AM
    gman54313
    sounds good. I will still hangout as I am not sure when my ride will show up.
  11. Feb 2, 2023 at 6:09 PM
    arrampico
    arrampico New Member
    2023 SR5 CM 4X4 SB Silver Tundra
    Did you ever get the measurement of the thickness? Curious as I’m looking at one an Toyota has ZERO specs for weight carrying capacity listed for thier OEM.
  12. Feb 3, 2023 at 8:19 AM
    TUNDRA-TY
    TUNDRA-TY Winter SUCKS!
    Tyler
    Tricities, WA
    23 SR5 4WD CMSB CSM
    I've talked to a rep at Bakflip, their load carrying capacity is between 300-400lbs evenly distributed across the cover depending on the model.
    arrampico[QUOTED] likes this.
  13. Feb 3, 2023 at 9:01 AM
    raylo
    raylo not so new member
    Frederick, MD
    I just measured the Toyota OEM cover thickness. It is ~15mm.
  14. Feb 3, 2023 at 9:10 AM
    arrampico
    For the BAKFlip proper? I’m getting the Toyota OEM one that nobody seems to have a real answer for….and if the Toyota is actually a BAKFlip, what model?
  15. Feb 3, 2023 at 9:14 AM
    arrampico
    That is closer to 5/8” suggesting (The Toyota OEM) is most likely the MX4 rebranded by Toyota (combined with it being the matte color this makes the most sense).
  16. Feb 3, 2023 at 9:58 AM
    raylo
    Frederick, MD
    It feels really solid and heavy duty for sure. Although I am not sure I can live with it and might need to go back to a retract like I used to have for the intermediate locking positions. If I do, I'll sell this one here.
  17. Feb 3, 2023 at 10:29 AM
    gj953
    gj953 New Member
    East Coast
    2023 1794 Hybrid TRD OR Blueprint
    While we're talking the bakflip - I have the OEM Tundra - and one of the bumpers on the section closest to the cab popped off in the first 2 days I owned it. Strange, but it seems the 3m tape didn't really get a good hold on the surface. The other side, is still on. I have the original piece that fell off, I contacted bakflip, and they sent me this huge bag of all other kinds of bumpers, but none this exact size. So, any suggestions on how /what to use to get this original one back on? Rec'd tape? or ?upload_2023-2-3_13-32-17.jpg
  18. Feb 3, 2023 at 12:32 PM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    I've had good experience with double sided Gorilla tape. Have no idea how it holds up in weather though.
    gj953 likes this.
  19. Feb 3, 2023 at 2:29 PM
    arrampico
    i was wondering about that same exact thing….don’t have my truck yet. Did they install the foam pieces to touch the window or the outside cab? I’m hoping they put mine on the window area (not that I will drive around a ton with it up anyways) so it will not mess up the paint.
    gj953[QUOTED] likes this.
  20. Feb 3, 2023 at 3:44 PM
    TUNDRA-TY
    Tyler
    Tricities, WA
    23 SR5 4WD CMSB CSM
    OEM is the Bakflip MX4 with a toyota logo on it. 400lbs evenly spread across the cover (snow load)
  21. Feb 3, 2023 at 4:00 PM
    War Machine
    War Machine SSEM # 5 3MW
    Mine did the same thing. Haven’t gotten around to putting it back on yet.
  22. Feb 4, 2023 at 7:58 AM
    gj953
    gj953 New Member
    East Coast
    I'll have to get some and try it - This is in SWFL, so the biggest issue here, is the heat/sun. But, like I said, it came off, like a day or so after I put it on.
    One other person asked about the blocks for the windows - This was a Tundra OEM (from bakflip) that I installed myself and yes, i put the blocks on for where it touches the cab when fully opened. This was a slim bumper (not even sure what it's there for as nothing seems to bump against it there. - It sits next to the snap receiver for the strap, and is maybe 5/16" wide/high and rounded on the top side, flat where it attaches to the tonneau cover with tape, 4" long. Now that I think about it, it might be there, to protect the snap - if you lay anything on top of the tonneau cover when it's closed. (say if you put plywood on top, or something like that... maybe it is for protecting those snaps, I'll have to look closer to see if that might be what it's for)
    Update: so I washed the truck yesterday and looked at the side that is still stuck on solidly after 3 months - and it's not tall enough to protect the snaps... so, not quite sure, what it's for. If anyone has an idea, I'd like to know what it's for.
  23. Dec 30, 2024 at 5:40 PM
    jtweezy
    jtweezy New Member
    Jeffrey
    Can anyone with an MX4 measure the vertical space from the floor of the bed (on one of the raised ribs) to the underside of the cover? In other words, what’s the maximum height of a box I can fit under the tonneau when closed?
  24. Dec 30, 2024 at 8:14 PM
    LowcountryDave
    LowcountryDave New Member
    ‘23 Limited TRD
    I’ve got 20” to the bottom of the MX4 from the top of the raised rib. Midway down the cover I have the pieces that allow it to rest against the back window. They come down a little further and I’m thinking that spot probably has 19-1/4” clearance.
    jtweezy[QUOTED] likes this.
  25. Dec 31, 2024 at 5:39 AM
    jtweezy
    jtweezy New Member
    Jeffrey
    You’re the man!
