Baja Designs Squadron Fog Light Option
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bannock452, Oct 3, 2020.
  1. Oct 3, 2020 at 3:21 PM
    Bannock452
    Bannock452 [OP] New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Hey everyone!
    So I made myself some custom fog light brackets for my tundra and have had a lot of people ask where I got the brackets. So I have designed and built a production run for these fog light mounts.
    These mounts will only work with the Baja Designs Squadron series pods. The fog light kit that comes with the squadrons are made from plastic and become loose or rattle when offroad and sometimes fall out! My bracket is Powder coated Black and made from .125" aluminum with welded tabs so the mount is nice and solid.
    The angle of the pod is facing outwards so the light projection is great for cornering or "ditch" lighting. I personally wanted this light output since I had a lightbar facing straight ahead already. With the Baja Designs "wide" angle lens it fills in very nice but is still not a forward facing light. Just FYI for those looking for a forward facing light.
    Cost will be $100 total shipped
    Thank You for supporting the #BANNOCKBUILT small business!
    Please send me a PM for further info about purchasing these brackets. Also contact via Instagram @Tundra452
    Bolts directly to the metal bumper
    Light Beam against a hill
    PLASTIC HOUSING FALLING OUT
    Thank you and feel free to PM for any questions. Also contact through Instagram @tundra452 for more info.
  2. Oct 3, 2020 at 3:26 PM
    alwzdfiant
    alwzdfiant New Member
    2013 Tundra Crew Max
    Great looking product!!! I’m sure these will sell just as good as your awesome compressor mounts!
    Bannock452[OP] likes this.
  3. Oct 28, 2020 at 10:44 AM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    That's sick, I'd buy today if I wasn't waiting on a new bumper. I will be needing a compressor mount though.
  4. Oct 28, 2020 at 11:02 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    So it uses the Baja bolts from the lens?
  5. Oct 28, 2020 at 11:20 AM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    So sick! If I still had my stock bumper I would jump on this without hesitation. Nice job!
  6. Oct 28, 2020 at 11:57 AM
    Bannock452
    Brandon
    Murrieta, CA
    Yes sir that’s correct. The same Baja countersink bolts to mount the pod in the plate.
  7. Oct 18, 2024 at 8:34 PM
    SoJersey
    SoJersey New Member
    Good evening @Bannock452, do you have any of these left? I know it’s years later but I just stumbled upon this.
  8. Oct 18, 2024 at 8:51 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    bannockbuilt.com
  9. Oct 19, 2024 at 8:59 AM
    Bannock452
    Brandon
    Murrieta, CA
    Yes sir still making theses mounts and they are live on my website. Thanks for sharing Jason! Thanks guys!
    Bannnockbuilt.com
  10. Oct 19, 2024 at 5:08 PM
    SoJersey
    SoJersey New Member
    Thank you both!!
    BiggHertz likes this.
