Baja Designs S8 20" Lightbar and Cali-Raised Switch
Discussion in '3rd Gen Tundras (2022+)' started by Buellride, Dec 13, 2022.
  1. Dec 13, 2022 at 7:29 PM
    Buellride
    Buellride [OP] New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    Took a little bit for the S8 to arrive but the installation was very smooth. An added benefit is the lightbar is always ON with a 20221213_191744.jpg 20221213_191659.jpg 20221213_191646.jpg 20221213_191727.jpg 20221213_191759.jpg "marker light" look to it when the DRL/parking lights are on. The photos show the button panel back light and then with the light bar turned on (note the blue solid bar above the Cali-Raised button)....the exterior photos show the light bar off (but with the marker light look) and then on. Love the look and the functionality.
    bulldog93, drobb, AND and 3 others like this.
  2. Dec 14, 2022 at 7:59 AM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    Looks good, I like how you moved the switches around. Would also like to see from the driver seat a picture of the beam pattern without headlights on, please.
    ChiefG likes this.
  3. Dec 14, 2022 at 8:07 AM
    Buellride
    Olympia
    THE BOULDER
    Sure, I will need to post a picture of that later tonight or tomorrow.
    Regarding the switches, I noticed that you can really only see the first 2-3 switch/buttons on the left of the panel when seated in the drivers seat. So I considered what were my most used switches and adjusted appropriately. What is interesting is that the OEM switches are actually pre-notched to the panel. So even though I moved the "Auto On/Off" to the lower right side of the panel, it wouldn't fit initially because the notch pattern was different....a quick dremel of the notch on the OEM switch itself and it fit no problem. Just something to consider in the future if you are moving the OEM switches/buttons around on the OEM panel.
    AND, Maharisc[QUOTED] and Skidmarcx like this.
  4. Dec 14, 2022 at 8:57 AM
    Krusher22plat
    Krusher22plat New Member
    22plat
    Interesting in I have the S8 but put the drl amber on own switch and light on another switch. But my center section only lights up low amber when on.
    Did you hook both up to truck hi and then low for amber running? That must have made the difference.
  5. Dec 14, 2022 at 9:06 AM
    Buellride
    Olympia
    THE BOULDER
    I installed the wiring as recommended and the BD switch provided initially didn't have the amber "low", but when I installed the Cali-Raised switch I combined the 2 negative ON wires into the BD relay (?) wire. I need to double check the wiring sequence I used. Personally I love that the S8 is on LOW during DRL driving and then fires up full when the switch is depressed.
    AND and Maharisc like this.
  6. Dec 14, 2022 at 9:29 AM
    Krusher22plat
    22plat
    Many thanks..i like the DRL on low as well. Just curious in yours looks like the amber is on across entire backlight. Mine is center 6” it appears.
  7. Dec 14, 2022 at 9:39 AM
    Buellride
    Olympia
    THE BOULDER
    I think mine is very similar to yours, believe that it is 3 of the backlights on either side, directly above the license plate holder. See picture.20221214_093749.jpg
    ChiefG and Maharisc like this.
  8. Dec 14, 2022 at 10:23 AM
    Krusher22plat
    22plat
    Yeah..think you are right in angle looked at changes how the amber looks.
    ChiefG and Buellride[OP] like this.
  9. Dec 14, 2022 at 10:25 AM
    Buellride
    Olympia
    THE BOULDER
    Beautiful truck! And as a vet myself, I think I know what your plates are saying.... LOL
    Maharisc likes this.
  10. Dec 14, 2022 at 10:33 AM
    Krusher22plat
    22plat
    Tks an Roger that! :anonymous:
    Maharisc and Buellride[OP] like this.
  11. Dec 14, 2022 at 12:45 PM
    Maharisc
    Maharisc w/Patty
    Karl
    So far, no body but ARMY has posted to this thread...
    Another thing I have noticed, those of us military in this forum choose either Midnight Black or Magnetic Gray for our trucks.
  12. Dec 14, 2022 at 12:51 PM
    Buellride
    Olympia
    THE BOULDER
    LOL....
