Bak x2 cover too far forward?
Discussion in 'General Tundra Discussion' started by scjb007, Dec 14, 2017.
  1. Dec 14, 2017 at 7:45 AM
    scjb007
    scjb007 [OP] Big Blue Nation
    Kentucky
    2017 White Platinum
    2018 led headlights and fog lights, Trd pro grill, rc 30in light bar, iron cross hd steps, trd sway bar, trd shift knob, color matched door handles and mirror caps, Linex bed liner, amber marker lights, led cargo lighting, anytime fog mod, VLED footwell lighting, bak x2 revolver, and FRAC.
    I had a Bak x2 cover just installed and it looks like it's a 1/2 inch too far forward. The flap in the front sticks out instead of laying on the front edge of the bed. If you have one installed, does yours line up like mine or is it further back over the tailgate?
    Thanks.
  2. Dec 14, 2017 at 8:07 AM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Will it shove back anymore? I originally had my F1 to far towards the rear. I just kept moving it back and forth until it looked best at the tailgate. Even then the front looks like it is a little to far towards the cab. Not as much as yours does in that pic though.
    scjb007[OP] likes this.
  3. Dec 14, 2017 at 8:16 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    i would pull it a little more to the tailgate.. maybe by a 1/4".
  4. Dec 14, 2017 at 8:16 AM
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    Mines pretty close to that maybe a 1/4” farther back but not much at all
  5. Dec 14, 2017 at 8:53 AM
    scjb007
    Kentucky
    2017 White Platinum
    Thanks for the quick responses. I'd like a little more water resistence/coverage over the tailgate. I'm gonna try to slide it back tonight if it'll move.
  6. Dec 14, 2017 at 10:41 AM
    MakMurph
    MakMurph I'm here
    Ya I tried sliding mine back for that reason. It didn’t help, there’s such a big gap all around where the tailgate closes it’s almost impossible to keep the heavy rain or car wash water out of it unless you pack it full of weatherstripping
  7. Dec 14, 2017 at 12:10 PM
    scjb007
    Kentucky
    2017 White Platinum
    It hasn't rained here since install but I'm interested to see how much rain water will make it in that little gap. Did you pack yours with weatherstripping?
  8. Dec 14, 2017 at 1:16 PM
    smooosh
    smooosh This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
  9. Dec 14, 2017 at 2:18 PM
    MakMurph
    MakMurph I'm here
    I had a little bit of the roll left I just tried piecing it in there. I’ll try and get a pic tomorrow. It’s dark and snowing like crazy here right now.
    scjb007[QUOTED][OP] likes this.
  10. Dec 14, 2017 at 2:35 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    To position it correctly, loosen the bolts at the front and with the tailgate down, pull the cover back until you have a 1/4" or so of the cover overhanging the rails. With the bolts loose and the cover latched, gently close your tailgate. What you want is for the tailgate to contact the bulb seal that runs across the inside rear edge of the cover. I usually lay inside and have a coworker close the tailgate and with a flashlight I make sure that there's contact, I have the coworker make sure the cover is square and with someone holding the front corners down, I tighten the nuts.
  11. Dec 15, 2017 at 10:15 AM
    MakMurph
    MakMurph I'm here
    Here’s some pics that’s the tailgate gap I was talking about. That’s about the only spot the water comes in. Nothing in the front of the bed.
  12. Dec 15, 2017 at 11:21 AM
    scjb007
    Kentucky
    2017 White Platinum
    Thanks for the pictures guys. Everybody also recommends the Pop and Lock for added security. Not sure how this helps but I'll give it a try.
    smooosh likes this.
