Baja Designs S1 | Over 2k Lumens from a single LED light
Discussion in 'Lighting' started by Baja Designs, Sep 14, 2019.
  1. Sep 14, 2019 at 11:13 AM
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Designed from the ground up our new S1 fills the shoes of a large light in a small package! The S1 utilizes a highly specialized reflector and LED combination to outshine the competition. With the 2.1" length, width, and height the S1 is highly versatile for any application that is in need of light. Whether you're looking for a light to drive off of, or something to light up a campsite the S1 will exceed your expectations!
    Specifications:
    Lumens: 2,375 Utilizing 1 LED
    Wattage/Amps: 20W / 1.45A
    Dimensions: 2.1" x 2.1" x 2.1"
    Weight: 0.4 lbs
    LED Life Expectancy: 49,930 Hours
    Front Lens: Hard Coated Polycarbonate
    Housing: Hard Anodized & Powder Coated Cast Aluminum
    Bezel: Billet Machined Aluminum
    Hardware & Bracket Material: Stainless Steel
    Exceeds MIL-STD810G (Mil-Spec Testing)
    Built-In Overvoltage Protection
    IP69K (Waterproof up to 9ft & Pressure Washable)
    IK10 Compliant (Mechanical Impact Testing)
    CLICK HERE
    TruckyTruck and TRD15559 like this.
  2. Sep 14, 2019 at 6:48 PM
    19TuRDSport
    19TuRDSport New Member
    Michigan
    2019 MGM Tundra SR5 TRD Sport Crew Max
    I want that for my snowblower
  3. Sep 14, 2019 at 7:14 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    These look interesting. May have to open up the wallet again...