  13. Dec 14, 2022 at 2:11 PM
    Krusher22plat
    22plat
    LOL…I just call it good taste! (Kinda funny sold a 19’ tacoma Magnetic grey)
  14. Dec 14, 2022 at 3:55 PM
    Maharisc
    Maharisc w/Patty
    Karl
    I traded 20 Tacoma MGM for this 22 Tundra MGM.
    ChiefG likes this.
  15. Jan 28, 2023 at 6:27 PM
    ChiefG
    ChiefG Limited 4X4 TRD OR
    Burlington Township, NJ
    2022 Tundra Limited Off Road 4X4
    Just minor stuff. For example, Undercover bed cover, Tufskinz custom door sill protectors, and TRD air filters.
    Did you remove the switch panel to install another switch? If so, how did you remove it? If not, how did you hook it up. Nice look.
  16. Jan 28, 2023 at 6:32 PM
    ChiefG
    Interesting! I’m retired AF and have midnight black.
  17. Jan 28, 2023 at 7:06 PM
    Maharisc
    Maharisc w/Patty
    Karl
    Which I just traded for this 23 Tundra MBM, upgraded to a Plat.
    Good to see you here ChiefG.
    ChiefG likes this.
  18. Jan 29, 2023 at 12:13 AM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    Awesome. Link to DOT cert?
  19. Jan 29, 2023 at 5:47 AM
    Buellride
    Olympia
    THE BOULDER
    The trim around the OEM switches just pops out with a trim tool. There are 2 clips on the top and bottom edges of the panel. You can also remove the dash access panel to the left of the dash to aid in compressing the panel clips if you are hesitant or concerned with breaking panel tabs. Search YT there are a few 2022 Tundra dash panel removal videos
    ChiefG[QUOTED] and AND like this.
  20. Jan 29, 2023 at 7:55 AM
    AND
    AND New Member
    Washington, PNW
    Did you wire your lightbar to turn on with your highbeams?
  21. Jan 29, 2023 at 8:14 AM
    Buellride
    Olympia
    THE BOULDER
    No
  22. Jan 29, 2023 at 11:12 AM
    Maharisc
    Maharisc w/Patty
    Karl
    Here's pics of pulling that panel off:
    AND and ChiefG like this.
  23. Jan 29, 2023 at 1:44 PM
    Yoda_Lance
    Yoda_Lance New Member
    San Diego, Ca
    22 Platinum WCP Hybrid 4x4
    I went with the rave off road switch. It’s a tad brighter but works
    Baja Designs, ChiefG and ElNopal like this.
  24. Jan 31, 2023 at 6:39 AM
    ChiefG
    Looks great. Really like that TRD Lightbar switch.
  25. Feb 11, 2023 at 7:44 AM
    AND
    AND New Member
    Washington, PNW
    Where are you guys tapping/wiring into for the amber back light on the Baja S8?
  26. Feb 11, 2023 at 9:05 AM
    Krusher22plat
    22plat
    I did a 6 switch auxbeam and have both the amber and main light switchable. May just use an add a fuse and have on whenever truck is on.
  27. Feb 11, 2023 at 9:13 AM
    AND
    AND New Member
    Washington, PNW
    Ive been trying an add a fuse but all fuses in fuse boxes under the hood are constant 12v, even with truck turned off.
  28. Feb 11, 2023 at 9:41 AM
    Krusher22plat
    22plat
    Will have to search but guys have found a couple that are not constant on.
  29. Dec 17, 2023 at 9:22 PM
    PikesPeakTRD
    PikesPeakTRD New Member
    23 Hybrid Limited TRD OR MGM
    @Buellride saw on another post that you’d had some issues with the lightbar turning on unexpectedly. Have you gotten all of that figured out and if so, what did you have to change?
  30. Dec 18, 2023 at 6:26 AM
    Buellride
    Olympia
    THE BOULDER
    PPTRD, to clarify, the DRL function of the BD light bar would unexpectedly come on when the truck is parked. To answer your question, no I still haven't figured it out. Both Caliraised and BD told me everything was connected correctly. In the end, I believe the light bar is sensing or the wiring is tied into a sensor that SOMETIMES turns on the DRL function of the lightbar. Do you have the same issue?
